Old 03-25-2010, 02:51 AM   #1
KingGalantVr4
Member#: 121092
LOOK OUT BELOW!
Re-entry is a &!^%#
Default Failed my vision test for my license renewal. Question about contacts.
Yeah, I couldnít believe it either. My driverís license expired so it was time to renew and when the vision test came up I made a mistake on 2 of the letter out of something like 12 on the bottom line. That means I failed. So I drive to the ophthalmologist and get a sight screening.
Oph: Why are you here?
KGVr4: I failed my driverís license vision test.
Oph: Ok, letís start with an exam.
Exam takes place
Oph: Ok, seriously why are you here? You donít have an impairment that would preclude you from passing the state vision test. Seriously, I purposely give people the vision you have for a living, I donít understand why you are here. However yore right eye is slightly deficient and I can give you a trial of contact lenses to test drive if you like. You will only need one as you have perfect vision in yore other eye.
I go back to the DMV with the form he filled out and they put a restriction on my license because I failed the test regardless of him signing off on my vision. Outside Mirrors on Each Side of the vehicle. Isnít this federal law now? I havenít seen a vehicle without a passenger side rearview mirror since the late 80ís early 90ís. I think to myself, this is not worth fighting over, **** it. Thanks for running me all over the place for hours DMV.
So, about contacts Ö I like the contact, but I know NOTHING about them other than they are CIBA VISION Dailies and how to put them in and take them out. What else should I know?
If I fall asleep/take a nap with them in (2-3 hours) is it going to be a problem?
Is there a specific brand that I should test drive? Are weeklyís better? Extended wear? ETC?
KingGalantVr4 is offline   Reply With Quote
Old 03-25-2010, 02:54 AM   #2
choloman05
Member#: 99359
02 wagon
blackish-blue
DMV play trick on you
choloman05 is offline   Reply With Quote
Old 03-25-2010, 02:55 AM   #3
obyone
Member#: 16523
That's what you get for being a conservative.
obyone is offline   Reply With Quote
Old 03-25-2010, 02:57 AM   #4
KingGalantVr4
Member#: 121092
LOOK OUT BELOW!
Re-entry is a &!^%#
Seriously, I had to adjust my tin foil hat because I started thinking they were receiving kickbacks from ophthalmologists.
Only fiscally, not socially. BIIIIIIIIIIIIIIIIIIIIIIIIIIIG difference.
Old 03-25-2010, 02:58 AM   #5
skywaffles
Member#: 82470
I am more humble
than you can understand.
If you sleep in them you run the risk of blinking them out, otherwise they're harder to take out.
I use two week disposables, but have been using the same pair for probably a year. YMMV
skywaffles is offline   Reply With Quote
Old 03-25-2010, 02:59 AM   #6
r0bman
Member#: 87015
I've been wearing contacts on a daily basis since I was about 15. Flat-out, you get used to them.
I've slept with them in... the byproduct is that you wake up with very dry contacts. Move 'em around, blink a few times... problem solved. Be as it may, I've gotten into a system where I can't live without correction... i.e. if my contacts come out, my glasses are on. The second my lenses start irritating me, I change 'em. This usually equates to about 3 months or so of daily wear.
My girlfriend has very similar vision to mine, and she wears her contacts when she feels like it... same approach to her glasses. I don't get it, I can't imagine being that "blind," but I do see her standpoint in that she's used to it, which I am not since I've been rocking correction for over a decade.
So, in conclusion, I just blabbered a bunch and I'm not sure I helped. Contacts kick ass because you're vision is 95% perfect 100% of the time.
r0bman is offline   Reply With Quote
Old 03-25-2010, 03:05 AM   #7
KingGalantVr4
Member#: 121092
LOOK OUT BELOW!
Re-entry is a &!^%#
Do you clean them or have you just left them in that long? Again, this may be a stupid question but I seriously have ZERO clue about these things.
What kind of contacts are you rocking? The dailys or something else?
Yeah, the ophthalmologists had to back down the prescription 2 steps from perfect vision in my right eye because I was trippin balls.
