Mid Atlantic Impreza Club
Old 08-15-2010, 10:54 PM   #1
Dr. octagon
Member#: 171127
62XX Rotated
*Mo Displacement
Default Question on Shaft Play Stock TDo4
I currently have 98k on my tdo4 and am questioning the longivity of the turbo seals. The seals are not leaking as of yet, but am trying to stay ahead of the game. My buddy is offering me his 60k tdo4 but was told at the time of his vf39 install that his stocker had "a little shaft play". I am not familiar with "a little shaft play" or how much a td04 should have.
1. Is it possible for a turbo to never have shaft play?
2. Is it normal for turbos to have shaft play?
2. He is currently running/has been running RP 5-30. What impact does this have on cooling or lubrication of the turbo/seals.
Yea..........he is offering it to me for $20.00 so i know bitching on my end should be 0, but i dont want a paper weight. Turbo was fully operational at the time of his vf39 swap. Looking to have grimm speed pnp it, or maybe a local who has experience.
Dr. octagon is online now   Reply With Quote
Old 08-15-2010, 11:00 PM   #2
Boogalo
Member#: 77435
04 WRX Wagon Stg2
'94 Miata Project
i have 107k on the stock td-04. 35k at stage1, 5k at stage2. there was no shaft play when we checked it during the stg2 install.
we're not quite sure if its leaking oil. TMIC isn't soaked, but certainly has some in it. i lose a quart every 2-3k
Boogalo is offline   Reply With Quote
Old 08-16-2010, 08:49 AM   #3
Dr. octagon
Member#: 171127
62XX Rotated
*Mo Displacement
Ok, anyone else have insight on questions 1,2,and 3>?
Old 08-16-2010, 08:52 AM   #4
Ryan314
Member#: 82989
Hybrid VF22
No turbo will have zero shaft play. A slight side to side shaft play is completely normal/fine.
Up and down shaft play is NOT normal, and the turbo is toast if there is.
Ryan314 is offline   Reply With Quote
Old 08-16-2010, 10:31 AM   #5
Dr. octagon
Member#: 171127
62XX Rotated
*Mo Displacement
^^^^^^^^Thanks
Old 08-16-2010, 01:20 PM   #6
Mach V Dan
Member#: 12029
More specifically, about 1mm of play in the radial direction (out towards the fins) is normal.
There should be zero axial play (along the axis of the shaft).
--Dan
Mach V
FastWRX.com
Mach V Dan is online now   Reply With Quote
Old 08-16-2010, 01:30 PM   #7
Dr. octagon
Member#: 171127
62XX Rotated
*Mo Displacement
--Dan
Mach V
FastWRX.com
Pm comming your way.......you recently saw this customers tdo4
Old 08-16-2010, 02:12 PM   #8
Anti Trust
Member#: 170256
2000 002.5rst-07wrx
blue
sorry off topic but its actually normal to "burn" 1qt of oil per 3k miles
Anti Trust is offline   Reply With Quote
Question on PSP via stock system Ricewagon Car Audio, Video & Security 3 01-30-2009 01:19 PM
Impreza owner question on your "ram" stock air intake? Bluefoton Legacy Forum 23 06-29-2008 12:57 AM
Question on cams for Stock 2.0L WRX Heads naTe02 Factory 2.0L Turbo Powertrain 6 04-19-2006 02:45 PM
Question on versions of stock ECUs - year variations?(looking at I-Speed Reflash) Back Road Runner Engine Management & Tuning 1 03-11-2006 09:01 PM
Question on the subaru stock body kit Wrx0R Interior & Exterior Modification 2 10-16-2001 02:13 PM
Message Board Statistics All times are GMT -4. The time now is 11:16 AM.
