Welcome to the North American Subaru Impreza Owners Club Monday February 8, 2016
Old 06-03-2002, 05:15 PM   #1
redmeanie
Member#: 15702
2001 2.5 RS-T LINK'D
911verion2.0TT (soon)
Smile Finally everything is here!!!
The fun begins....I finally recieved everything for my install....Tom at LUDESPEED and Andrew at AMR are outstanding individuals with allot of knowledge on aftermarket turbos....I'll keep ya'll posted on progress....
redmeanie is offline   Reply With Quote
Old 06-03-2002, 07:25 PM   #2
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Looks like fun. I was gonna ask about the CD, but noticed the Link logo.
Old 06-03-2002, 07:46 PM   #3
In2Deep
Member#: 10651
2013 WRX - Silver HB
04STI(sold) 06STI(sold)
Lucky Bastard!
In2Deep is offline   Reply With Quote
Old 06-04-2002, 02:36 AM   #4
hayscoob
Member#: 4544
2004 STi Aspen White
Bone Stock for now
Damn that stuff looks familiar! I havn't seen my car for so long I forgot what it looks like. Big ass top mount intercooler. Great kit, you will like it.
Paul...
hayscoob is offline   Reply With Quote
Old 06-04-2002, 03:21 AM   #5
Delicious Tuning
Member#: 1990
Looks great, just like the other two I have installed. Just want to let you know everything fits in pretty well. The only thing I noticed was you will need t cut the pipe that goes from the Turbo to the Intercooler. It seems to be a little on the long side. Besides that though, everything runs nice...
Glad to see you got a Link to control your engine management. Life will be a lot easier with that.
So what are you doing about the fuel line conversion? Did Tom send you an adaptor to make the conversion? It is worthwhile to do that modification.
Delicious Tuning is offline   Reply With Quote
Old 06-05-2002, 12:38 AM   #6
hayscoob
Member#: 4544
Bone Stock for now
Skywalker is right about the charge pipe. It's too long. It wound up placing the intercooler to high and it started to bang up against the flange just below the hood gasket. I cut almost 2 inches from the pipe to allow the intercooler to sit under the flange that supports the hood gasket. Also, don't use the supplied gaskets with the Tial Wastegate. They will blow out in a couple of days. Go flange to flange with no gaskets. Trust me, it will work. I had a hell of a time with this. The metal between the two is so flat, it seals up 99.9%. If the metal is not flat enough on the Ludespeed supplied up pipe you may need to file it flat. I had to do this to stop a horrible exhaust leak before the wastegate. You may also need to clock the turbo as well, so check that out. Make damn sure if you use a RRFPR that you hook that up right. Once you get the OEM cat/cats pipe out of the car the and the down pipe installed you may find a rattle or to from the heat shielding. Just bend them out of the way. There are no hangers or support brackets with the new Ludespeed down pipe and as a result of the movement of the down pipe you get the rattles on the heat shielding. Nothing major. I plan on having a bracket welded on to attach to the factory support. That should make it way stonger and move less at idle. Once all of the little bugs are out you will enjoy the kit alot. The rush is worth it all. Good luck...
Paul...
"Summer is here!" June spotted thread! Leonardo South East Region Forum 163 07-01-2010 06:17 PM
Finals Week is here! Study! druxboyz Off-Topic 27 05-14-2008 06:39 AM
well everything is finalized jnorth85 Baja Forum 14 03-09-2006 10:18 PM
Finally!! Our MINI Cooper S is here! Coati Southern California Impreza Club Forum -- SCIC 45 02-25-2003 05:59 PM
Woohoo my car is here finally!!! Dolphin Overton Rocky Mountains Impreza Club Forum -- RMIC 9 01-19-2002 01:42 AM
