Old 06-02-2002, 09:46 PM   #1
adamsrs
Member#: 3768
Question ANOTHER Fuel Pressure Question!
I have a few questions actually:
-where did you place your fuel pressure sensor?
-if it is before your injectors, what is your idle pressure?
-if it is AFTER your injectors, what is your idle pressure?
-What are your idle EGT temps?
-What are your WOT EGT temps?
-What FPR are you running?
-What injectors are you using?
THANKS!
adamsrs
adamsrs is offline   Reply With Quote
Old 06-03-2002, 02:19 AM   #2
Delicious Tuning
Member#: 1990
Before the injectors, idle fuel pressure under vacuum is 34 PSI. EGT's are around 700 to 750. This is after it has been sitting idle for a while.
To many variables IMHO, to place the Fuel Pressure Sensor after the injectors.
Delicious Tuning is offline   Reply With Quote
Old 06-03-2002, 02:29 AM   #3
adamsrs
Member#: 3768
What FPR are you running? and what injectors and WOT EGTs too please!
adamsrs
Old 06-03-2002, 12:20 PM   #4
Delicious Tuning
Member#: 1990
Walbro Fuel Pump
With the Link Plus you can use the STOCK FPR or an upgraded one doesn't matter.
RC Eng 440cc injectors, high impedance
EGT's at WOT shouldn't be more then 1500
EGT's Cruising on the highway are around 1200 to 1300
yep- another boost pressure question.... dux10 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 01-26-2010 11:49 AM
Another oil pressure question. . . . fishheadback Pre-2002 Factory Turbo Powertrain 5 11-16-2008 06:09 PM
another tire pressure question dan avoN7 Tire & Wheel 0 11-23-2003 05:08 PM
Fuel Pressure questions... Delicious Tuning Normally Aspirated with bolt-on Forced Induction Powertrain 12 07-26-2001 04:41 AM
turbo fuel pressure questions bttune2.5rs Normally Aspirated Powertrain 5 03-01-2001 12:47 AM
