Mid Atlantic Impreza Club
Go Back   NASIOC > NASIOC Chapters > Mid Atlantic Impreza Club -- MAIC > MAIC Private Classifieds
Old 03-23-2010, 09:30 PM   #1
firefighting03wrx
Member#: 237601
2003 Impreza WRX
Black/ Blue
Default WTT: Trailing arms
i need a set of either Outback Trailing Arms or Forester ones. I lifted my car last weekend and im not liking the "off-kilter" rear wheel spacing
Please help!!!
firefighting03wrx is offline   Reply With Quote
Old 03-24-2010, 02:37 AM   #2
Abnormal
Lil Curious
Member Sales Rating: (45)
Member#: 149626
2005 CGM FXT
Rocket Box! :D
Trailing arm brackets are cheap from our MAIC-sponsoring dealer, Jackie at Annapolis Subaru.
What did you use for the lift? I would only use FXT brackets if you used FXT struts and springs.
Abnormal is offline   Reply With Quote
Old 03-24-2010, 06:12 AM   #3
highway_patrol
Member Sales Rating: (7)
Member#: 154296
Slow as balls
Ford Ranger
On DI he said Outback and here he said Legacy so that being said I think he meant to say Outback. I need to get trailing arm brackets for my Forester lift.
highway_patrol is offline   Reply With Quote
Old 03-24-2010, 08:22 AM   #4
nhat
Member Sales Rating: (42)
Member#: 140163
03 STi
hellaflunctional
you want forester trailing arm brackets. i've done all the research. you'll also want outback sport cv spacers so your axles don't bind
Old 03-24-2010, 02:20 PM   #5
firefighting03wrx
Member#: 237601
2003 Impreza WRX
Black/ Blue
ok, let me be a little more Clear, the susp came off a legacy, the legacy was outfitted with impreza outback susp. For highway_potrol this all came off Strat's Rally-x car. my old susp went onto his legacy. I am still semi new to the idea, i got the most expensive part done, but now i need all Peices to finish the transformation. You gotta remember i started with a Slammed WRX and i have worked up to here. I am just lookin some help to finish her susp up b4 may. Thanks for the Help i have recived so-far!!!
Old 03-24-2010, 11:10 PM   #6
firefighting03wrx
Member#: 237601
2003 Impreza WRX
Black/ Blue
Bump!
Old 03-25-2010, 03:21 AM   #7
highway_patrol
Member#: 154296
Slow as balls
Ford Ranger
Oh I didn't know that. Your coming to the DI spring meet right?
Old 03-25-2010, 11:44 AM   #8
firefighting03wrx
Member#: 237601
2003 Impreza WRX
Black/ Blue
as far as i know, as long as they dont move it to the 15th bc i wont be able to get off work
Old 03-25-2010, 01:24 PM   #9
Abnormal
Lil Curious
Member#: 149626
2005 CGM FXT
Rocket Box! :D
Came off an Impreza Outback?
Then you want the matching trailing arm brackets. The Forester ones might push your wheels back too far. Call Jackie, see if the part numbers differ from regular Impreza to the Outback. Pretty sure it is.
You don't need the axle spacers because you haven't lifted it that high... yet
FS : WRX rear trailing arm bushing txl146 Suspension/Brakes/Handling 1 06-04-2010 11:26 PM
FS : WRX rear trailing arm bushings txl146 Tri-State Area Private Classifieds 0 06-04-2010 08:47 PM
FS: MD STI lateral links, trailing arms, and Super Pro Trailing Arm Bushing boyracer_05 Suspension/Brakes/Handling 10 04-16-2010 12:46 PM
Adjusting Adjustable Arms of Trailing. What to set trailing arms at? relliMmoT Brakes, Steering & Suspension 9 03-02-2010 01:59 AM
NEW Superpro Trailing Arm Bushings (front bushings on the trailing arm, not the hub) fastwrx25 Suspension/Brakes/Handling 5 11-13-2007 02:40 PM
