Old 03-26-2010, 01:09 PM   #1
neversummer489
Member#: 153729
PSM Bugeye
Missing rod bearing??
Default Post your custom intake manifold
I was looking at the "post your beads" thread here and saw a couple of custome (one off?) intake manis. Any info on the gains of the manifolds would be cool too.
neversummer489 is offline   Reply With Quote
Old 03-30-2010, 02:41 PM   #2
PrecisionCustom
Member#: 207830
2002 Precision Built
Just a quickieee for ya
PrecisionCustom is offline   Reply With Quote
Old 04-01-2010, 08:09 PM   #3
79tranny
Member#: 209661
JDM RHDswappedWRX
2012 Dodge Ram-daily
i noticed those pictures too, on post your beads..
I have lots of questions about why and how this is done.. I'm nowhere near a good enough welder to do it... but I'm definitely gonna keep an eye out and watch this thread grow
79tranny is offline   Reply With Quote
Old 04-01-2010, 09:18 PM   #4
scubydrew
Member#: 32609
2005 saab 9-2x
rhd ej20tt sold...
PrecisionCustom... that looks nice! you got anymore pics?
scubydrew is offline   Reply With Quote
Old 04-02-2010, 09:25 AM   #5
Patrick Olsen
Member#: 120
1997 Legacy 2.5GT
QuickSilver Metallic
There are a bunch of fabricated intake manifolds (some from tuner shops, some from "amateurs") in this thread. Can definitely give you some ideas.
Old 04-05-2010, 09:39 PM   #6
neversummer489
Member#: 153729
PSM Bugeye
Sweet thanks
Old 04-05-2010, 10:04 PM   #7
PrecisionCustom
Member#: 207830
Ill post some tomorrow. I have made about 10 of these in my day. Each for subbys. All have seen 20-38psi and never failed. Had some issues at first with cylinders running to lean, but have further fixed the problem. If you got questions about this setup Pm me and I can help ya out.
Old 04-06-2010, 01:49 AM   #8
neversummer489
Member#: 153729
PSM Bugeye
I'm looking foreward to seeing this
Old 04-07-2010, 10:47 PM   #9
sackytar
Member#: 149262
03WR Rally/XTDD/98SJ
PrimerGrey
P custom. I want to see the final product looks good.
sackytar is offline   Reply With Quote
Old 04-08-2010, 02:59 PM   #10
scubydrew
Member#: 32609
2005 saab 9-2x
rhd ej20tt sold...
I know many of you seen this manifold already but here's a bit more in depth of how it all went down. Enjoy!
Old 04-08-2010, 11:39 PM   #11
scarless ronin
Member#: 212434
2000 Imreza RS
Dark Red
what kind of gains are you seeing with that kind of intake manifold scubydrew?
scarless ronin is offline   Reply With Quote
Old 04-09-2010, 06:01 PM   #12
scubydrew
Member#: 32609
2005 saab 9-2x
rhd ej20tt sold...
I'm not sure the exact number but I wanna say it was between 15 and 20 wheel horsepower. Call the shop they have record of that kinda stuff. I just make the parts. lol
Old 04-09-2010, 06:36 PM   #13
Kenji815
Member#: 65623
2005 05 Varis WRX
95 LS400
very pretty manifold..
Kenji815 is offline   Reply With Quote
Old 04-09-2010, 10:24 PM   #14
scarless ronin
Member#: 212434
2000 Imreza RS
Dark Red
I probably couldn't afford the thing anyway, just curious if you knew
Old 04-11-2010, 01:32 PM   #15
sackytar
Member#: 149262
PrimerGrey
P custom. What are the costs associated with you setups???
Old 04-13-2010, 06:44 AM   #16
jzk25
Member#: 179120
I fiddle about with manifolds a bit just for welding practice. Made this for an EJ25/35R we built. A friend had built one similiar using round tube that flowed well but was very complex and had a heap of welds so i though I'd do one out of box so there would be limited welds, greater strength and a bit more volume. The runners are early EJ25 quadcam which are basically straighter versions of early EJ20G runners. I never had it flow tested due to time constraints, would have been interesting to compare.
