Old 03-25-2010, 06:34 PM   #1
Chris_Lee
Member#: 110667
2006 WRX
Default Welding references
I'm just posting some basic reference material. When I figure out how to post a pdf I will. Until then...
Having a basic understanding various types of welded joints will help you select materials and assist you in developing your design. Below is a link to Welded Joint Design MIL-STD-22 that will help you visualize different types of joints and how to construct them. Also there are a couple of weld symbol charts to help you sort out which weld to use when you are sketching out your design.
Basic rule for sizing fillet welds is fillet welds can only be as thick as your thinnest member. Meaning generally when you have a corner joint or a T joint coming together where one leg is .25 and the other leg is .125 your weld can be no bigger than .125. I think the reasons for this are pretty obvious some times you may want to build up a welded joint and that is something different all together.
This is a link to Welded Joint design. It does deal with some pretty thick material that most people will probably never use but it a great aid in visualizing what it is you need to do.
http://www.everyspec.com/MIL-STD/MIL...22D.005107.PDF
The charts I have are a little blurry. I will try to find some better ones.
Websites that provide useful information:
Welding tips and tricks- Awesome website packed with practical info.
http://www.weldingtipsandtricks.com/
American Welding Society (AWS)- What can you say, it's a society.
http://www.aws.org/w/a/
Chris_Lee is offline   Reply With Quote
Old 03-26-2010, 07:29 PM   #2
FourOnTheFloor65
Member#: 106225
02 WRX STied PSM
03 L, 05 GT Legacy Wagons
This has to be one of the best sites around for all kinds of welding info. I am on here every couple of days reading stuff. There are also a lot of good videos.
FourOnTheFloor65 is offline   Reply With Quote
Old 04-01-2010, 09:50 PM   #3
KillerBMotorsport
Member#: 198281
2005 WRX/STi
WRB of course
Good stuff here too...
KillerBMotorsport is offline   Reply With Quote
Hey OT let's have MOAR penis talk or reference I25's junk daily. Lucky Loser Off-Topic 47 06-04-2010 06:29 PM
FS: Infinty reference 12, Reference 1300a amplifier, Amplifier wiring kit, and more!! abqkid Interior/Dressup/Audio & Security 12 11-18-2008 12:17 PM
Aluminum Welding Shop/Personal Reference zeekz Texas Impreza Club Forum -- TXIC 6 04-23-2008 11:58 PM
WRX Center diff welded or not welded. joshuagore Private 'Wanted' Classifieds 0 04-19-2005 05:11 PM
Chop chop cut cut weld weld LOUD mexicanpizza Bay Area Impreza Club Forum -- BAIC 4 08-22-2002 02:59 PM
