Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 03-31-2010, 06:26 PM   #1
elitescouter
Member#: 127164
05 WRX STi
Default My STi burned 2 and half quarts of oil in 800 miles??? Catch can = full
Ok so I am going out of my mind here. My car used up 2 and half quarts in about 800 miles. I did my oil change 800 miles ago, filled it up and it was all good, emptyd my catch can and changed my oil filter. I put in Redline 5W30 every oil change. I do the oil change my self and I do it under 3k miles every time. I included some pictures of my catch can... It was litteraly full and the crap was going back into the intake. I don't know why it fills up so fast and no idea where my oil is going. It's not leaking at least no spots on the ground and when I change my oil its really clean under.
My car runs good no issues with power. I do drive my car differently than other people. Theres no day that the car doesen't see high rpms. I always check my liquids before driving it. I run RomRaider logger no matter where I drive. Any ideas?
Here are some catchcan pictures... This was made in 800 miles.
elitescouter is offline   Reply With Quote
Old 03-31-2010, 06:29 PM   #2
blkwrx06
Member#: 190753
damn thats milky. Do a leak down test.
blkwrx06 is offline   Reply With Quote
Old 03-31-2010, 06:34 PM   #3
jdmboy
Member#: 240161
2002 wrx wagon R.I.P
87 bmw e30
^i deff suggest a leak down test. my car did something like this about a year ago i dont have a catch can but it burnt a quart of oil in like 500 miles. all i did was change the pvc valve and changed my oil and it never happened again.
jdmboy is offline   Reply With Quote
Old 03-31-2010, 06:45 PM   #4
blkwrx06
Member#: 190753
the fact its so milky makes me wonder if its a headgasket. It very well could be as simple as a pcv, but....god damn thats milky as all hell. I burn half a quart of oil every 5k if that. i push my car harder then most, I use penzoil platnium 5w30. 33k on dash currently.
OP is your radiator reservoir milky colored?
Old 03-31-2010, 07:24 PM   #5
elitescouter
Member#: 127164
05 WRX STi
No it's not. It's the blue color.
Old 03-31-2010, 07:27 PM   #6
blkwrx06
Member#: 190753
lol, its not green? What brand fluid are you using? I didnt mean your radiator fluid would be quite the same color as your oil is right now. I mean like cloudy/murky.
Old 03-31-2010, 07:34 PM   #7
Audiosavvy
Member#: 150794
Qcab dakota 4x4
LT1 Formula Firebird
It's normal to 'catch' more during the winter months. However, that much blow-by has me wondering about the condition of one or more pistons.
Hate to say it, you are describing the first symptoms of my old shot 2.0
Audiosavvy is offline   Reply With Quote
Old 03-31-2010, 09:05 PM   #8
elitescouter
Member#: 127164
05 WRX STi
I just went to the shop. They told me the compression is low. They said the ring land on the piston is shot. It would cost me 4500$ with forget pistons. This is not looking good for me. I don't have this kind of money at the moment. Any other routes I can go?
Old 03-31-2010, 09:23 PM   #9
davidsti1
Member#: 210923
2001 RSTI Twinscroll
FullRace BW8374 ripper
davidsti1 is offline   Reply With Quote
Old 03-31-2010, 09:43 PM   #10
elitescouter
Member#: 127164
05 WRX STi
Wow thanks on those links!
Is it really true the ring land can go on a 68k mile motor that's been only stg 2 for around 30k miles?
Old 03-31-2010, 11:05 PM   #11
dr3w
Member#: 222318
1993 RHD GC8
Might have been something as simple as bad gas, so yes unfortunatly its very possible.
dr3w is offline   Reply With Quote
Old 03-31-2010, 11:17 PM   #12
elitescouter
Member#: 127164
05 WRX STi
So putting in a new block would fix this? I honestly can't pay $4500 just for forged pistons and couple of gaskets. New block is 2k shipped, I have a friend who can put it in and it wouldn't cost me more than 2.5k... sure beats 4500$ and I get a new block, pistons, rods, etc.
Old 04-01-2010, 01:20 AM   #13
Want_To_Buy
Member#: 238843
1997 Honda
Accord
Why are you using the Blue, could have sworn Subaru said not to!
Want_To_Buy is offline   Reply With Quote
Old 04-01-2010, 01:21 AM   #14
cartoonlife
Member#: 204291
07 UGM STi Ltd
2012 Prius
Think about it real hard. Spend the little extra to do it right. It might cost you more in the end. 2k for a block and 500 for forged pistons. 300+awhp isn't a crazy figure, but it still falls under the "not IF your engine will go, but WHEN" parameters.
