Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Go Back   NASIOC > NASIOC Classifieds > Private 'For Sale' Classifieds > Complete Car Part-Out
Old 03-29-2010, 06:30 PM   #1
madkayaker
Member Sales Rating: (16)
Member#: 57378
2002 wrx w/ sti swap
04 sti, 11 forester xt
Default 2004 STi with 60k miles to be parted
If you do not get a response from me, then most likely you have asked a stupid question or for a part that is clearly listed as sold on the this first post.
This is a damaged 04 STi bought from an auction. It has Just over 60k miles. Color is psm. It has a salvage/parts only title.
The parts listed below on this post are SOLD or otherwise NOT available:
Body:
Driver side fender
Pass. side fender
Trunk and Wing
Side skirts
Hood scoop
Hood
Hood prop and plastic clip
Pass side tail light
Driver side mirror
Pass. side mirror
Rear Driver side door
Window trim - rear driverside door
Driver side window molding retainer
Headlights
Fender Liners
Brakes:
Front Brembo calipers, rotors, and lines
Rear Brembo calipers
Brake Booster
Brake Master Cylinder
Interior:
Front seats
Rear seats
Door cards w/ handles
Cluster
Carpet
Radio and HVAC trim
Steering wheel with airbag
Arm rest extension
Clock pod
Center console
Map Light
Rear deck
Front seat belts
Rear view mirror
Steering column trim
A/C blower motor assembly
IC sprayer switch
Center A/C vents
Dash cup holder
Side A/C vent trim
Shifter surround
Shifter trim (aluminum piece)
Shift boot
Shift knob
Driveline/suspension:
Cusco front coilovers
Cusco rear coilovers are damaged
Control arms
Rear axles
Transmission
Rear diff
Drive shaft
Right Rear hub w/ abs sensor and e-brake parts
Front Axles
Steering rack
Spare Tire/Wheel
Tires and Wheels
Engine:
Turbo
Power steering pump
Pass outer timing cover
Alternator
Heads w/valves and buckets
Cams
Valve covers
Rods
TurboXS FMIC kit
No TMIC
Fuel injectors
Oil pan
Pick up tube
A/C line - High Pressure
A/C line - low pressure
Engine Harness
TGVs w/sensors and motors
Throttle Body
Fuel rails
Oil Cooler
Bare Block with bolts
Electrical:
Clock spring
Integrated Unit
Chassis Wiring Harness
ECU
DCCD switches
Engine Harness
madkayaker is offline   Reply With Quote
Old 03-29-2010, 06:31 PM   #2
madkayaker
Member#: 57378
Interior:
No trick photography. I tried as best as I could to get photos that accurately represent the parts. They are not coated in armor-all to make them shine or anything like that.
Available:
Passenger airbag
Dash
Dash under steering wheel piece
Dash center cage around radio
Dome light
Glove box (rubber opening stops are broken)
Plastic trim pieces(door seals a,b,c pillar covers, etc)
Rear seat belts
Sun visors
Steering column
http://s1002.photobucket.com/albums/af147/topher170/sti%20part%20out/STI%20interior/
Body: Click the link below for pictures of these items.
Front driver side door
Front pass side door
Rear pass side door (small dent)
Driver side tail light
Cowling below front window
Rear driver side glass
Front pass side glass
Rear pass side glass
http://s1002.photobucket.com/albums/af147/topher170/sti%20part%20out/STI%20body/
Motor:
AVCS Cam gears
Intake manifold
Water pipe
Oil baffle
Motor mounts
Timing covers
http://s1002.photobucket.com/albums/af147/topher170/sti%20part%20out/STI%20motor/
Electrical:
Front airbag sensors
Side airbag sensors
Window motors
Keyless entry unit with key fob
Steering column electrics - let me know what you need and make an offer
http://s1002.photobucket.com/albums/af147/topher170/sti%20part%20out/STI%20electical/
Old 03-29-2010, 08:10 PM   #3
keifun
Member#: 176100
03 Bugeye WRX
interested in the OEM TMIC..
let me know
thanks
keifun is offline   Reply With Quote
Old 03-29-2010, 08:31 PM   #4
Bratman18
Member Sales Rating: (15)
Member#: 214388
2004 6 spd FXTi
Lifted 98 Forester S
let me know
thanks
Looks like it has a front mount in the pic
Bratman18 is offline   Reply With Quote
Old 03-29-2010, 08:56 PM   #5
madkayaker
Member#: 57378
let me know
thanks
no tmic, and unfortunately the fmic is busted.
Old 03-29-2010, 09:38 PM   #6
Mustang Raper
Member Sales Rating: (3)
Member#: 84388
2002 WRX,FPG,6MT
Sedona Red Pearl, Carbon
Interested in the long block if it is running. If that works out I want the dccd controller and ecu too
Mustang Raper is offline   Reply With Quote
Old 03-29-2010, 10:30 PM   #7
madkayaker
Member#: 57378
I have one person interested in the ecu already, but I'll put you next on the list. You are first on the list for the long block. I plan to keep the dccd controller for myself.
