Old 03-29-2010, 05:53 PM   #1
jsnm
Member#: 186356
2006 WRX-pte6262
CTS-V,& 05 RS
Default cam gear bolt torque?
Anyone know off the top of their head what the torque specs are for the cam gear bolts?thanks
jsnm is offline   Reply With Quote
Old 03-29-2010, 05:58 PM   #2
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
It's torque to angle.
21.8 ft-lbs, then an additional 45 degrees
Old 03-29-2010, 06:01 PM   #3
jsnm
Member#: 186356
2006 WRX-pte6262
CTS-V,& 05 RS
ok,so its for the front 10mm allen key bolt right?
i just thought it was alot more than that.
Old 03-29-2010, 06:35 PM   #4
Wagonkenny
Member#: 181897
2003 red s2000
98 200sx SE-R black
Works out to be about 72 ft lbs.
Wagonkenny is offline   Reply With Quote
Old 03-29-2010, 06:35 PM   #5
jsnm
Member#: 186356
2006 WRX-pte6262
CTS-V,& 05 RS
Awesome thanks guys
Old 03-30-2010, 05:36 PM   #6
ihadmail
Member#: 159315
2009 Cadillac CTS-V
Yep. My 02 WRX manual says 72 or 73 pounds. My 05 STi manual says 21.8 then an additional 45 degrees.
ihadmail is offline   Reply With Quote
Old 03-31-2010, 01:04 AM   #7
morrocco88
Member#: 104098
97' LGT 2.3 Dstroke
Rotated BW S256 6speed
I was told by an engine builder to put a tiny amount of anti-sieze on the flange of the bolt head, that contacts the face of the cam gear. That makes it easy to break it free when you want to take them off. We all know how hard it is to break these loose.
I did it on my cam bolts and torqued them to 60 ft lbs. All I had was the torque to angle spec in the manual and the builder said he has torqued them all to 55 ft. lbs for years and has never had one come loose, so I just added 5ft lbs to that.
Food for thought
morrocco88 is offline   Reply With Quote
Old 03-31-2010, 07:34 AM   #8
jsnm
Member#: 186356
2006 WRX-pte6262
CTS-V,& 05 RS
thats actually a really good idea.i didnt even think of that.
i got a set of the cam gear tools from AMS,makes taking them off and tightening them simple.
Old 04-07-2010, 12:49 PM   #9
AMS
Member#: 27854
STI, WRX, GTR, EVO,
BMW, Porsche, + More!
Glad they worked well for you! They really make it much easier to break those stubborn bolts loose.
AMS is offline   Reply With Quote
Old 07-30-2014, 07:48 PM   #10
Kilbahlmoon
Member#: 395891
I have the NA version and haynes say's 55 - 61 ft lbs so i did 58 and worked great, I bought a sprocket tool from industry 23 I believe and it worked great. but then again It did'nt have the dreaded allen bolts either.
Kilbahlmoon is offline   Reply With Quote
cam gear bolts, crank bolt stuck boosted lego Transmission (AT/MT) & Driveline 16 04-13-2011 10:11 PM
Crank pulley bolt/Cam gear bolt Starkiller Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-17-2007 01:55 PM
intake cam gear bolt part no.?? deluxsti Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 0 09-05-2005 04:07 PM
need help with cam gear bolt attitude Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 17 01-07-2005 06:22 PM
Cam gear bolts always a pita kaos200 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 06-13-2004 07:58 AM