Old 03-25-2010, 03:12 AM   #8
hotshot172
Member#: 85253
06 Beast Mode
I survived an F5
Been wearing 2 week disposables for almost 10 years now. I've always disposed them at the two week mark, they can honeycomb up and can be bad for your eyes. Never slept with them on unless I passed out drunk, but you get used to them, I don't even notice that I'm wearing them (feel wise, of course i can notice by seeing 20/20). I'm using acuvue advance btw.
I need to get PRK.
hotshot172 is offline   Reply With Quote
Old 03-25-2010, 03:14 AM   #9
skywaffles
Member#: 82470
I am more humble
I take then out every night and put them in saline cleaning solution.
If you wore then for that long you'd have corneal ulcers and they'd fuse to your eyes.
Old 03-25-2010, 03:15 AM   #10
r0bman
Member#: 87015
They're monthly's. Iv'e been through half a dozen brands over the years, and they're all the same. You wear them until they bother you, and then chuck 'em and crack open a new pair. This translates to anywhere between 2 and 4 months per pair. If I'm conscious enough at bedtime, (which is 95% of the time), they come out before I crash.
The shocker that people usually gasp at: I use Target brand contact solution, and have forever. It's like, $4 for 3 months worth of squirt. As I said, never had a problem.
Old 03-25-2010, 03:54 AM   #11
pezcore
Member#: 178045
06 WRX
CGM
The doctor should have told you how to use & maintain contacts
pezcore is offline   Reply With Quote
Old 03-25-2010, 03:56 AM   #12
KingGalantVr4
Member#: 121092
LOOK OUT BELOW!
Re-entry is a &!^%#
He taught me how to put them in, take them out, and throw them away daily. I didn't have questions until I got home and thought about it for a while.
Old 03-25-2010, 04:13 AM   #13
97whitesi
Member#: 70925
2002 S2000 90 R32GTR
2015 Accord Sport 6MT
I think I've left my night and days in for maybe 6 weeks, tops
97whitesi is offline   Reply With Quote
Old 03-25-2010, 04:19 AM   #14
vecdran
Member#: 162932
Contact wearer since the age of 12 here. Don't sleep with them in. They'll just dry out and it will suck.
I recently upgraded to Acuvue Hydraclear from Advanced 2. For once, the commercials were right. Immediately upgrade in comfort and un-noticeability.
vecdran is offline   Reply With Quote
Old 03-25-2010, 05:26 AM   #15
richde
Member#: 79498
2013 XV
I've been doing that for a while...until my last exam where the doc could see some effects of wearing contacts past their best buy date.
Just because you don't notice something now doesn't mean that you won't notice it later.
richde is offline   Reply With Quote
Old 03-25-2010, 07:03 AM   #16
boosted06
Member#: 144143
03 Wrx Wagon
damn. your getting old homie.
boosted06 is offline   Reply With Quote
Old 03-25-2010, 08:50 AM   #17
Kiel
Member#: 133439
2003 WRX
Sonic Yellow - Stage Taxi
In the morning when I knock my glasses off the nightstand, I usually have to have my wife find them after my frantic palming of the floor proves futile.
My deepest sympathes,
Kiel
Kiel is offline   Reply With Quote
Old 03-25-2010, 09:22 AM   #18
ExHonda
Member#: 170273
2016 Jeep Rubicon
Granite
I am -6 in both eye's, they are still very slowly getting worse, but not stigmatisms or whatever yet. Due to slowly changing eye sight I am not going to try for laser eye surgury until they stop changing. I REALLLLLLY hate glasses. I am a stickler for having them clean constantly and not having crap on them or smudges. However I work in a refinery and I can't wear contacts at work due to the risk of getting something in my eyes, solid/liquid/gas, and if you wear contacts there is a chance it can get stuck behind the contact and do more damage to your eye. Anyways I digress.
Most chances I get I wear contacts outside of work, I used to do disposable daily ones, but my eye's didn't seem to care for that peticular brand so I switched to acuvu(sp?) oasis and so far they have been great.
Like some said above, if you catch a nap with them in they will be dry, your eyes will probably not be all that happy with you either. Probably wake up with red eye's and depending how irritated your eyes are they may try and water a lot to compensate which can obviously lead to a ton of eye gunk you will need to clean out.
