Welcome to the North American Subaru Impreza Owners Club Friday February 12, 2016
Closed Thread
Old 04-01-2010, 05:53 PM   #1
idklol
Member#: 242922
Default how does the wrx/sti 2.5 engine hold up?
Just wondering if anybody has over 100k on their car, especially if it is modded. Are these engines reliable over 100k?
idklol is offline
Old 04-01-2010, 05:56 PM   #2
Deuce Cam
Member#: 130444
'85 AE86 GTS
There's a guy on a iwsti that's stage 2 and has 180,000 miles. He says it still pulls strong.
Deuce Cam is offline
Old 04-01-2010, 06:19 PM   #3
Nuke209
Member#: 108089
2003 WRX
NF Performance
a few buddy of mine has over 100k (about 120ish) on their stage 2 setups, stock engine.
Nuke209 is offline
Old 04-01-2010, 06:57 PM   #4
08EJ25
Member#: 174022
2008 WRX
Lightning Red
I have seen many modded Subi's with 100K plus. The key to any vehicle having a long life is keeping up with the maintenace.
08EJ25 is offline
Old 04-01-2010, 07:10 PM   #5
Spenk
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
You need two things:
1) proper maintenance
and
2) a good tune.
Spenk is offline
Old 04-01-2010, 07:44 PM   #6
SoCalMonarch
Member#: 142752
2008 WRX STi
depends on if its an EJ255 or 257 and from what year
SoCalMonarch is offline
Old 04-01-2010, 08:27 PM   #7
idklol
Member#: 242922
Was referring to any sti model and the 06-07 wrx in particular
idklol is offline
Old 04-01-2010, 08:37 PM   #8
SoCalMonarch
Member#: 142752
2008 WRX STi
07+ EJ257 (STI) motors don't put up with much more than 350 whp for long.. 06 and down is usually good to about 450 w/ a good tune. As for the 06-07 EJ255... I've heard people making 350-400 with em... dunno where the edge of that envelope lies exactly tho
Old 04-02-2010, 06:31 AM   #9
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
What a load of crap.
Byzantium is offline
Old 04-02-2010, 07:01 AM   #10
mopartodd
Member#: 164929
2014 Impreza Premium
Jasmine Green Metalic
Please identify said crap.
mopartodd is offline
Old 04-02-2010, 07:59 AM   #11
Gabriel69
Member#: 146218
2007 WRX
Ralley Blue
I really, absolutely, find find it quite hard to believe a stock engine EJ255 with stock casting pistons, holding 350+whp for more than 60,000 Km without blowing a piston or two........I know I blew two engines with stock pistons, first @ 50,000 Km and the second @ 8000 Km. I am currently running 296whp with my third engine, the diff is that this one has Cosworth pistons.
Have Ecutek tuned and and an aqua mist water methanol system.
So far 12,000 km, oil consumption is around 0.5 kilo per 4000 Km.
I know at least another two cars, one is a 08 sti, blew pistons @ 8000 Km and the other is a 09 sti, blown pistons @ roughly 2000 km , both engines were stock.
Gabriel69 is offline
Old 04-02-2010, 08:12 AM   #12
10046252
Member#: 242289
2010 WRX
LR. Stage 3
Every car you mod will heavily depend on your tune. If you are talking about a TBE and a tune then your car should easily see 100k + as long as you keep up with the maintenance and don't push the limits of the car. Do some blow up before 100k...yes. However, you'll hear stories about that happening with each and every car. Treat it like you'd treat Jess Beil on a first date and your Suby will last.
10046252 is offline
Old 04-02-2010, 08:54 AM   #13
Gabriel69
Member#: 146218
2007 WRX
Ralley Blue
hehe... interesting choice of words, I would say, unestablished
Old 04-02-2010, 11:35 AM   #14
Gabriel69
Member#: 146218
2007 WRX
Ralley Blue
I guess this is more typical for the 2.0 liter engines.
Old 04-02-2010, 11:59 AM   #15
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
I blew up my STI motor in an OEM un modified STI at 30k miles from the horrible oil pick up break. Luckily under warranty, just shows that nothing is indestructable.
Wil
GrimmSpeed is offline
Old 04-02-2010, 04:31 PM   #16
Byzantium
Member#: 207826
85k 2002 WRX
'06 and down handling 450 whp.
Old 04-02-2010, 05:03 PM   #17
Saopaulo54
Member#: 236677
I have a 2005 Sti and it has almost 120K on it thanks to a long assed commute to work. I haven't been easy on it by any means and I suck at maintenance. I change the oil every four thousand miles and I changed the spark plugs at around 100K. I drive it like I stole it and it has never broke down once. The only mods that I have is a 3" catless exhaust because my exhaust was so rotted from the new england weather that the cat disintegrated. I never even had it tuned. The car is a goddamn tank, and the only thing that I would have to complain about are the crappy struts (or the crap that they use to lube them) and the rear stabilizer linkage. I'm working on a new powerplant and I'm going to drive this one until the stock drivetrain turns to dust.
Saopaulo54 is offline
Old 04-02-2010, 06:37 PM   #18
JF824
Member#: 71460
2007 WRX/STi
HTA Green 11.89 @ 119
My old EJ205 I turned in with 99,000 miles on it. Ran a Big 16G @ 20psi for about 3 quarters of that with no problems. Then on the other hand I spun a rod bearing in my STi at 35,000 miles. I drove them each just as hard and maintained them just as frequently. Sometimes it will just come down to luck when going for high mileage on a modded car.
JF824 is offline
Closed Thread
how does the WRX RA differ from just a WRX? suberdave Subaru Conversions 12 03-12-2008 10:40 AM
How does the Greddy Evo 2 Exhaust sound??? Nads07 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 01-23-2007 08:41 PM
2005 Subaru Wrx Sti 2.5 Engine, Wiring Harness And Ecu Sale Silverline Automotive Engine/Power/Exhaust 1 09-14-2006 04:50 PM
How are the FXT and LGT 5 speeds holding up? loudbay Transmission (AT/MT) & Driveline 6 01-27-2005 05:46 PM
GI: What is the Demand on 2.5 Engines like? erice1984 Private 'For Sale' Classifieds 7 07-08-2004 12:58 AM
