Old 04-03-2010, 05:09 PM   #1
FourOnTheFloor65
Member#: 106225
02 WRX STied PSM
03 L, 05 GT Legacy Wagons
Default Penetrating oil comparison
Well this is sort of tool related so I figured this forum would be a good place to put it. I found a great penetrating oil comparison from Bob Is The Oil Guy's site. They tested several of the more popular products (WD-40, PB Blaster, Liquid Wrench, Kano Kroil) and a home brew made from ATF and Acetone.
I have always used PB Blaster, but I have recently been considering ordering some Kano Kroil. My friend, who works at an aircraft composites lab and machine shop has been raving about it. I have also heard a lot of local gurus talk about home brews using a solvent and some kind of oil. I didn't realize just how good the home brew can be. Here is the comparison...
http://www.bobistheoilguy.com/forums...Number=1433151
FourOnTheFloor65 is offline   Reply With Quote
Old 04-03-2010, 06:06 PM   #2
razrielle
Member#: 205698
Makes me wonder how long it was soaked for, and what the price per oz difference between them
razrielle is offline   Reply With Quote
Old 04-05-2010, 10:41 AM   #3
iluvdrt
Member#: 46248
82 Brat
Tan
WOW, these guys are oil dorks. I think I learned more about oils in 5 minutes reading their forums, then 7 years on NASIOC LOL.
<---off to read more about oil.
iluvdrt is offline   Reply With Quote
Old 04-05-2010, 01:31 PM   #4
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
LPS makes a pretty good penetrant as well
Old 04-06-2010, 12:12 AM   #5
Storm
Member#: 5218
96L Most Over-
Developed Beater
I'm a believer in Kroil. Though a shopmate has brought in a couple cans of stuff by BG (Barry Grant, or carb guys?) that seems to work better......I forget the name of the stuff at the moment. We get alot of use from our penetrating oils up here in the land of orange barrels and salt.....
Jay
Old 04-06-2010, 12:31 AM   #6
XanRules
Member#: 157348
1996 JNCO Jorts
Stonewashed Denim
I always knew Liquid Wrench was better than PBlaster.
XanRules is offline   Reply With Quote
Old 04-06-2010, 02:24 AM   #7
Uncle Scotty
Member#: 16200
OK buy Nates beans
GM rust penetrant and inhibitor heat valve lubricant #1052627 is also one of the better things you can spend $$$ on
Old 04-06-2010, 08:28 AM   #8
coxy
Member#: 198711
1989 MV Brumby TC
Wurth Rostoff is pretty good as it the Loctite freeze spray with penetrating oil in the mix as it also in conjunction with a heat gun will use expansion and contraction to free stuck components.
coxy is offline   Reply With Quote
Old 04-07-2010, 12:16 AM   #9
afohlin
Member#: 240629
good to know that PB Blaster actually does work better than just WD-40, but its pretty amazing a simple acetone-atf mix is so much better
afohlin is offline   Reply With Quote
Old 04-07-2010, 12:40 AM   #10
FourOnTheFloor65
Member#: 106225
02 WRX STied PSM
Liquid Wrench used to make a freeze spray with a penetrating oil in it, too. It was terrible. It seemed like you had to use half the can for one stuck bolt. The Loctite stuff might be better though, I don't know.
Uncle Scotty: Do most dealers carry that GM stuff at the parts counter, or does it usually need to be ordered? What's the cost on it? I might give it a try next time. GM seems to have a history of creating fluids to solve some of their quality/engineering issues (synchromesh). It makes sense that they would make a good rust eating oil. Next they need to make an interior spray that makes the materials, fit, and finish magically not suck.
Old 04-07-2010, 01:42 AM   #11
Uncle Scotty
Member#: 16200
OK buy Nates beans
it is available at the parts counter....it is quite $$$ at ~$11/can.....BUT
I know a subaru master mechanic who swears by the stuff......and it has done some things that left us
it managed to penetrate a rusted to hell lateral link bolt on an old 99 RS within about 20 or 30 minutes.....got that bolt out without torching it or cutting it....after EVERYTHING had been tried---it was quite seized, no doubt
Quite shocking
if the local gm dealer haddnt closed up I'd have a can right now....now the closest GM dealer is ~15 miles
as far as the rest of that....
