Old 03-31-2010, 05:45 PM   #1
djc1827
Member#: 238618
2011 WRX
11.82 stock 5sp/eng vf52
Default rain causing cel and maf problem
At first it just became a problem when i went thru a carwash but now it occurs when it rains as well. I have a fender liner so now i had to find out where the water is coming in and getting my filter wet thus creating a problem under boost. So here are some pics. The holes are not big but i hope after using some safe silicone to seal them off the problem will not come back.
Ok how do i upload pics without using an url...you know upload them from my pc?
djc1827 is offline   Reply With Quote
Old 03-31-2010, 07:11 PM   #2
oguitar
Member#: 206720
2002 WRX Wagon
You can't directly upload from your CPU. You need to upload to a website like photobucket. Once you have uploaded your image there you can copy and paste its image code.
What filter is getting wet? Your air filter is what I am guessing. Is it a stock airbox or CAI/SRI?
oguitar is offline   Reply With Quote
Old 03-31-2010, 09:42 PM   #3
djc1827
Member#: 238618
2011 WRX
ks tech cold air, it goes down in the wheel well but there are a few holes around it about 1/2 inch where water is dripping down onto the filter. I bought some foam sealer stuff i think im gonna fill in the gaps, wont look pretty but will do the job. You know the stuff that expands like 30%. I cant believe you have to load pics that way...pretty lame. I am not gonna sign up for photo bucket. What does nasioc have a contract with them? Wouldnt surprise me
Old 04-01-2010, 12:48 AM   #4
oguitar
Member#: 206720
2002 WRX Wagon
There are other sites you can use. I just mentioned photo bucket because that is what I use. Don't try to fight the system here. Just go with the flow. Stick to the newbie forums until you get the feel of how this site works. IMHO.
Old 04-01-2010, 11:20 AM   #5
Pearl04
Member#: 178913
06 STI
You should get black silecone. I don't know how to spell that. It's simple and would make less of a mess in my opinion. You could make it look pretty nice.
I'm about to put an intake in my fender and would like to see some pics of yours where it's leaking. Go sign up for photobucket. When you sell stuff it makes it easy to post in multiple forums, plus when you are away from home you can still access your pics. Do it.
Pearl04 is offline   Reply With Quote
Old 04-01-2010, 09:57 PM   #6
djc1827
Member#: 238618
2011 WRX
Old 04-01-2010, 09:58 PM   #7
djc1827
Member#: 238618
2011 WRX
Im guessing some water is dripping thru this hole
Old 04-02-2010, 12:00 AM   #8
scby rex
Member#: 104878
02 wrxbastardchild
aw, MPS 2.34 breaking in
change the filter to a k&n, you dont think water gets in between the hood and fender and that huge hole in your hood?
scby rex is offline   Reply With Quote
Old 04-02-2010, 12:02 AM   #9
djc1827
Member#: 238618
2011 WRX
I bought the aem filter because the k&n must be cleaned with oil and that oil can cause maf problems as well. I will just block off all possibilities of water seeping thru and problem solved
Old 04-02-2010, 12:21 AM   #10
xBroncox
Member#: 236790
2003 wrx
yellow
I has simular problems with my wrx thought that a coil pack was cracked or bad wire connection.It only had problem in rain mostly boost issues the car came to me with a aem shorty took it out just because it was not tuned for it and now my rain problem is no longer.i started to think it was a general humidity problem mixed with untuned intake but the aem was fine when it was dry out just seemed to cause uneven idle.now i am happy again car runs much better with stock intake
xBroncox is offline   Reply With Quote
Old 04-03-2010, 06:08 PM   #11
djc1827
Member#: 238618
2011 WRX
Nothing a little water proof tape didnt take care of.....lol
Old 04-04-2010, 11:56 AM   #12
scby rex
Member#: 104878
02 wrxbastardchild
your oiling it way to much then. it takes very little oil. So your going to make a air tight box for your air intake? water can get almost anywhere air can so you going back to the stock air box?
help!!! flashing cel and no one can help tommy 02wrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 21 06-05-2010 08:26 PM
1999 Subaru CEL and Stalling Problem vancarlson Service & Maintenance 1 10-24-2006 04:11 PM
02-03 Brake Differences Causing Me and AndrewTech Problems HELP plz theziggurat Brakes, Steering & Suspension 1 08-02-2005 11:53 AM
Maf problem...Cels car wont start... bottlediger Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 9 06-27-2005 09:37 PM
Catted downpipe and 3rd cat eliminator pipe cause cel? dman918 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 02-13-2002 03:39 AM
