Old 03-31-2010, 01:01 PM   #1
Darth Lefty
Member#: 126009
11 WRX wagon
Anonymous Gray
Default Quick stands?
I'm curious if anyone makes stands that work like a motorcycle rear stand, or the stands they use in the Formula 1 pits... with two solid wheels and a long handle to lever them under the car. Cars are heavy I know, but if you're only lifting a corner at a time and had a set of four... in the garage this could replace both jack and jack stands.
Does anyone know of such a thing?
Darth Lefty is offline   Reply With Quote
Old 03-31-2010, 03:49 PM   #2
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car in progress
Nope, not for a sedan. It MIGHT work if you had a person on each side to simultaneously lift each rear corner or each front corner but even then it probably couldn't lift high enough. And I sure as hell wouldn't crawl under a car that was only supported by them, you need jack stands anyway.
boost junkie is offline   Reply With Quote
Old 03-31-2010, 03:52 PM   #3
PrecisionCustom
Member#: 207830
2002 Precision Built
Make that $hit and get paid!!!!!!
PrecisionCustom is offline   Reply With Quote
Old 03-31-2010, 05:51 PM   #4
Member#: 67
1999 Outlasting
the competition.
Might be cheaper and easier to put airjacks in the car
Old 03-31-2010, 09:48 PM   #5
FourOnTheFloor65
Member#: 106225
02 WRX STied PSM
03 L, 05 GT Legacy Wagons
Have you ever seen hydraulic wheel dollies? They won't get the car very high, though, maybe 4 or so inches. Harbor Freight even sells them. There is a coupon to get them for $50 a piece.
FourOnTheFloor65 is offline   Reply With Quote
Old 05-07-2010, 01:52 AM   #6
db2xpert
Member#: 35932
Bought these, but the wheels are too small to move the car easily by myself.
Had to get a friend to help push.
db2xpert is offline   Reply With Quote
Old 05-07-2010, 08:03 AM   #7
kharris4
Member#: 46018
2003 wrx
silver(mostly stock)
You might be able to find some bigger casters for that on McMaster Carr, or somewhere like that.
kharris4 is offline   Reply With Quote
Picture inside, need quick advice azscooby Transmission (AT/MT) & Driveline 6 06-06-2010 09:54 PM
quick question about engine stands... Jpizzzle Built Motor Discussion 1 11-12-2006 12:22 AM
quick question: What Does GI Stand For? skimmilk68 Off-Topic 33 02-13-2006 11:51 AM
Quick jack stand question porque Service & Maintenance 8 07-06-2005 06:09 PM
Quick engine stand Q rally_wrc Subaru Conversions 8 10-17-2004 12:12 AM
