Old 04-03-2010, 07:58 PM   #1
f4phantomii
Member#: 58504
2004 STi w/o wing
Aspen White / Silver
Default Yet another reason I'll never buy another domestic....
I was helping my 75 yr old Father in Law replace the front disc brakes on his 2007 Dodge Ram pickup. Yeah...it's a 5.7l HEMI and he tows a big travel trailer withit a lot.
He said he'd noticed some shudder and thought the brakes might be worn out and wanted to replace them. He asked if I'd help him get it jacked up and on stands so he could could replace the pads over the next several days.
The man had his knee *replaced* 4 weeks ago and he was going replace his brakes?!? I told him I'd help and we could just go ahead and get it done in a couple of hours.
We removed the wheels and he went looking for a socket to fit the bolts holding the brake housing onto the brake flange. I reached around the back of the rotor and put my fingers on the bolt. I could turn this 1/2-inch bolt with my fingers!. No wonder he was feeling a shudder! Every foreign car I've ever seen has lock washers on these bolts....not on a Dodge apparently.
We got the calipers off and saw some really uneven wear on the pads. The 1/4-inch steel plate of the pad had been bent. Geez.
All this because they had to save $0.50 on 4 washers.
IBcoolbrostory
f4phantomii is offline   Reply With Quote
Old 04-03-2010, 08:05 PM   #2
Integra96
Member#: 64196
2010 Family Sedan
Wow, that's a well thought out reason to never buy a "domestic" car.
Integra96 is offline   Reply With Quote
Old 04-03-2010, 08:08 PM   #3
Baja820
Member#: 196860
2014 TAKE OFF
YOU HOSER!!!
whoa that is crazy... but for towing heavy trailers you really cant beat a big domestic diesel ie. Cummins. ive had three 3/4 ton dodges and never had an issue with the brakes shaking or wobbling weird.
Baja820 is offline   Reply With Quote
Old 04-03-2010, 08:28 PM   #4
SedonaScooby
Member#: 143522
1987 Brat GL 4 Speed
98 Forester L (RIP)
cummins is the ish for diesel trucks
SedonaScooby is offline   Reply With Quote
Old 04-03-2010, 08:33 PM   #5
Hondaslayer
The toast of OT
Member#: 4562
1995 Legacy LSi
1998 Forester, lifted.
It's a 2007 and he tows a trailer, I'm sure the brakes have been done before or at least inspected and the bolt was left loose at that point.
Lock washers will not fix a lack of torque.
Old 04-03-2010, 08:38 PM   #6
GriffinREX
Member#: 36054
I drive a 06 Dodge and have had no brake issues whatsoever.
GriffinREX is offline   Reply With Quote
Old 04-03-2010, 08:42 PM   #7
Russ77
Member#: 69369
^ this.
in high vibration environments, lock washers can actually cause bolts to loosen more than not having lock washers.
Russ77 is offline   Reply With Quote
Old 04-03-2010, 08:55 PM   #8
f4phantomii
Member#: 58504
2004 STi w/o wing
Sadly no, this is the first time the brakes have been touched. It's just out of warranty. Brakes on the other wheel still had about 60% of the pads left. He uses the trailer brakes a lot when slowing.
It probably was torqued properly at the factory and came loose over time. BTW, there are now lockwahers on the bolts so it won't happen again.
Old 04-03-2010, 09:43 PM   #9
Meat Supply
Member#: 137902
---- by all means,
keep your dick out!
i think it's funny when these little things come up and that's the deal breaker.
Meat Supply is online now   Reply With Quote
Old 04-03-2010, 09:48 PM   #10
chkltcow
Member#: 10814
'13 ToyobaruFRZ-86
97 Miata M
There is something about Chrysler, I'd say. We have a 2004ish Jeep Grand Cherokee as a company vehicle. That thing warps rotors like they're going out of style. Our other company cars, a Mercury Mountaineer and a Ford Explorer.... they're fine. But that Jeep has been through 3 sets of rotors in 60,000 miles.
chkltcow is offline   Reply With Quote
Old 04-03-2010, 09:52 PM   #11
finnRex
A. Moderator
Member#: 21095
RIP KTH & LMFH
'09 Crystal red Tintcoat
Are the wheels overtorqued? If you overtorque or improperly(unevenly) torque the lugs that can cause a rotor warpage.
I had a '96 Mustang that had problems with warping rotors too, and torquing to proper specs helped out.
Mika
finnRex is offline   Reply With Quote
Old 04-03-2010, 09:56 PM   #12
Dolphin Overton
Member#: 1925
01 A4 89 944s2
13 Speed 3R 99 Sprint
all cars fall apart. big deal
Dolphin Overton is offline   Reply With Quote
Old 04-03-2010, 09:57 PM   #13
chkltcow
Member#: 10814
'13 ToyobaruFRZ-86
97 Miata M
Mika
You'd have to ask the local Chrysler/Dodge dealership that does the service on it. I just find it odd that even from the factory it had the problem and it has persisted ever since.
Old 04-03-2010, 10:00 PM   #14
f4phantomii
Member#: 58504
2004 STi w/o wing
My bad....thread title should have been "Reason #327 I'll never buy another domestic...."
I've got a GMC Acadia....by most accounts one of the best vehicles GM ever produced. It's our first domestic (and last) vehicle.
