Old 04-03-2010, 12:35 PM   #1
Tomato_88
Member#: 204277
Dark Gray Metallic
Default E85 Runs fine (so far) on 08 2.5i
I have searched around and have seen that some others were running E85 in their modified WRX's, but I was wondering if any one else is using it in their 08+ 2.5i N/A? It has not thrown the CEL yet on mine. And as far as the BUTT-O-Meter it feels like it packs a punch.Fuel economy only dropped slightly for me.
So anyone else using E85 on their stock 08+ 2.5i?
Tomato_88 is offline   Reply With Quote
Old 04-03-2010, 03:04 PM   #2
nairbmik
Member#: 220259
09 2.5i
SSM
Are you tuned for it? I'm sure it would give you a lot more results if you were
nairbmik is offline   Reply With Quote
Old 04-03-2010, 06:59 PM   #3
Tomato_88
Member#: 204277
Dark Gray Metallic
No I am not tuned for it. I was not even sure that our cars would run on it without problems. At min. I thought i would get a CEL from what I have read.
Old 04-04-2010, 10:33 AM   #4
GrundleJuice
Member#: 165749
how long have you been running 85?
Old 04-04-2010, 11:52 AM   #5
xsnapshot
Member#: 170973
2004 WRX 4EAT
So your not tuned at all, and its actually running? This is really hard to believe.
I'm not sure how OPEN/CLOSED loop works on the N/A vehicles, but let me warn you.....going WOT could be very detrimental eventually. Not as dangerous as a turbo car, but you can still get detonation too.
Are you on a winter blend at all in California? What made you decide to fill up with E85? Is it full E85, or just a %? Like 50% E85 and 50% gas?
xsnapshot is offline   Reply With Quote
Old 04-04-2010, 12:45 PM   #6
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
Stoich AFR on E85 is 8:1
On gas is 14.7
It trying to run 14.7 is 1.8-1.9, that is extremely lean and is doing damage to your engine. I'm going to call either BS or see you make a thread on your engine being done for.
Jubert69 is offline   Reply With Quote
Old 04-04-2010, 01:52 PM   #7
WagonMafioso
Member#: 222641
E85 is a waste of corn, it could be feeding hungry people right now, and they are using it as fuel such nonsense.
WagonMafioso is offline   Reply With Quote
Old 04-04-2010, 02:22 PM   #8
cmiovino
Member#: 134005
2004 WRX Premium
What does it say about E85 in the owner's manual. If it didn't say you could run it, I wouldn't be. Could be bad in the long term, if it's actually running right now.
cmiovino is online now   Reply With Quote
Old 04-04-2010, 02:39 PM   #9
BrianMR2
Member#: 238679
2007 WRX TR
Possibly one of the stupidest things I have ever heard. Corn is a renewable resource, we can grow more as the demand increases. Oil is not. Make any sense?
BrianMR2 is offline   Reply With Quote
Old 04-04-2010, 02:40 PM   #10
2.5i
Member#: 112986
N/A Cam'd & Cornfed
DOM TUNED 06 Impreza
Oh really, well lets face it E85 is creating jobs, saving family farms, and is helping the U.S. ween themselves from middle eastern oil dependency. Their are many hungry U.S. citizens out there, but the fact is there are government programs in place to help them as long as them choose to use them. Hell with the way things are going it would almost make more sense to not have a job, that is unless you make well over a 100k a year.
It sounds like your car's ecu is trying compensate for the lean fuel mixture. Just like what everyone else is saying I'm willing to bet your running lean, which means your more than likely doing some awesome engine damage. I bet after a couple more tanks the car throws a cel.
2.5i is offline   Reply With Quote
Old 04-04-2010, 02:54 PM   #11
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
the other side of that coin is overpopulation and too many people trying to live in places that can not support those numbers of subsidized people
corn isnt the issue....people IS the issue, when you get right down to the very bottom of this issue
_____________________________________________
On gas is 14.7
and the stoich for e85 is NOT 8:1
Fuel AFRst FARst Equivalence Ratio Lambda
Gasoline stoichiometric 14.7 0.068 1 1
Gasoline max power rich 12.5 0.08 1.176 0.8503
Gasoline max power lean 13.23 0.0755 1.111 0.900
E10 stoichiometric 14.0 - 14.1 ? ?
E85 stoichiometric 9.765 0.10235 1 1
E85 max power rich 6.975 0.1434 1.40 0.7143
E85 max power lean 8.4687 0.118 1.153 0.8673
E100 stoichiometric 9.0078 0.111 1 1
E100 max power rich 6.429 0.155 1.4 0.714
E100 max power lean 7.8 0.128 1.15 0.870
Old 04-04-2010, 03:06 PM   #12
jackolafedon
Member#: 232089
2007 Impreza 2.5i
Crystal gray metallic
After tuning my 07 2.5i I can tell you a few things.
1. yes the car will run, closed loop it might get close to the right lamba, but it will max out the stock AFR learning eventually.
2. No matter what without new injectors your openloop will be VERY lean, yes you will make more power but you will break something.
