Go Back   NASIOC > NASIOC Classifieds > Vendor 'For Sale' Classifieds > Gauges & Electronics
Closed Thread
Old 04-01-2010, 09:53 AM   #1
Built Industries
Vendor Sales Rating: (21)
Member#: 33839
Default Electronic Goodness Sale!!-AEM/GRedddy/AutoMeter
If your looking for some new electronics for your car then this is the perfect sale for you! I garuntee To make you the best deal on these items!
AEM Tru Boost 6 in 1 Controller
The AEM Tru-Boost Boost Gauge/Controller combination is a multi-featured system for simplified, comprehensive boost control. Packaged within a 52mm gauge are a 29psi capable boost controller, peak-memory boost gauge, and many other great features. This unit includes black and silver bezels and black and white faceplates for simple color selection and easy matching to other AEM gauges (i.e. serial gauge, UEGO, etc.)
Features:
On-board pressure sensor included for boost levels up to 29 PSI
Peak boost memory
Selectable over boost alarm with overboost shutdown
Scaleable bar graph display
Selectable waste gate delay for quick turbo spool
Simple install harness allows for quick and easy installation
Boost hose and fittings included for easy hookup to on-board pressure sensor
AEM Wideband UEGO
AEM's Wideband UEGO Controller is also available in a gauge that includes a single-channel analog output with a Bosch O2 sensor in one unit! The controller also features an LED readout and sweeping LED "needle" that changes colors as AFR fluctuates from rich to lean. The 52mm (2-1/16") gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere.
Need something to put those Pretty new gauges in?? well i got that coverd!
ATI Tripple Gauge Hood
ATi clock pods feature a punch out design that allows you to increase the diameter to accommodate 52mm or 60mm gauges in the same pod, this means you can mix and match 52mm and 60mm gauges. There are optional face plates to customize you pods look. This gauge pod is painted by ATi to match the interior. Gauges face the center they do not face the driver.
Auto Meter Full Pillar Pods
This dual gauge pillar mounted gauge pod from Auto Meter is an easy way to add two 52mm gauges to your interior. This gauge pod covers the whole stock pillar molding.
GReddy Turbo Timer II
Greddy has finally released their follow up to their famous full auto turbo timer. The Turbo Timer II offers the same great features as the original version with a few improvements, such as 'attack' mode which ties into your speedometer and calculate 0-60 times as well as 1/4 mile ETs, digital speedometer, digital volt meter and digital clock display options. The unit also includes two separate programmable turbo timer functions as well as two pre-programmed auto modes. The Greddy Turbo Timer II features the new flat face style display unit with an easily hide-able brain box for more versatile mounting options in any car. Install is a snap using the Greddy plug and play turbo timer harnesses, sold separately.
Innovate LC-1 XD-16 Wideband
The Innovate “Standalone Gauge Kit” comes complete with the patented award-winning LC-1 Wideband Controller, NEW! XD-16 (16 in 1) 52mm Programmable Digital Gauge, Bosch 5-wire Wideband 02 Sensor, Bung/Plug Kit, Software CD, and quick start guide.
We have these On our shelfs ready to ship out, and i promise we have these for the best price you'll find!
__________________
321.304.4908
Sales -
Sales -
Tracking -
General Inquiries -
Prices via text message 407-376-0059 (just text). Large quotes please email, include first and last name please!
Built Industries is offline
Old 04-01-2010, 02:01 PM   #2
Built Industries
Member#: 33839
PM's have been replied! keep em comin!!
__________________
321.304.4908
Sales -
Sales -
Tracking -
General Inquiries -
Old 04-02-2010, 09:40 AM   #3
Built Industries
Member#: 33839
Greddy Profec B Spec II Boost Controller
Based on the very popular B-Spec, the all new Profec B-Spec II increases boost as easily and accurately as the original, with an added built in boost pressure display and new optional features like real-time, peak or last boost display (in either kPa or PSI). There are optional warning and boost limiter functions that can be programmed to offer much more control. The two presets values can be stored and are executed by a larger capacity inline solenoid valve.
This unit does not require extensive programming and is ideal for low to high boost levels for single or twin turbo systems with actuator or external wastegates. The Profec B-Spec. II is available in black or silver cased head units.
__________________
321.304.4908
Sales -
Sales -
Tracking -
General Inquiries -
Old 04-02-2010, 01:27 PM   #4
Built Industries
Member#: 33839
All PM's have been answerd. Its Friday!! who wants a shinny new package next week?!?!
__________________
321.304.4908
Sales -
Sales -
Tracking -
General Inquiries -
Old 04-05-2010, 09:24 AM   #5
Built Industries
Member#: 33839
Done with painting eggs, now its back to some awesome deals!!
__________________
321.304.4908
Sales -
Sales -
Tracking -
General Inquiries -
Old 04-06-2010, 09:27 AM   #6
Built Industries
Member#: 33839
Cobb AccessPort Got a ton in stock!!
Installs via the vehicle's diagnostic port - no tools/disassembly/wiring required!
Reversible Process: the ECU can be returned to stock at any time
Scantool Capability: Read and clear check engine lights (CELs).
Measure 0-60, 1/4 mile times, estimate fuel economy, & estimate torque and horsepower.
Data Readout: Display engine parameters on the color screen.
Dynamometer: Easily calculate power output and compare with other Accessport users
Accessport part numbers vary between model and year. Please choose the correct Accessport for your car below.
The 07 WRX & 07 STI require a restrictor pill (available separately below) when using the stock turbo to prevent over boosting.
PM Me for some great deals!!
