Welcome to the North American Subaru Impreza Owners Club Saturday July 2, 2016
Old 03-30-2010, 09:32 PM   #1
Punk In Drublic
Member#: 232673
2015 wrx limited
dgm
Question Grille/bumper doesn't line up with hood
Also just posted this in the service and maintenance section but I thought maybe someone here would know about the frame structure or something and be able to help out:
This came to my attention yesterday when I swapped my CF hood for a stock 02 WRX hood... The front of the hood hangs over the front grille piece a little bit on the passenger side, and even more (about 3/4") on the drivers side. It may or may not have been in a small fender bender before I bought it (clean carfax).
The guy who was swapping with me told me that the front frame can be pushed back towards the firewall without much force, and it's an easy fix. He said it just needs to be pulled back out. Anyone have experience doing anything like this?
Brian
Punk In Drublic is offline   Reply With Quote
Old 04-05-2010, 03:25 AM   #2
subaru3169
Member#: 55252
* pullup bar *
perhaps you could see how much play there is where the hood bolts onto the hinges.. the height can somewhat be adjust on the front of the hood by the rubber knobs on top of the frame
subaru3169 is offline   Reply With Quote
Old 04-06-2010, 03:27 AM   #3
FourOnTheFloor65
Member#: 106225
02 WRX STied PSM
03 L, 05 GT Legacy Wagons
It is more likely that the hood is the issue. Cheaply made fiberglass hoods, with a thin layer of carbon fiber on top of them, pretty much all suck. They never fit correctly, mainly because of the cheap resins used and the way they are made.
FourOnTheFloor65 is offline   Reply With Quote
Old 04-08-2010, 09:50 AM   #4
69subaru360
Member#: 159682
1995 WRX
2015 F150
You can bend the upper tie bar of the radiator support easily. It's just thin sheetmetal. It bends back easily too. Bend it back with a big prybar or even a ratchet strap hook to an immovable object.
Old 04-19-2010, 08:26 PM   #5
Punk In Drublic
Member#: 232673
2015 wrx limited
dgm
Here is a picture that shows the problem
Can anyone give me more info on the ratchet strap method? I'd rather do that before taking a dremel tool to my hood mounting holes...
Old 04-19-2010, 08:55 PM   #6
69subaru360
Member#: 159682
1995 WRX
2015 F150
Park the car near something solid that won't move. Wrap a a large 2-3" or so ratchet strap around the upper tie bar and to immovable object. Tighten the strap pulling the upper tie bar back in place. Do one side at a time, checking parts fit as you go.
Help shifter not lined up with gates on 5mt runner19 Transmission (AT/MT) & Driveline 6 04-27-2012 10:16 AM
Front grille/bumper doesn't line up with hood Punk In Drublic Service & Maintenance 2 03-30-2010 10:58 PM
MAF screw holes don't line up with new intake MDRex Mid Atlantic Impreza Club -- MAIC 16 10-06-2009 11:35 AM
sti swap headlights, grill, bumper, hood,& fenders with 02 wrx? Factual info please Turbo Juice Interior & Exterior Modification 12 06-23-2003 08:32 PM
ARGH! Up Pipe about an inch off line up with manifold Altered BeasT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 10-29-2001 10:03 AM