Make absolute sure that who ever is doing the work does it well. Not just everyone can build a motor right.
Good luck with your build man. I too am waiting for the WHEN.
cartoonlife is offline   Reply With Quote
Old 04-01-2010, 01:28 AM   #15
Want_To_Buy
Member#: 238843
1997 Honda
Accord
Man search hiis threads... This problem goes back to last year along with a load of other problems. Mbc and the bov probably shouldn't be on there op.....
Old 04-01-2010, 10:31 AM   #16
Metallrulz
Member#: 100148
2003 WRX Wagon
If you're going to just throw in another stock block I'd at least figure out why this happened in the first place. Do you have a good tune (verify with a wideband)? Using the right oil? Maybe you're beating on the car a little too hard.
Metallrulz is offline   Reply With Quote
Old 04-01-2010, 10:52 AM   #17
the suicidal eggroll
Member#: 51961
2005 STi
2012 WRX
Most of that $4500 is labor
You can get a new stock shortblock for about $1600, pistons for about $400, gaskets for about $200. New timing belt, idlers and water pump for another few hundred...you're looking at under $3k for the whole thing, including a new block.
If you reuse your block, you can get it bored/honed, new bearings, pistons, timing belt, idlers, etc for under $2k.
You do not want another OEM block though, there is ZERO reason to stay with OEM pistons at this point, they are the weak link by far, and are the reason you're in your current situation.
Old 04-01-2010, 11:45 AM   #18
elitescouter
Member#: 127164
05 WRX STi
I just talked to a friend last night about my situation. He told me I would be lucky to get 30k miles out of the forged pistons.
I don't want anything crazy right now. This is my daily driver. Yes I drive my car pretty hard but right now I'm not looking for more power.
I am going to have them print out an estimate because $4500 is too much for me at the moment. The $4500 is with my block, its not a new block so yeah.
Old 04-01-2010, 11:53 AM   #19
i_c_the_light
Member#: 88618
1994 Legacy
"The Silver Slug"
30k is bull****. Find a new friend.
i_c_the_light is offline   Reply With Quote
Old 04-01-2010, 12:00 PM   #20
elitescouter
Member#: 127164
05 WRX STi
Hahahah thanks
Old 04-01-2010, 12:02 PM   #21
happs subi
Member#: 200288
2002 Impreza WRX
World Rally Blue
30k out of forged pistons... That figure is a bit exagurated... But all you have to do is take out the weak link, which are the pistons. That's $1600 for a new block, plus another $400 for forged pistons. And you can get everything put together for around $2500, vs $4500. That's a big difference
happs subi is offline   Reply With Quote
Old 04-01-2010, 12:26 PM   #22
elitescouter
Member#: 127164
05 WRX STi
Well dam.. I might just have to drive down to cali to get that done =)
I am going to have the estimate printed out to see everything and why it's so expensive.
Old 04-01-2010, 12:31 PM   #23
evan_impreza
Member#: 115276
04 PSM WRX -sold:(
98 RS- WRX swap complete!
30k on forged pistons is a figure for cars with VERY high horsepower applications. Its because no one runs stock turbo/tune with forged pistons. If someone were to and the block was built correctly it will last much longer than stock.
evan_impreza is online now   Reply With Quote
Old 04-01-2010, 04:56 PM   #24
elitescouter
Member#: 127164
05 WRX STi
I went back there today to get another estimate. I guess the labor is like 2k, lol. They say the car would need to be at the shop for 6 days. I am running out of options. I am even thinking of doing the job my self, just have to get the right tools. The way they explained it, it makes it sound as they are the only shop that does it perfectly and it takes rocket science to do it. They told me not to buy an assembled block because the person probably didn't do it right.
Old 04-01-2010, 05:12 PM   #25
happs subi
Member#: 200288
2002 Impreza WRX
World Rally Blue
if you buy an oem block guess who assembles it
and swapping out your pistons is actually much easier than you think. if you look in the built motor forum stickies, they show a few project builds and how-to's
although, you will need time, space, and the right tools.
9 quarts of oil in a 2002 WRX (big problems i think) Saco1997 Service & Maintenance 31 08-07-2009 01:19 PM
anyone else going through a quart of oil every 1k miles? God Normally Aspirated Powertrain 12 04-21-2009 02:38 PM
Using One Quart of Oil per thousand miles... =( chipster Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 32 11-24-2006 02:16 AM
burned off 3 quarts of oil in one weekend... kheovnien Service & Maintenance 5 02-15-2006 02:49 AM
Anyone else burn a quart of oil in the first 3000 miles? Zoso STi Forum Archive 17 07-26-2003 10:33 AM