-Matt
__________________
321.304.4908
Sales -
Sales -
Tracking -
General Inquiries -
Old 04-09-2010, 09:21 AM   #7
Built Industries
Member#: 33839
It's Friday and im excited!! catch me while im in a fantastic mood and ull get a great deal!!
__________________
321.304.4908
Sales -
Sales -
Tracking -
General Inquiries -
Old 04-09-2010, 03:06 PM   #8
Built Industries
Member#: 33839
The day is coming to a close so place your orders now!!!
All PM's replied to!
-Matt
__________________
321.304.4908
Sales -
Sales -
Tracking -
General Inquiries -
Old 04-12-2010, 11:07 AM   #9
Built Industries
Member#: 33839
Back to the grind!!! Yes it's monday but you could make your week better by getting some new parts in the mail!!
-Matt
__________________
321.304.4908
Sales -
Sales -
Tracking -
General Inquiries -
Old 04-15-2010, 01:32 PM   #10
Built Industries
Member#: 33839
__________________
321.304.4908
Sales -
Sales -
Tracking -
General Inquiries -
Old 04-16-2010, 09:48 AM   #11
Built Industries
Member#: 33839
These LC-1's need a good home!! pick one of these up for the best price around!
-Matt
__________________
321.304.4908
Sales -
Sales -
Tracking -
General Inquiries -
Old 04-19-2010, 09:35 AM   #12
Built Industries
Member#: 33839
Grimmspeed 3-Port EBCS
GrimmSpeed introduces the most complete and easy to use 3-Port Electronic Boost Solenoid available on the market. Our aftermarket boost controller allows you to raise the OEM boost levels in a quick and efficient manner. If you try to raise the boost on the weak OEM boost solenoid it will start to become unpredictable and unable to maintain proper and safe boost levels. Using our solenoid you are able to spool your turbo quicker and maintain a rock solid boost level. We have made our solenoid to withstand 120psi, way more than any Subaru will see.
__________________
321.304.4908
Sales -
Sales -
Tracking -
General Inquiries -
Old 04-20-2010, 11:17 AM   #13
Built Industries
Member#: 33839
AEM Gauges are selling like hotcakes!! Get them while they're hot!!
__________________
321.304.4908
Sales -
Sales -
Tracking -
General Inquiries -
Old 04-21-2010, 09:40 AM   #14
Built Industries
Member#: 33839
Hallman PRO RX Boost Controller
Hallman's Pro RX kit is essentially the Pro kit with a ceramic ball instead of a steel ball. This allows for very specific boost control, and very fine adjustment for those only raising their boost a few pounds above stock. Boost can be adjusted consistently in 1/2lb increments with the Pro Rx. For those looking to add more than 5psi, the Pro RX also includes a stiffer spring.
INCLUDES:
Soft & stiff springs, 3 ft. vacuum line, mounting bracket, mounting clamp, hardware packet and instructions.
__________________
321.304.4908
Sales -
Sales -
Tracking -
General Inquiries -
Old 04-23-2010, 09:57 AM   #15
Built Industries
Member#: 33839
Default Turbo XS UTEC
Turbo XS UTEC
The TurboXS UTEC is a new concept in engine management that combines the features of a stand-alone engine management system with the simplicity of a piggyback system. The UTEC enables complete programmable control over ignition timing, fuel, and boost, while allowing the factory ECU to maintain control over basic day-to-day functions. Functions like cold start, hot start, intake temperature compensation, AC compensation and closed-loop fuel control signals are all managed by the factory ECU reducing your tuning time significantly while enhancing daily drivability. Spend more time driving and less time tuning for stock functions. The TurboXS UTEC system for your 02-07 WRX or STI provides advanced features that until now have only been available on full stand alone systems costing thousands of more.
__________________
321.304.4908
Sales -
Sales -
Tracking -
General Inquiries -
Old 04-26-2010, 10:28 AM   #16
Built Industries
Member#: 33839
If you want some new goodies now is the time!!
Auto Meter Carbon Fiber Series Gauges In stock!
Auto Meter's Carbon Fiber Ultra-Lite series is available in both mechanical and electrical gauges. All gauges consist of a carbon fiber dial, silver bezel, and a silver pointer for the ultimate in performance and style. Included are red and green colored light bulb covers for a custom night driving look. Auto Meter Carbon Fiber gauges use standard fittings, and you may need a thread adapter for certain gauges. Several gauges require additional fittings, so pay close attention to the notes. These Auto Meter gauges are available in 52mm.
__________________
321.304.4908
Sales -
Sales -
Tracking -
General Inquiries -
Old 04-27-2010, 11:12 AM   #17
Built Industries
Member#: 33839
Another day and some more great prices!! Lets us know what your looking for and we can find it!
__________________
321.304.4908
Sales -
Sales -
Tracking -
General Inquiries -
Closed Thread
AEM wideband Autometer boost and cluster Blacksails192 Interior/Dressup/Audio & Security 13 08-13-2009 06:34 PM
Zenesis alarms, Defi, STRI, Aem, Navman, Autometer, and so much more! IMPORTIMAGE Interior/Dressup/Audio & Security 96 08-06-2008 06:01 PM
Navigation under $200! Defi, Aem, Navman, Autometer, and so much more! IMPORTIMAGE Interior/Dressup/Audio & Security 232 05-01-2008 12:19 AM
IL: Home Audio electronics for sale...local sale only Shaitiger Mid West Subaru Owners Club Forum -- MWSOC 13 02-27-2003 01:03 PM
Message Board Statistics All times are GMT -4. The time now is 05:39 AM.