Old 04-11-2010, 09:06 AM   #12
jechlu
Member#: 235621
2005 STi
I use AD3000 its not expensive and works wonders on seized bolts and any type of mechanical mechanisms
Doors, latches.
jechlu is offline   Reply With Quote
Old 04-11-2010, 10:58 AM   #13
eugesubu
Member#: 180235
has any body ever tried LPS fluid? I have used it for a long time in my machine shop, it does wonders soaking on rust and protecting parts that have just been machined. I use particularly the LPS 2, however the kb88 is good stuff too.
http://www.lpslabs.com/product_pg/lu...Lubricant.html
eugesubu is offline   Reply With Quote
Old 04-11-2010, 06:34 PM   #14
SportyMark
Member#: 167263
02 WRX Sedan
GM heat valve has worked more wonders than any penetrating oil I have ever seen! we use it almost exclusively at our shop
SportyMark is offline   Reply With Quote
Old 04-11-2010, 06:50 PM   #15
WRXDK
Member#: 187983
2005 WRX
kroil is awesome. i have a gallon can in my shed, love it. it is the best penetrating oil i have ever used.
i still use pb blaster most of the time.
WRXDK is offline   Reply With Quote
Old 04-11-2010, 10:06 PM   #16
dan az
Member#: 120355
2004 wrx wagon 2.5
20g-xt, super slow
im always kinda surprised that wd-40 is sold and marketed as a penetrating oil, its not bad for that task even though it is meant as a water dispersment.
dan az is offline   Reply With Quote
Old 04-12-2010, 01:33 AM   #17
Uncle Scotty
Member#: 16200
OK buy Nates beans
wd-40 is **** for just about anything but drying wet electrics/ignitions and getting **** off paint and glass...and maybe the squeaky bathroom door hinge
I always liked the liquid wrench for 'buy it anywhere' penetrant
but that GM stuff is and when I get around to getting a can or 2....it will in my box along with LPS2 and Neo HP800 grease(THE BEST EVER) as the MUST HAVE stuff
Old 06-05-2010, 09:19 PM   #18
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
I have to try kroil when my PB blaster runs out.. I hear some good stuff about it.
SubaruImpreza_power is offline   Reply With Quote
Old 06-06-2010, 11:04 PM   #19
yarrgh
Member#: 80465
2001 2.5RS
Black Diamond Pearl
My brother is an aircraft mech. and swears by kroil. I'll have to get some one of these days and post back on how well it does.
Old 06-07-2010, 12:13 PM   #20
Honest Bob
Member#: 94698
2005 30R Wagon
CGM
Liquid wrench is better than pb blaster? Never would have guessed.
Honest Bob is offline   Reply With Quote
Old 06-07-2010, 12:29 PM   #21
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
seems like everything else but WD-40 is better then PB blaster?
Old 06-08-2010, 09:39 AM   #22
BoostinChick
Member#: 218971
2007 WRX
ATF-Acetone mix
Cheap, effective, looovveeee the smell.
On a side note: I have also used a product made by Castle called Thrust. I use to own/work on a 4Runner (rusty POS) and this product did well for the hard to reach places. It comes out as a foam so it really sticks to where you shoot it, instead of bleeding/dripping off like PB Blaster/WD-40.
BoostinChick is offline   Reply With Quote
Old 06-08-2010, 10:03 AM   #23
SubaruImpreza_power
Member#: 13910
1997 Legacy outback
blue
^ Does Kroil drip?
Old 07-02-2011, 04:48 PM   #24
dpbgst13
Member#: 106582
2002 Suspension mod
Siegel Tuned FP GREEN
Default strike force
Strike Force is the best thing I have ever used.
It was made for the military for guns. All I have to say is try it out.
dpbgst13 is offline   Reply With Quote
Old 07-02-2011, 09:33 PM   #25
vr6vdub172
Member#: 287291
01 VW
I usually use pb blaster. It does pretty good on rusted under car components that go through winter conditions That and a few taps with a mallet as well and its usually apart. Have had instances where it has not worked though. Think im going to brew up some home mix ATF/acetone and try that out next time. Good find on the testing of penetrating chemicals.
vr6vdub172 is offline   Reply With Quote
Oil filter comparison, 4 top brand oil filters cut up and compared. Paranoid Fabrications Service & Maintenance 203 04-19-2016 07:43 AM
Best penetrating oil? WD40, Liquid Wrench, PB Blaster... JoeTX Newbies & FAQs 39 05-26-2005 09:00 PM
FYI oil comparison srad711 Service & Maintenance 5 03-30-2005 02:06 PM
Motor oil comparison guide by API Craig02WRX Service & Maintenance 5 12-24-2004 03:19 AM
3in1 penetrating oil works well to quite your sway bars ciper Brakes, Steering & Suspension 6 07-16-2003 08:06 PM
