Old 06-03-2002, 11:25 AM   #1
Frakk's2.5
Visiting NASIOC Timeout
Member#: 11181
Question Borla Headers good or not?
I just put in my order through Cobb tunning I've several opinions about them some say they are good some say they are bad I know that for a period of time the quality wasn't that great was it Gen 1&2 if I'm not mistaken right? anyway i also ordered the High flow cat I was goign to go straight pipe but I figure I'll keep it legal for a while anyway does anyone on the board have the same combo? ad how much of an increase would this combo give you? I have so far two Mods (engine wise) Apex'i N-1 Cat back system, Injen Cold Air Intake with this alone I can notice a difference, and I like it alot.
Frank
Frakk's2.5 is offline   Reply With Quote
Old 06-03-2002, 01:24 PM   #2
rupteur7000
Member#: 11585
02 2.5RS
i am also not a p****
the last gen are fine, they fixed the cracking problem. the borla headers are great, not the best performance wise but the best sounding ones for the price, they are also the only ones that bolt up to the cat same as stock so it is good if you want to go FI later on. for now it is my first choice as well.
enjoy, and don't wake up the neighbors.
Q
rupteur7000 is offline   Reply With Quote
Old 06-03-2002, 02:18 PM   #3
Dolphin Overton
Member#: 1925
01 A4 89 944s2
13 Speed 3R 99 Sprint
I don't have them, but I hear the last generation is pretty good. I have also heard that you should wrap them as to not throw a CEL... Let us know how it goes
Dolphin Overton is offline   Reply With Quote
Old 06-03-2002, 05:41 PM   #4
J Rotten
Member#: 9345
2000 impreza rs-t
silverthorn metallic
Just put borla headers on my car last week. I already had the random tech high flow cat on the car. Install was a snap the wait was kind of long.(6WEEKS) No cel yet i was told by cobb to not wrap the header but to get it jetcoated instead.enjoy the noise
J Rotten is offline   Reply With Quote
Old 06-03-2002, 07:54 PM   #5
Reciprocity
Member#: 1165
2012 dcrawford died
for your sins
Borla...
Pros:
-Warranty (if bought new from vendor)
-Awesome awesome sound
-Proven company, been around for ages
-American company, warranty easier to deal with
-Easy install, bolts straight to stock cats
-CARB legal (I believe)
-Stainless Steel
-Can be used with turbocharger
Cons:
-Stories of cracking, bad welds, banging (all those issues should have been addressed by now)
-Not the most efficient design (lots of bends)
-Not the most powerful design
-CE light possible
-For a bit more you can get more power
-Comes bare, no coating, no paint
-All you get is the header
MRT...
Pros:
-Most efficient design (LOOKS to be that way, so far)
-Comes heat treated
-Minimal amount of bends
-Comes with high flow cat
-Comes with midpipe
-Comes with exhaust can
-Pretty inexpensive considering what you get
-Thick walls, impressive build quality
-Many vendors carry it
-Could quite possibly be the best power from an N/A header (MAYBE!!)
-Midpipe MIGHT allow direct bolt on of other "Subaru" exhausts (maybe...not sure, but I think it does)
Cons:
-Manufactured in Australia, sold through US vendors (make take a while to get it if it isn't in stock)
-If warranty repair is needed...see above note
-Just doesn't sound as good as the Borla
-CE lights more common
-Some issues with damaged cats
-slight modification to second O2 sensor required (but still very easy to install)
-Mild steel, could rust in certain climates
-Not CARB or smog legal
-Can't be used with turbocharger (at least, not easily)
-Stock can a little weak sounding (my opinion)
That's my take on things...and as always, open to discussion.
Anyone want to do a Pro/Con for the Brullen?...or Syms?
NC
Reciprocity is offline   Reply With Quote
Old 06-04-2002, 01:00 PM   #6
Julian
Member#: 1182
MY00 RS
BRP
Borla - Pro: early generations were CARB legal
Borla - Con: later generations (3 and 4, IIRC) are no longer CARB legal.
MRT - the header isn't ceramic-coated, just painted with a different paint than the rest of the system.
Otherwise, a very nice summary of the two systems. If someone could add one for the Brullen, call it good and Sticky it or FAQ it.
FAQ you! Smurf off!
Julian is offline   Reply With Quote
Old 06-05-2002, 12:08 AM   #7
Frakk's2.5
Member#: 11181
Hey! that really helps my out alot thanks! so how much HP @ the crank would you say you would gain out of this??
Frank
Header equal or not Marcos Peguero Pre-2002 Factory Turbo Powertrain 4 09-26-2006 08:33 AM
Putting car in storage for a year. Good or not good? tankerWRX Newbies & FAQs 21 05-10-2006 04:13 PM
Cracked Gen3 Borla header...repair or warranty? Bob O Normally Aspirated Powertrain 13 07-03-2003 12:03 AM
Borla headers...wrap or cermaic coat? Bob O Normally Aspirated Powertrain 10 07-03-2002 12:49 PM
The Borla header debate...or I have $500 and I need your opinion Overtime General Forum Archive 13 07-24-2000 07:57 PM
