Old 06-03-2002, 01:22 AM   #1
mofoporn
Member#: 4766
2001 2.5 RS
BRP
Default keepin white rims clean?
what is the best way to keep white rims clean? I have the rota sub-zeros and they are always dirty with brake dust and dirt and crap..... I heard thet if you put a thick coat of wax on it that the dirt and stuff doesnt stick as much.
Kurt
mofoporn is offline   Reply With Quote
Old 06-03-2002, 03:17 AM   #2
shogunate83
Member#: 6006
I'm sure it will stick.. but it will be easier to wash off
shogunate83 is offline   Reply With Quote
Old 06-03-2002, 10:30 AM   #3
westy66
Member#: 4329
2005 LGT Wagon 5MT
good question.... i wanted to powder coat my stock rims white for winter use, but they would be dirty and crappy looking all the time.
Bob
westy66 is offline   Reply With Quote
Old 06-03-2002, 03:28 PM   #4
imprezaf
Member#: 12403
2008 STi
An old trick that I heard about is actually spraying the rims with something like Pam. After you clean the rims, put a coat of wax on them, then spray some Pam on them. Any dirt or brake dust won't stick to the rims, and all you have to do is hose them clean
-Mike
aka imprezaf
imprezaf is offline   Reply With Quote
Old 06-03-2002, 03:43 PM   #5
Seraph
Member#: 12251
Pam is actually what a lot of people use on step-in bindings on snowboards so that the snow doesn't clog the claws and the tabs, and it works great.
Seraph is offline   Reply With Quote
Old 06-03-2002, 04:38 PM   #6
98kPa
Member#: 17379
I bet PAM will keep your tires shiny too
jason
98kPa is offline   Reply With Quote
Old 06-03-2002, 10:33 PM   #7
mofoporn
Member#: 4766
2001 2.5 RS
BRP
so clean you can eat off it Ha Ha Ha Ha HA because of the Pam....yea....get it.....
Im Sorry
Kurt
"Because its your dog!"
Old 06-03-2002, 11:06 PM   #8
Skylab
Member#: 4263
Arrow
Find out if the powdercoating shop can put a clearcoat on the rims. Local guy here has powercoated gold stock rims with a clearcoat and he says that the dirt wipes right off.
I'm planning on the white look too...
Good Luck
Skylab™
Skylab is offline   Reply With Quote
Old 06-27-2002, 08:49 AM   #9
Rattler
Member#: 6351
2004 Tacoma 2xCab
\m/ \m/
I had a set of wheels I painted white on my old Z28. I clear coated them after about a week of daily cleaning. I just used an engine enamel "clearcoat".
I was going to post a new thread in regards to another trick I use. I take Kit EZ Shine wax (its one of those spray-on quickie deals) and spray a bunch on a rag. I then wipe down my gold Rotas with it respraying the rag every now and then. This seems to make my wheels easier to clean when I wash it. I use the Kit stuff for no special reason. I get it cheap through work.
Rattler is online now   Reply With Quote
Old 07-07-2002, 03:14 AM   #10
Nacan_5
Member#: 18819
2002 Imprezza WRX
WRB WRX
Be careful using PAM as to not overspray. I did this my dirtbike to help with the mud, and upon finding only dust, the PAM actually helped the dust collect all over my bike, and the engine heat baked it on...just a warning
Nacan_5 is offline   Reply With Quote
Old 07-07-2002, 07:48 AM   #11
WRXagon
Member#: 16179
2002 WRX SportWagon
WR Blue Pearl
Get some low-dust brake pads.
Shawn
WRXagon is offline   Reply With Quote
Old 07-07-2002, 01:14 PM   #12
juztin180
Member#: 11804
Yep, Low dust pads
maybe try some Zaino bros Z6 spray. For some reason it keeps dust away on my car.
Its black and i was washing it about 2-3 times a week to keep it clean. After i got the Zaino spray i wash it maybe once a week and spray it w/ zaino about the same.
just a suggestion
juztin180 is offline   Reply With Quote
Old 07-07-2002, 07:50 PM   #13
Really_Soaked
Member#: 4992
2000 Impreza 2.5 RS
Blue Ridge Pearl
Don't spray your wheels with Pam.