If you want to run e-85 get some used wrx blue injectors for cheap and get a retune for e85. That way your not running youself out of injector.
jackolafedon is offline   Reply With Quote
Old 04-04-2010, 03:06 PM   #13
Tomato_88
Member#: 204277
Dark Gray Metallic
Wow. From what I had read I thought it would either run or not run. I didnt think it would do damage. So as of now I am stopping the E85.
Old 04-04-2010, 04:13 PM   #14
Counterfit
Member#: 124254
2006 06 SGM Slowbaru
"The Scoobinator"
Default Re: E85 Runs fine (so far) on 08 2.5i
Corn is a far less efficient source of ethanol than sugarcane. Thankfully, other sources are being developed. Cellulosic ethanol isn't too far away, and there is a species of algae that produces ethanol directly from photosynthesis.
Counterfit is offline   Reply With Quote
Old 04-04-2010, 08:45 PM   #15
Jubert69
Member#: 167739
04 WRX
ej207 spec C 18g
E85 in standard engines - Wikipedia, the free encyclopedia
Clearly that wasn't my point. I guess since you proved me wrong it's okay for him to run E85
Old 04-05-2010, 01:10 AM   #16
WagonMafioso
Member#: 222641
Of course its a renewable resource,but that does not mean it will be used the right way, but my point is that instead of wasting corn to make fuel, you can feed people, simple as that.
Old 04-05-2010, 01:33 AM   #17
chazly413
Member#: 151079
2005 2.5RS RBP
too many friction losses
I agree.
chazly413 is offline   Reply With Quote
Old 04-05-2010, 05:05 AM   #18
formula91
Member#: 102984
2005 2.5RS 4EAT
Platinum Silver
Originally Posted by chazly413 View Post
I agree.
It won't matter either way. Most of the corn we use is fed to farm animals. It's not for people directly. If we all magically became vegeterian corn eaters and switched all corn production from field to sweet corn then maybe....
Even if all the corn in the US was used for fuel production, it would only meet abotu 10% of our energy needs.
Cellulose-based ethanol is the way to go. Miscanthus and Switchgrass being the most promising in the Illinois area anyway.
formula91 is offline   Reply With Quote
Old 04-05-2010, 01:51 PM   #19
Uncle Scotty
Member#: 16200
OK buy Nates beans
clearly....if he keeps using straight e85 it will blow up at some point
Old 04-05-2010, 08:42 PM   #20
GrundleJuice
Member#: 165749
this turned into an "ethics of corn fuel" debate and that gets one of these:
lets turn this into a E85 knowledge thread and actually find out something real about how these engine can use E85 when modified/tuned properly.
Old 04-05-2010, 08:52 PM   #21
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
We already grow about as much corn as our arable land can support, and it's not even close to enough.
OP: I would probably not use e85 in your car without a tune and some proper injectors (at the very least). I'd also make sure your fuel lines aren't going to disintegrate.
sniper1rfa is offline   Reply With Quote
Old 04-06-2010, 02:20 AM   #22
Tomato_88
Member#: 204277
Dark Gray Metallic
I was confident that my fuel lines were not going to disintegrate. From the research that I have done it appears that since they started using Ethanol as a fuel additive in the early 1980's the fuel systems (ie lines, pumps, filters) can handle the ethanol.
Old 04-06-2010, 02:21 AM   #23
Tomato_88
Member#: 204277
Dark Gray Metallic
+1 for this. Maybe we can help some poor idiot from making this same mistake in the future?
Old 04-06-2010, 09:57 AM   #24
coxy
Member#: 198711
1989 MV Brumby TC
The biggest issue with these fuels is they absorb water,this then leads to corrosion.
Remember also that Fuel stations generally use water at the bottom of their fuel tanks to weigh them down so in heavy rain periods the lighter Gasoline filled tanks do not try to float up through the concrete apron of the gas station,this is why you try not to get fuel just after the tanker has refuelled the station as it has stirred up the water at the bottom of the tank.
Normally this is not such an issue unless their tanks are low as Gas is lighter and floats on top of the water.
Ethanol and Methanol based fuels are hygroscopic this is an issue long term they won't tell you about.
coxy is offline   Reply With Quote
Old 04-06-2010, 06:44 PM   #25
Subarudave09
Member#: 209316
14 XV
so i asked a few ppl today about this. A Tech at subaru said No the srevice manager said no and SOA said no when i was on the phone with them regaurding my paint
Subarudave09 is offline   Reply With Quote
08 STI Wing on 08 2.5i impreza juny102004 Interior & Exterior Modification 13 01-18-2012 10:46 AM
Any news on 08 2.5i CAI? Mr.Z Impreza Forum 10 06-04-2008 12:47 AM
Tire & Wheel fitment on 08 2.5i & WRX Wagon, ideas? results? p2adan Tire & Wheel 3 05-08-2008 02:12 PM
STI or Legacy Turbo Springs on 08 2.5i? rick92008 Brakes, Steering & Suspension 6 04-16-2008 09:05 PM
no temp gauge on 08 2.5i? jordan s Normally Aspirated Powertrain 14 10-26-2007 03:36 PM
