Old 03-28-2010, 10:58 PM   #1
im2ninja4u
Member#: 183389
Default Computer not detecting accessport?
When I plug in the accessport to my computer the accessport turns on fine, but it won't allow itself to be detected by my computer. It's weird because it worked when I did the firmware upgrade, everything was detected and updated fine, then when I try to install race tuner and it asks me to plug in my accessport, it won't detect it. I can't even update the accessport anymore because of detection problems. I tried switching out USB cables, that didn't help, is it broken? If it matters, I'm running on windows 7 64 bit.
im2ninja4u is offline   Reply With Quote
Old 03-29-2010, 12:13 AM   #2
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
call cobb best advice
ProdriveDreams is offline   Reply With Quote
Old 03-29-2010, 12:28 AM   #3
im2ninja4u
Member#: 183389
Giving them a call in the morning.
Old 03-29-2010, 11:26 AM   #4
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
Does the screen turn on if you plug it into your car?
rexworx is offline   Reply With Quote
Old 03-29-2010, 12:41 PM   #5
im2ninja4u
Member#: 183389
Yah, when I plug it into the obd port or a usb port, the screen comes on fine, I just have a problem with the computer detecting the accessport. As far as I know, the drivers are up to date, and the firmware is the lastest one. The access update doesn't detect it, the access manager doesn't detect it, and the race tuner doesn't detect it, and I don't get the prompt that says there's something plugged in the USB port.
Old 03-29-2010, 08:40 PM   #6
gregbenoit
Member#: 156545
2007 WRX STi
UGM
I'm having the same problem but my screen won't turn on...
gregbenoit is offline   Reply With Quote
Old 04-02-2010, 02:50 PM   #7
andysf
Member#: 67926
2004 Impreza STi
Did you ever have it working with Windows 7? I couldn't get mine to connect on my Windows 7 VM, so I used another laptop with Vista and it worked fine.
andysf is offline   Reply With Quote
Old 04-02-2010, 03:10 PM   #8
bsikora
Member#: 125573
2006 2.5i
ProTune by Sean S.
i had the same problem with my desktop. then i switched it to my laptop with windows xp home and it worked fine.
bsikora is offline   Reply With Quote
Old 04-08-2010, 03:55 PM   #9
im2ninja4u
Member#: 183389
Nope didn't work. I already sent it in to Cobb to look at. I plugged it into my desktop that's running windows 7 x64, and my laptop that was running windws 7 x32, and my other desktop that was running windows xp sp3, and my other desktop that was running windows vista x64.
Old 04-14-2010, 10:56 PM   #10
codean
Member#: 10186
bought a new laptop with windows 7... can't get an older version of accesstuner race to install due to "Error: could not load communications module"
codean is offline   Reply With Quote
Old 04-15-2010, 04:33 PM   #11
im2ninja4u
Member#: 183389
Call Cobb, they're pretty good about trouble shooting. I sent mine in last week, and hopefully I'll have it today so I can get tuned.
Old 04-15-2010, 06:30 PM   #12
codean
Member#: 10186
Yeah, the issue is its for an evo 8 and they don't want to support it anymore.
Old 05-20-2010, 12:58 AM   #13
im2ninja4u
Member#: 183389
Well, after a little over a month, I finally got my AP back. Don't know if the car will detect it yet, because it's at yimisport, but I'll find out in a few weeks. My PC detects it now and I'm able to pull my logs which are useless now, but hey, it's a good start.
Asus G60 will not detect wireless network. Need fix ASAP camshaftprelube Off-Topic 18 02-20-2010 01:56 PM
V1 not detecting speed sign hybrid gti 2 Electrical & Lighting 8 11-21-2008 06:58 PM
Can HEAR pings, but knocks not detected stanton Engine Management & Tuning 25 09-21-2006 02:19 PM
ej257 hybrid knocking not detected by ecu NITROS UTEC 41 09-02-2006 10:34 AM
Fuel computer not cycling between lean and rich dead-eye Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 0 04-18-2001 03:45 PM