It works during the winter (sort of) if you're doing a lot of donuts and you don't want snow sticking in clumps on your wheels. It also works for stopping large amounts of mud from sticking. But it makes brake dust, road dust and pretty much any small particles stick to the surface.
Take two spoons, spray one with pam, leave the other one clean. Then go and blow dust over them both. You'll see what I mean.
Really_Soaked is offline   Reply With Quote
Old 07-07-2002, 10:14 PM   #14
BIGSKYWRX
Member#: 7958
09 GH B+
I've been washing my TE's (white) w/ soap and water and although they cleaned up pretty good, I noticed what i thought were several nicks out of the paint. Then I read a post about waxing your wheels and thought I'd give it a try. I used Mother's cleaner wax and all the "nicks" are gone- must have been tar or some other stubborn substance. I was estatic to say the least. They do clean easier now also.
As a side note, the Mother's cleaner wax did a wonderful job in removing a terrible orange streak along the side of my white rex (somebody must have thrown a cone at my car during a autox event as I've never hit one ).
Big Sky
Old 07-08-2002, 12:41 PM   #15
Section 8
Member#: 821
Don't spray anything on your wheels while they are on the car. What ever you get on your wheels will end up on your brakes. Spray into a rag and apply, or just take the wheel off. Tire and wheel cleaners have caused brake pad squeel, and you just plain don't want to spray Pam on your rotors. Anti stick = anti friction = just plain bad for braking. It might come off with the first application of braking, but if you need to stop NOW, you don't want anything on there.
cheeRS,
Greg
Section 8 is offline   Reply With Quote
Old 05-30-2011, 07:52 AM   #16
Fat Black Pig Sac
Member#: 247911
2005 obp WRX
color: HUMMER H2 WHITE
I used Mother's wax on my white Rota G-Force and it worked better than expected!
Brought 9 years old thread to life!
Fat Black Pig Sac is offline   Reply With Quote
Old 05-30-2011, 02:03 PM   #17
paulpat
Member#: 237145
02 WRX
12 FXT
lol. Funny I just sprayed aircraft grade silicone all over my rims. Lets see if it helps. I dont care but it was bugging my dad.
paulpat is offline   Reply With Quote
Old 06-01-2011, 08:58 PM   #18
dankim321
Member#: 283287
dankim321 is offline   Reply With Quote
Old 06-01-2011, 11:22 PM   #19
wrxfinally
Member#: 284126
2006 Impreza WRX STi
CGM
just purchased a wrx couple weeks ago and i was thinking going white rims. not 100% but if they're always dirty that would be annoying. but my cars black so i have to wash it weekly anyways...
wrxfinally is offline   Reply With Quote
Old 06-02-2011, 02:39 AM   #20
bri_n_m
Member#: 263133
2011 WRX
i just bought a bottle of this:
http://gtechniq.com/shop/3s-for-cars...-wheel-armour/
it's a bit expensive but my local detail shop loves it and swears by their other products. i havent used it yet so i cant give a first had experience. rims go on in about 3 weeks.
bri_n_m is offline   Reply With Quote
Old 06-02-2011, 04:24 AM   #21
LifeMage
Member#: 260130
2007 Wrx
I had always polished the rims with a wax (once they were cleaned and new) than makes it easier to wipe the dust away
LifeMage is offline   Reply With Quote
Old 06-02-2011, 07:51 AM   #22
jonklein611
Member#: 117776
2011 WRX Limited 5dr
WR Blue Pearl
sonax to get the grime off, then a wheel wax to keep them clean.
jonklein611 is offline   Reply With Quote
best way to keep rims clean?? STIpimp2006 Car Care & Detailing 25 11-21-2009 12:42 AM
Keeping STi wheels clean inside the rim? Drive_STIck Car Care & Detailing 6 06-17-2007 12:22 PM
Keeping painted rims clean? baileypicks24 Interior & Exterior Modification 10 01-31-2005 10:03 AM
Keeping painted rims clean and shiny? baileypicks24 Tire & Wheel 1 01-15-2005 08:09 PM
How do people with white rims keep them clean? kenshiro Brakes, Steering & Suspension 0 06-04-2002 02:12 PM
Message Board Statistics All times are GMT -4. The time now is 01:15 AM.
