Old 03-28-2010, 06:12 PM   #1
Viperguy324
Member#: 121108
2006 06 Spec C
Default Window bypass mod?
Yea.. so no door cards in the car.. Planned on driving with only the driver side switch connected. Anyone figured out how to Pin up the other connectors to bypass the switches?
Viperguy324 is offline   Reply With Quote
Old 03-28-2010, 06:45 PM   #2
MasterKwan
Member#: 98961
2003 WRX
You want one switch to activate all the windows? The switches themselves are brain-dead. They hook up voltage one polarity to raise the window and reverse the polarity to lower them. It would be pretty easy to hook up a single switch to raise and lower all the windows simultaneously. You just need a strong enough power source.
Old 03-28-2010, 07:04 PM   #3
Viperguy324
Member#: 121108
2006 06 Spec C
I want to use the stock drivers side switch to run the others with them having the switches installed. Not all at once ..rears can be dead.
Old 03-28-2010, 07:16 PM   #4
MasterKwan
Member#: 98961
2003 WRX
I'd check out the BL/RL wires going into the front passenger side switch connector with a meter. If they're 12 volts and the polarity reverses when you go up and down on the drivers side switch, I'd cut the connector out and attach the wires to the motor directly (LR/L).
You have to experiment with the polarity. Get it wrong and up will be down and down up. I didn't look at the back door wiring. It would be similiar though. Maybe different colors.
Old 03-28-2010, 07:28 PM   #5
Viperguy324
Member#: 121108
2006 06 Spec C
Yeah thats what is throwing my off on the diagram.. colors are wrong.
2 wires are hot ...Y and LG .. making the driver side work is easy..getting the passenger side is not.
Old 03-28-2010, 07:57 PM   #6
MasterKwan
Member#: 98961
2003 WRX
On the passenger side, you want wires that are only hot when the drivers side switch is pressed up or down. The constant hots won't be used. There's not that many wires. 2 constant hots are unused, 2 wires to the motor. The 2 remaining wires are the ones you use.
The 06's are different though. There's a relay looking thing that almost looks like it's used for putting all the windows down at once. I might wire around that and wire the system like the '05's.
Old 03-28-2010, 08:01 PM   #7
Viperguy324
Member#: 121108
2006 06 Spec C
Ok... I may have found the issue. The wires that I found hot are for the door locks... so nothing is hot on the window side. Looking into the relay...and CB
Old 03-28-2010, 08:19 PM   #8
MasterKwan
Member#: 98961
2003 WRX
Master window switch?
Old 03-28-2010, 08:37 PM   #9
Viperguy324
Member#: 121108
2006 06 Spec C
Yes master window switch.. anyhow
Problem solved.
Passenger side Pins 4 to 7 and 5 to 6 bypasses the switch
You now have control of the passenger window.. without the switch.
Oh and the relay was labeled wrong on my 06...
Old 03-28-2010, 08:41 PM   #10
Viperguy324
Member#: 121108
2006 06 Spec C
Thanks for the help!
Throttle Coolant Bypass Mod NavyBlueSubaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 01-15-2013 01:58 PM
HELP! Power window bypass. pom Newbies & FAQs 7 10-26-2008 09:50 AM
Boost solenoid bypass mod luck? Lightsped Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 11-20-2002 10:56 AM
Did the TB bypass mod today ImpreziveRS Normally Aspirated Powertrain 15 09-22-2002 09:56 PM
Just did the TB bypass mod... IggDawg Normally Aspirated Powertrain 46 09-19-2002 10:00 AM
