Old 03-30-2010, 09:17 AM   #1
jc8587
Member#: 76201
1990 Spec Miata
TMPR.net
Default Did my alignment eat my tires?
Hello NASIOC,
I just got back from a weekend at Putnam Park with 100-speed lapping days and looked at my tires (235-40-17 RA-1s) and noticed one of them is beginning to cord on the inside of the tire.
This leads me to beleive a few things:
1) As these were used tires when I bought them, they were already thin on that inside point.
2) Putnam is always harsh on the front left, but as I didnt mark these tires when I took them off, I have no clue what side the tires came from (STUPID STUPID STUPID)
3) My alignment is so far off it is eating tires? :
Front Camber: -4.2*
Front Caster: 3.8*
Front toe: 0.2* Out
Rear Camber: -3*
Rear Toe: 0*
4) I overheated the tires and the result is money down the drain?
Please only helpfull critisism, I have enough disgust at the myself at the moment. Tires are expensive!
Also, last couple years I have ran -3* on all four corners with no negative side effects... maybe -4* was just pushing it too far?
jc8587 is offline   Reply With Quote
Old 03-30-2010, 09:20 AM   #2
steveRS
Member#: 180430
2008 335i
Looks like too much front camber to me I personally wouldn't run that much camber in the front or rear.
steveRS is offline   Reply With Quote
Old 03-30-2010, 09:29 AM   #3
HybridBoxer
Member#: 139813
2002 WRB WRX
07 UGM STi
Has it been -3 degrees all 4 corners for street driving, or tracking as well? I think it's the excessive negative camber plus the harsh corners you're describing that wasted the tire. Not to mention the fact that the tire was worn on the inside edge to begin with. I feel you have pretty much answered your own question.
HybridBoxer is offline   Reply With Quote
Old 03-30-2010, 09:32 AM   #4
jc8587
Member#: 76201
1990 Spec Miata
TMPR.net
Haha
Never hurts to have a few opinions.
I don't daily drive on the ra-1s if thats what you mean. I do drive on that alignment
Old 03-30-2010, 09:36 AM   #5
cucamelsmd15
Member#: 122980
2010 F150, 2013 CX-5
92 Miata 15 TTF/PTF/E3
Id say 4+* of camber and toe out are likely culprits. How the hell did you get to 4+* anyway?
cucamelsmd15 is offline   Reply With Quote
Old 03-30-2010, 09:43 AM   #6
mav1c
Hoodbridge!
Member#: 560
2006 STi, 16 Outback
Crystal Gray, Silver
Too much front camber. When I run at tracks like Summit Point and NJMP, which are predominantly right turns, I will see more inside wear on the right front. With as much camber as your running, I would bet it's even worse.
Old 03-30-2010, 09:53 AM   #7
jc8587
Member#: 76201
1990 Spec Miata
TMPR.net
RCE camber plates and aftermarket camber bolts... That coupled with the ALK and 3.8* of caster doesnt help the camber issue in turns..
I guess I found where "too much is too much".
What sort of camber setting should I be looking for?
-3* ? -2*?
Old 03-30-2010, 10:02 AM   #8
steveRS
Member#: 180430
2008 335i
I'd shoot for -3.0 -3.5. Take your hand or a pyrometer and see if all of the tire is getting hot. If not, then adjust your camber accordingly.
Old 03-30-2010, 10:04 AM   #9
okiedude
Member#: 37736
2003 WRX Race Wagon
Be careful using aftermarket camber bolts in the front, they are usually smaller diameter and the front loads on those bolts can be pretty great. The factory bolts and top camber plate should be more than sufficient to get the settings you need. I run -3.5, but that is with Yokohama racing slicks, they like that much.
okiedude is offline   Reply With Quote
Old 03-30-2010, 10:09 AM   #10
mav1c
Hoodbridge!
Member#: 560
I run -3F, -1.8R. RCE T2's (600/500), 24mm Whiteline sways F&R both in stiffest setting. Nice even tire wear as long as I rotate regularly.
Old 03-30-2010, 10:21 AM   #11
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
We run -4.2* on the front of our race car with a slight bit of toe out and never have any problems. Running -3.4 in the rear with a bit of toe in.
Wouldn't surprise me if you were just running the most worn tire on the left front. Putnam will kill it quickly if you're not careful as you know.
Tony
Old 03-30-2010, 11:02 AM   #12
jc8587
Member#: 76201
1990 Spec Miata
TMPR.net
Tony
Thanks guys,
I'll keep this is mind and remember bring a pyrometer, notebook, and a cautious outlook with me next time! lol.
Old 03-30-2010, 05:36 PM   #13
GLSTI
Member#: 242717
That seems, good. Add a little more caster to regain the front grip you'll lost with the less aggressive camber
GLSTI is offline   Reply With Quote
Old 03-31-2010, 08:51 AM   #14
jc8587
Member#: 76201
1990 Spec Miata
TMPR.net
UPDATE:
Judging by brake dust, it is actually a rear tire that has corded, not the front.
I am going to check the alignment tomorrow and see if the toe slipped.
Help - alignment eating tires kelsey Brakes, Steering & Suspension 10 12-04-2008 09:13 PM
did my alignment,now my car is messed up 1stockwrx Brakes, Steering & Suspension 34 06-17-2008 11:07 PM
did my alignment,now my car is messed up 1stockwrx Newbies & FAQs 7 06-16-2008 03:52 PM
Just did the alignment today, how is my setting? ForEveR2.5 Brakes, Steering & Suspension 3 07-01-2003 02:25 AM
Finally decided to do my alignment myself...boy did it hurt !!! munkis General Forum Archive 6 01-03-2001 04:31 PM