We've had it in the shop at least 300% more than all of the other vehicles we've ever owned put together. And eveytime it goes in, it comes back with another problem.
It's a shame really....we love the vehicle....but the poor reliability is so stereotypical it's almost funny. The next problem that crops up with it will get it traded in on either a Honda Pilot or Toyota Highlander.
Old 04-03-2010, 10:05 PM   #15
Meat Supply
Member#: 137902
---- by all means,
keep your dick out!
i like most cars all the same. they all have their own problems. my cav z24 had a few quirks (i know, i know, not the best car) . i did the normal work to it. struts, power steering hose, wheel bearings, brakes, only one new caliper and brake line. rear brakes only once.
it was a good car. what did it in? blew a head gasket and the rest was history. i've had a few other domestics too, but i like my mid 90's subies the best so far.
Old 04-03-2010, 10:08 PM   #16
Garwin
Member#: 105621
Sounds kinda like when the Viper beat the Vette somewhere in Illinois. Yeah!
Garwin is offline   Reply With Quote
Old 04-03-2010, 10:36 PM   #17
f4phantomii
Member#: 58504
2004 STi w/o wing
Nope....lugs were spot on where they should have been.
My FIL wanted to have the rotors turned and I was trying to talk him out of it. For the price most places charge to turn them you can buy new aftermarket ones and install them yourself.
As it turned out, the rotors were in excellent shape. Very smooth and perfectly flat.
With new pads and everything torqued down properly it drove and stopped perfectly.
Old 04-03-2010, 10:58 PM   #18
silver2004impreza
Member#: 127878
2004 Impreza 2.5TS
2004 Outback sedan H6
According to the local Dodge dealer (before they went out-of-business), the rotors on the newer Dodge trucks are composite and shouldn't be turned.
silver2004impreza is offline   Reply With Quote
Old 04-03-2010, 11:03 PM   #19
Sting_Ray1502
Member#: 188814
2009 Ford Focus
Gold
Don't ever go by how the vehicles are rated especially from GM. I work for a GMC dealer, and EVERYTIME I see one of those, I cringe. The media hyped them up so much, but they have so many problems.
Sting_Ray1502 is offline   Reply With Quote
Old 04-04-2010, 12:03 AM   #20
Jessie James
Member#: 2072
I hope you did not use "hardware store" lock washers. Did you use lock washers that are designed for heavy torque and high heat? If not, they are probably going to spread open and then all the caliper bolts are going to come loose.
You may want to use the "star" type or Nord washers instead.
Jessie James is offline   Reply With Quote
Old 04-04-2010, 12:32 AM   #21
nayeliesuncle
Member#: 165137
The Jeep Grand Cherokees and the Jeep Liberty are notorious for going through front brakes every 30k miles or so.
My dad has a Liberty and it is like that.
The loose bolt is not uncommon. Your dad should do proper regular maintenance. It includes inspecting the brakes on a lift to verify the conditions of the components.
So, it's his fault.
nayeliesuncle is offline   Reply With Quote
Old 04-04-2010, 12:41 AM   #22
just smurfy
Member#: 135893
2012 Smart Car
murdered out w/ stickers
My co-worker bought a new 2009 Ram 1500 with the big-ass engine - the 5.7L Hemi I guess? It had a steering wheel shudder since it was driven off the lot. The dealership couldn't fix it (couldn't track down the issue) and so after months of verbal wrangling with the dealership he got a new 2010 Ram 1500.
Obviously they have quality control issues.
just smurfy is offline   Reply With Quote
Old 04-04-2010, 12:42 AM   #23
ScubaruImpreza05
Member#: 74041
2006 2012 Weee-strom
SV650 For sale
I'll buy a domestic vehicle; CTS-V. I'll admit it, I like just about everything it is (besides the fact that it is domestic since I also have about 30 reasons to not like domestic spanning several vehicles). Besides that, I'll stay away for a bit until they prove themselves again. The worst case I've seen is that craptastic CVT they put in the first gen Saturn Vues. Those transmissions will never last past 100k, rarely past 75k, and some have died at 25k. They are obviously a terrible transmission. My mother's Vue was in the shop once every 2 months with random slipping (starting at mile freaking 13,000) that they never fully cured. They'd reset the ECU, ship it out. Rinse, repeat. She asked for a new transmission after about the 15th time in the shop and they wouldn't do it. Finally the trans completely went at 65,000 miles and GM stopped making them, do not support them, and charge $5,000 to locate and replace one.
ScubaruImpreza05 is offline   Reply With Quote
Old 04-04-2010, 12:43 AM   #24
just smurfy
Member#: 135893
2012 Smart Car
Composite?
Or alloy?
Old 04-04-2010, 12:47 AM   #25
2003specv
Member#: 47130
This. You'd be retarded not to want a V.
2003specv is offline   Reply With Quote
I'll never need another fortune cookie. Prod Off-Topic 4 11-02-2006 10:17 AM
Yet another reason to never street race. south_texas_scoobie Off-Topic 33 08-23-2006 05:14 PM
Yet another reason not to buy a rental car speaker General Community 37 08-27-2005 01:51 AM
I'll never install another swaybar mount kit again Siper2 Brakes, Steering & Suspension 21 09-03-2004 10:31 PM
Why I'll NEVER buy a EVO newscooby General Forum Archive 22 02-17-2001 01:38 AM
