Old 03-25-2010, 06:51 PM   #1
Chris_Lee
Member#: 110667
2006 WRX
Default Fasteners, washers, split locks, thru holes and drill bit sizes
This is a chart I use at work all the time. It provides you with dimensions for screws, nuts, washers, and split locks. It also helps you size thru holes and countersunk holes. (I will re-size this and post a better copy.)
Here are all your basic drill bit sizes:
And for those that hate to do math:
This is the most useful conversion app I've ever used. Download it and never screw up a conversion again. It's free.
http://joshmadison.com/software/convert-for-windows/
Chris_Lee is offline   Reply With Quote
Old 03-26-2010, 08:36 AM   #2
WC LATHE WERKS
Member#: 175549
Buy my SHIFTKNOBS
www.LatheWerks.com
I also use www.McMaster.com
You can search for and select the exact type of hardware you need, and the final product page lists all the part dimensions for it.
WC LATHE WERKS is offline   Reply With Quote
Old 03-26-2010, 04:05 PM   #3
iluvdrt
Member#: 46248
82 Brat
Tan
We have MCmaster at work too (lots of conduit and electrical stuff), they have everything. Good source.
The convert doesn't have the conversion for electricity. (watts, volts, amps, etc)
Not that I need it (that formula is programed in now LOL) but it is a basic fundamental conversion for a lot of people.
iluvdrt is offline   Reply With Quote
Old 04-01-2010, 05:32 PM   #4
09rexwagon
Member#: 216135
2011 Civic SI
STX #66, 06 S2000 STR 180
What about a list of common Subaru fasteners along with head sizes. I think Subaru uses JIS standards so the pitches are not always the same as UNF and UNC:
Head Size X pitch
10mm M6x1
12mm M8x1.25
14mm M10x1.25*
17mm M12x1.25
17mm MXXxXXX (oil pan plug)
19mm M12x1.25 (lugnuts)
19mm M14x1.5
*though some may be M10x1.5....studs in rear diff are coarser on the thread that goes into the diff I think
Please add to and/or correct me and I'll update it for other people's reference.
09rexwagon is offline   Reply With Quote
Old 04-01-2010, 05:57 PM   #5
Chris_Lee
Member#: 110667
2006 WRX
I didn't do that because I figured for new fabrication work there would be more options for standard hardware. I know the metric is out there but for new work I would just use standard fasteners. You'll find more options locally and people are more likely to have standard drill bits.
Old 04-01-2010, 11:26 PM   #6
DrSaabaru
Member#: 183225
2005 Saab 9-2x Aero
DrSaabaru is offline   Reply With Quote
Old 04-01-2010, 11:34 PM   #7
DrSaabaru
Member#: 183225
2005 Saab 9-2x Aero
These tables are useful for matching up JIS fasteners with their metric equivalents:
http://www.boltdepot.com/fastener-in...Head-Size.aspx
http://www.boltdepot.com/fastener-in...ead-Pitch.aspx
Drill bit size for WRX sideskirt install?? Dizzuque Interior & Exterior Modification 9 11-15-2007 10:51 PM
What size drill bits should I use? Dragonbreak Interior & Exterior Modification 2 09-16-2007 11:38 AM
1/8-28 NPT Tap and Drill Bit my04sti Engine/Power/Exhaust 0 08-07-2006 04:31 PM
ouch... this dude fell from a ladder and landed face first on a 1.5" wide drill bit! Wagon Joe Off-Topic 7 09-03-2003 03:35 PM
drilling holes and no rust t.rod Car Audio, Video & Security 5 03-12-2001 12:12 AM