The main reason I do the manifolds is to reposition the throttle body to the front. The main reason for this is to free up room at the rear for bigger turbos as in RHD cars we are struggling for space.
jzk25 is offline   Reply With Quote
Old 04-13-2010, 09:26 AM   #17
submaster08
Member#: 218016
2002 subaru WRX
white
looks real nice man
submaster08 is offline   Reply With Quote
Old 05-01-2010, 06:43 PM   #18
jzk25
Member#: 179120
EZ30D manifold modified for an EZ30R turbo. Had heaps of trouble with the cast when welding it, couldn't get it clean. Any pros know how to prepare castings for welding?
For this, not fitted yet because the owner is a slackass.
Old 05-01-2010, 07:29 PM   #19
timeXlost
Member#: 113924
2005 STI....SOLD!
93 RX7...Not Broken
Is that a ford iac?
timeXlost is offline   Reply With Quote
Old 05-01-2010, 10:32 PM   #20
jzk25
Member#: 179120
It's a ford throttle body from an Australian Ford Falcon 4l six. They are cheap and have built in 2 wire IAC so we often use them.
Old 05-02-2010, 07:31 AM   #21
SKC
Member#: 15250
Have a chat to the guys at HPC at Brendale. If they can get the oil and containments out of a casting well enough to ceramic coat, it should be fine to weld.
SK
SKC is offline   Reply With Quote
Old 05-03-2010, 02:43 PM   #22
FourOnTheFloor65
Member#: 106225
02 WRX STied PSM
03 L, 05 GT Legacy Wagons
Do cleaning passes with the welder. Set your amps just high enough to melt the surface of the metal and set the cleaning percent fairly high. Just go over all the edges where you are going to weld. Let the surface get molten, and watch the crud float to the top and edges of the puddle. Then go over it with a carbide burr or something to clean all the crud off. Then do another pass or two until you don't see as much crud in the puddle. After the last pass just wire brush it very well and clean it with acetone, don't use the carbide burr. It will weld 100 times better.
If the casting has a lot of oil in it you can heat it up first to burn off all the oil. A random old oven works well. Crank the thing to 375*F or so and put the casting in there for 15min to an hour depending on how thick it is. Don't use the oven you bake cookies and what not in. At least I wouldn't do it. I don't like the taste of 10W30 in my chocolate chips. You can also use a torch to do the same thing but be careful not to overheat it. I'd use a temperature indicating marker or something.
FourOnTheFloor65 is offline   Reply With Quote
Old 05-03-2010, 03:26 PM   #23
PrecisionCustom
Member#: 207830
^ I second the above operation
Old 05-03-2010, 03:55 PM   #24
Storm
Member#: 5218
96L Most Over-
Developed Beater
I was gonna ask how well the cast bits welded to the sheet aluminum.....I've got some pieces parts layin around that could be fabbed up into something cool. For now I'll just whore out the oft-used pic of the Irish Mike's manifold on our 98RS.
If my memory serves, it's 3.5l in volume and uses runners grafted from an Benz SL something or other....
Jay Storm
Old 05-03-2010, 06:13 PM   #25
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
beautiful work everyone.. It's very interesting to see the amount of originality floating around.. very refreshing to see.
jigga is offline   Reply With Quote
Roller Barrel ITBs and Custom Intake Manifold Design wgknestrick Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 277 10-11-2010 08:06 AM
Post your custom intake heat shields sc00ter Interior & Exterior Modification 10 01-19-2010 11:42 PM
Custom Intake Manifolds??? schvanos Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 13 10-15-2005 09:52 PM
Custom Intake Manifold (gauging interest) Tattoo Collector Normally Aspirated Powertrain 37 02-10-2003 06:49 PM
Custom Intake Manifold N/A01RS Normally Aspirated Powertrain 2 08-22-2002 05:05 AM