Thanks!
Old 03-29-2010, 11:57 PM   #8
GiAANT
Member Sales Rating: (2)
Member#: 184331
2002 EWG vf39'd wrx
Slammed WRB -_-
if you dont mind me asking, how much di you pay for it?
GiAANT is offline   Reply With Quote
Old 03-30-2010, 12:49 AM   #9
weaver808
Member#: 227105
are you willing to ship?
weaver808 is offline   Reply With Quote
Old 03-30-2010, 01:31 AM   #10
esker
Member Sales Rating: (21)
Member#: 179833
2005 16g EVOIII WRX
are you willing to part out the brembos
esker is offline   Reply With Quote
Old 03-30-2010, 05:40 AM   #11
madkayaker
Member#: 57378
There is currently someone interested in the complete set. If it doesn't work out with him, I will consider it.
Thanks!
Old 03-30-2010, 05:41 AM   #12
madkayaker
Member#: 57378
If you're willing to pay for it. I would rather not ship the large items, but I will.
Old 03-30-2010, 05:42 AM   #13
madkayaker
Member#: 57378
Please read the whole post before asking questions. Thank you!
Old 03-30-2010, 12:07 PM   #14
Mxrider346
Member#: 231770
07 Legasexy
I am interested in the Passenger Side Fender and the shifter surround and boot off the console. Please PM me thanks
Mxrider346 is offline   Reply With Quote
Old 03-30-2010, 12:39 PM   #15
nxwrxfx
Member Sales Rating: (82)
Member#: 92011
02 EJ207 STi HTA68
05 EJ257 Baja 18G-XT
I need the STi intercooler spray tank TRUNK LINING from the rear left/passenger side.
PM'd ya!
nxwrxfx is offline   Reply With Quote
Old 03-30-2010, 02:03 PM   #16
madkayaker
Member#: 57378
All pms and emails replied to.
Old 03-30-2010, 02:34 PM   #17
madkayaker
Member#: 57378
More pics. More to come.
Old 03-30-2010, 04:05 PM   #18
topshotta10
Member Sales Rating: (13)
Member#: 70218
2005 WRX sti 20g met
how much for drivers seat, or even better just the base of the drivers seat
topshotta10 is offline   Reply With Quote
Old 03-30-2010, 04:40 PM   #19
FEVOZ
Member Sales Rating: (7)
Member#: 240633
2006 WRX
WRB Fp Green'd !
first on the list for the turbo ! its mine =)
FEVOZ is offline   Reply With Quote
Old 03-30-2010, 05:18 PM   #20
Blinden
Member#: 122993
Ex's WRX
02, 04 Sti, 12 Hatch
are side skirts a 'large item'?
let me know if you would be willing to ship sideskirts to 15601, and what you would want for them.
Blinden is offline   Reply With Quote
Old 03-30-2010, 05:56 PM   #21
Mustang Raper
Member#: 84388
2002 WRX,FPG,6MT
Thanks!
Ok, just keep me informed please!
Old 03-30-2010, 07:28 PM   #22
madkayaker
Member#: 57378
will do
Old 03-30-2010, 07:45 PM   #23
madkayaker
Member#: 57378
I'll ship them. I will inspect the skirts as soon as I get a chance and let you know the condition. I think they have a few chips in the paint here and there from normal use. I will also try to get some detailed pics posted as soon as I have a chance.
I will give you first shot at them.
I would like to get a chance to look everything over before I start giving prices. Please be patient.
Old 03-30-2010, 07:47 PM   #24
340Duster
Member Sales Rating: (10)
Member#: 52314
2002 PSM WRX 16G-XT
Dorothy from OZ, the XT
How much for the wing?
340Duster is offline   Reply With Quote
Old 03-30-2010, 07:54 PM   #25
cruxwrx04
Member Sales Rating: (1)
Member#: 220043
2004 Vf39 Wrx
Psm
price on hood scoop?
cruxwrx04 is offline   Reply With Quote
Used oil analysis: Mobil 1 5w-30 on 2004 STi with 67k miles Bullhonkie Service & Maintenance 4 08-28-2009 11:29 PM
2004 STI with 23k miles for $23k obo 04AWD MAIC Private Classifieds 1 12-29-2008 02:37 AM
2004 STI with 38K miles for under $20K - should I buy it? hype-R-29 General Community 45 10-23-2008 02:12 PM
2004 STi with 11k miles for $18,500?? (question) ezatnova Private Vehicle 'For Sale' Classifieds 13 10-24-2005 05:37 PM
FS: 2004 Sti with 8K miles Sti088 Private Vehicle 'For Sale' Classifieds 2 06-19-2004 08:16 PM