Any halfway decent eye doc will tell you that you shouldn't wear contacts 24/7. Your eyes need time to breath, even the best contacts can't offer that. If your Doc has one of those charts that shows different things that can happen to your eyes if you leave contacts in for too long I suggest you look at it to see what can happen.
When I wear contacts I usually carry a small bottle of eye drops with me for if my eyes start to feel dry or the contacts are bothering me. Don't always need it but it is nice to have.
ExHonda is offline   Reply With Quote
Old 03-25-2010, 09:37 AM   #19
Calamity Jesus
Member#: 44501
1984 That's *Sir*
Weinerlicks of Douche 2u.
Obviously the problem isn't your eyes. Your next step should be to get your GED since you're having issues with yore letters.
Old 03-25-2010, 09:43 AM   #20
vwzealot
Member#: 162696
06 Cooper S
07 Turbo
I've been wearing my 2 weeks for about 3 months at a time, and I sleep in them. I've done this for about 10 years. Doc's have never noticed anything D:
It is something I worry about though. Thinking about lasik, etc ;o
vwzealot is offline   Reply With Quote
Old 03-25-2010, 09:56 AM   #21
punk
Member#: 169792
2005 STI
I've been wearing Frequency 55 for about seven years and never had a problem with them. They are meant to be worn for one month per pair, but I normally double or triple that and have never had an issue.
Napping is just fine, sometimes they will get "stuck" in place blink a bit and they will be back to normal. Sleeping not so much (for me at least); I've slept a few nights with them in and wake up to very blurry/hazy vision. I suspect because the type I wear are not meant to be worn to sleep and are not allowing my eyes to "breathe" enough.
Depending on what brand/type you get (ask your doctor on this) they should come out every night and sit in a cleaning solution until you put them in the next morning. Again, this depends what type of contacts you get...
punk is offline   Reply With Quote
Old 03-25-2010, 10:53 AM   #22
rally_wrc
Member#: 14680
Careful wearing them overnight, my friend got an eye ulcer and it looked hella painful, a white spot on his eye appeared. Also keep them clean so no bacteria or infection will form inside your eyelid. I have seen some pretty messed up photos of people who don't clean their lenses, it ain't pretty.
rally_wrc is offline   Reply With Quote
Old 03-25-2010, 10:58 AM   #23
Kaiser
PM me for
great turkey recipes
Member#: 7170
Aut Kaiser,
aut nullus.
Timely thread is timely, but slightly depressing. It's been 20 years since I tried wearing contacts, and I'm ready to give them another shot. But goddamn, I'd really hoped that 20 years would've resulted in contacts that you can wear 24/7 for a month at a time without any ill effects.
Kaiser is offline   Reply With Quote
Old 03-25-2010, 10:59 AM   #24
justincredible
Member#: 83633
2012 bright green
box
$20 to that poor bastard behind the desk would have gotten you your license.
$50 would get you a motor cycle license as well.
$100 would get you all of the above plus a class C license. In case you wanted to borrow a semi for your next road trip.
justincredible is offline   Reply With Quote
Old 03-25-2010, 11:11 AM   #25
fliz
Member#: 30342
Sadly, the human eye has not evolved in 20 years.
But there is a technological solution, it involves lasers.
KGVR4: Likely the test at your DMV is out of calibration. You should have asked when they last had it tested/refocused.
fliz is offline   Reply With Quote
MA driver's license renewal question vision.dynamix New England Impreza Club Forum -- NESIC 40 12-01-2009 02:18 AM
Testing for my 3rd Degree tomorrow night. Any last minute OT MA advice? Yoo Shin Off-Topic 16 11-09-2006 04:20 PM
Can anyone do a compression test for my STI in ILLNOIS hilfiger4you Mid West Subaru Owners Club Forum -- MWSOC 7 12-25-2005 08:42 PM
Drivers's license renewal question Schris22 Texas Impreza Club Forum -- TXIC 11 08-06-2004 02:35 PM
Washed my car today for the first time in about 3 months fellfrosch7 Member's Car Gallery 4 10-12-2001 04:36 PM
