Old 06-02-2002, 12:23 PM   #1
Avenger
Member#: 1234
Question Exhaust question
Will a new age WRX mid pipe and muffler fit on a GC8? I've done a search and it seems really sketchy. From what I could found is that one of the hanger on the mid pipe is off. Will the flange fitting the cat fit and how about the length?
Thanks.
Avenger is offline   Reply With Quote
Old 06-02-2002, 02:01 PM   #2
Boostup!
Member#: 552
SOHC RS-Turbo EJ257
Tec-2 Aquamist 2D
No it will not fit directly. The hanger on the mid pipe is ok, it's the hanger right before the muffler that is wrong. The flange to the cat section is clocked wrong too.
The good part is that all the piping has the correct bends in them and will fit nicely. All you have to do is modify the front flange and rear hanger. The only thing I can't remember is if the lenght is correct, where your cat ends and where the wrx mid pipe starts. Somebody else here should know.
Boostup! is offline   Reply With Quote
Old 06-02-2002, 02:33 PM   #3
Avenger
Member#: 1234
This mid pipe looks a bit weird. The flange that connects to the cat is different from the GC8. I think this is the flange the connects to the cat.
Old 06-02-2002, 02:34 PM   #4
Avenger
Member#: 1234
Does this pipe look right?
Old 06-02-2002, 03:32 PM   #5
christoph1371
Member#: 1090
it looks DEAD
christoph1371 is offline   Reply With Quote
Old 06-02-2002, 08:07 PM   #6
Boostup!
Member#: 552
SOHC RS-Turbo EJ257
Tec-2 Aquamist 2D
Actually, the flange looks normal. The flared part is for the donut gasket that allows for flexing at the joint. Your RS has exactly the same thing except the flared part is built into the flange. In your picture, the flare is seperate from the flange. The two flanges do not mate/touch each other anyway, they are held together by two spring loaded bolts. The donut is what seals the system.
I think you'll be alright if you can find somebody to do some minor cutting and re-welding.
Old 06-03-2002, 10:31 PM   #7
Avenger
Member#: 1234
Update: Tried to put the wrx mid pipe and exhaust on and the mid pipe was 2 inches shorter than stock and the muffler hanger was facing the wrong way. I'm going to cut the mid pipe and extend it and turn the hanger around.
Edit: The mid pipe was a 2.75 inch custom pipe so the flange that fits onto the stock cat doesn't fit too.
08 STI exhaust on 08 WRX Exhaust Questions J-Rod 555 Newbies & FAQs 6 06-08-2009 03:58 PM
Exhaust Question for a QUIET Exhaust.. The Blue Pilot Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 29 01-19-2008 11:54 PM
Full OBX Exhaust? General exhaust questions. stoney98 Normally Aspirated Powertrain 12 06-18-2007 11:39 AM
Aftermarket exhaust question. The older the exhaust gets, the raspier? 2005wrbluesti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 4 12-12-2006 10:16 PM
Aftermarket exhaust question. The older the exhaust gets, the raspier? 2005wrbluesti Normally Aspirated with bolt-on Forced Induction Powertrain 0 12-12-2006 03:52 PM
