#1 |
Member#: 5692
Vehicle:WTF? YES! I am better than you! |
First off...I did a search and got no hits.
Now, does anyone know of any web sights that detail the install process so I can see how much work it is before I order? Thanks, Tats.
#2 |
Member#: 5778
South East
Vehicle:09 135i Jet Black |
I want to say the larry has the instructions for the JC sports kit on his site... they should be really close.... if need be call tom and ask him. he has good CS/support skills
Brad |
#3 |
Member#: 1990
Well I have done three LudeSpeed Turbo Installs so far and as long as you have every part you need, then things will run very smoothly. One thing I will highly recommend of engine management. Personally I have installed the Link Plus in every car I have installed the Ludespeed kit on. This makes getting the car up and running a million times faster.
I would allow two full days to install everything, this will allow, runs to the store for tools or whatever and fixing all those tiny little details you want just right. As for the directions, the first time I went through them, they were pretty clear and informative. As for a link, www.ludespeed.com. E-mail for the directions if you are really interested. |
#4 |
Member#: 1994
give me about 30 seconds, and I'll post the PDF I have so you can check it out. Mind you, the version I have is prolly a little different than the kit you'll get, but the gist of it is the same.
[EDIT] Server problems, so it'll take a bit longer. Nick (8Complex) might still have them online. |
#5 |
Moderator Member#: 922
Vehicle:04 FXT Red |
My site went down, so I don't have them online any more. Will search the home machine when I get back there to see if it's archived on one of my drives.
#6 |
Member#: 1994
#7 |
Member#: 5692
Thanks alot! I will be using the Pro ECM chip from imprezarc.com though.
Tats. |
#8 |
Member#: 8533
Vehicle:2002 2.5 RS-T LudeSpeed S. III W/ FMIC |
Hey Jewbaru,
That file isn't there anymore. I was hoping to get a copy of the install instructions. Do you think you could update the link? Thanks, Jared. |
#9 |
over boosted again
Moderator Member#: 1458
RMIC
Vehicle:2006 B9 Tribeca LTD 2005 Impreza 2.5 RS |
I think the instructions posted for download on my site for the kits we sell and those for ludespeed will differ in a few places.
Their oil pan is different, their turbo is only oil cooled and ours is oil and water cooled, they use a garrett with external wastegate and we use IHI RHB52, VF22, VF30 as the options with internal wastegates, and they use a catch can and we use a vacuum chamber where the PCV valve was. Larry www.SubaruPlanet.com/turbosale.htm |
#10 |
Member#: 94
Vehicle:1999 2.5 RS-T RBP EJ257 Hybrid Link'd |
I though the Ludepeed Garrett's were water cooled as well?
At least thats what it says their website: http://ludespeed.com/products/subaru...ts/stage1.html |
#11 | |
Member#: 1994
#12 |
over boosted again
RMIC
I take that back then, they have been upgraded since I last logged onto their site.
#13 |
LudeSpeed kits were actually never non-water cooled turbos.
I'll see if i can dig up the PDF at home and get it posted up somewhere (install instructions). |
#14 |
Member#: 1994
my link should work. I re-uploaded 'em.
#15 |
Member#: 8533
Thanks Jewbaru
#16 | |
over boosted again
RMIC
#17 |
Member#: 2301
NWIC
I thought the T3/T4 has the ability to be watercooled. Has all the fittings and stuff for it doesn't it?
#18 |
Member#: 1838
NWIC
Vehicle:2000 Impreza RS BRP Vishnu Turbo/Tec3 |
Any turbo can be water cooled if it has the water cooled center section.
#19 | |
Street Racing Instructor
Moderator Member#: 110
Vehicle:1989 1989 XT6 |
| Thread Tools | |
| Display Modes | |
| Installing and Removing a Ludespeed Turbo | Kevin Thomas | Normally Aspirated with bolt-on Forced Induction Powertrain | 8 | 11-11-2003 06:09 PM |
| HELP with my Ludespeed Turbo Install (Engine won't turn) | george | Normally Aspirated with bolt-on Forced Induction Powertrain | 13 | 09-08-2003 08:24 PM |
| Anybody install a ludespeed turbo kit? | agent007kimball | Normally Aspirated with bolt-on Forced Induction Powertrain | 6 | 02-06-2002 04:44 PM |
| Ludespeed Turbo Kit Installed | Xscreamer | Factory 2.0L Turbo Powertrain | 13 | 05-31-2001 08:30 AM |
| Who actually has the Ludespeed turbo installed? | GregBolby | General Forum Archive | 6 | 01-18-2001 04:49 PM |
