Old 03-27-2010, 04:16 PM   #1
MagikMuzik
Member#: 223968
2008 STi
Lightning Red
Have a Nice Day? Cobb AP not resetting engine code 08 STI
Hey everyone just got my cobb AP and I tried to reset the check engine light, I read the code first it said it was the speed sensor, I then went to reset the ecu. It said to leave key off for about 10secs, I waited more like 30. Restarted the car, and its still there. Am I doing something wrong? Any imput is appreciated thanks
MagikMuzik is offline   Reply With Quote
Old 03-28-2010, 01:25 PM   #2
van_dutch
Member#: 198633
2004 WRX
Have you tried figuring out why it came on in the first place?
van_dutch is offline   Reply With Quote
Old 03-28-2010, 03:06 PM   #3
MagikMuzik
Member#: 223968
2008 STi
Lightning Red
well it came on after me and a friend changed my driver side front wheel bearing hub.
Old 03-28-2010, 06:55 PM   #4
van_dutch
Member#: 198633
2004 WRX
What is the code? Have you tried trouble shooting it?
Old 03-28-2010, 07:36 PM   #5
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
It came back on because you didnt fix the problem...
rexworx is offline   Reply With Quote
Old 03-28-2010, 07:56 PM   #6
MagikMuzik
Member#: 223968
2008 STi
Lightning Red
My Access port said "P0502 - Vehicle Speed Sensor" im not 100% sure what went wrong after changing the wheel bearing, cus this sensor is tranny related. so maybe a fuse or wire or something? im not sure how to fix it and id rather fix myself and not go to the dealership unless I really have to, so any tips are appriciated!
Old 03-28-2010, 08:08 PM   #7
rexworx
Member#: 103232
I think in 07 or 08 suabru took the sensor out of the 6spd and run it on the knuckle???
Old 03-30-2010, 12:46 AM   #8
Frank A
Member#: 49979
11 dgm wrx hatch
08 black TA STI
you prolly broke the wheel speed sensor. Don't feel bad, its not that hard to do (and not too hard to replace, either). If you're lucky, you just removed it and forgot to reinstall it, but I imagine if you did that, you'd be telling us already.
Frank A is offline   Reply With Quote
Old 04-02-2010, 11:31 AM   #9
Lboogie
Member#: 171611
2014 FiST
Blk
x2 on the sensor not being correctly plugged back in @ the hub (hopefully not broken!). it happened to me last weekend on my buddies A3, I was being too gentle with his ABS sensor plug and it didn't 'snap' together enough.
Lboogie is offline   Reply With Quote
Old 04-02-2010, 11:39 AM   #10
Mavrik
Member#: 90347
2013 BRZ & Imp 2.5RS
Yamaha FZ8
also if its a speed sensor code, its being stored in the abs module, the AP does not clear those codes.
Mavrik is offline   Reply With Quote
AP not reading CEL codes car_cursed AccessPort 10 06-11-2009 09:31 PM
Cobb AP ECU reset mostasz AccessPort 2 06-01-2008 09:45 PM
Will a cobb ap not work with my cold air intake? 02dubRX AccessPort 8 10-03-2006 02:32 PM
CEL but AP says no engine codes subietech420 Engine Management & Tuning 1 05-30-2006 05:34 PM
AP not reading cel codes correctly? dankster AccessPort 4 05-21-2006 03:41 PM
