Old 04-04-2010, 04:00 PM   #1
huey1133
Member#: 206126
2003 wrx
black
Default all gears are hard to engage
I was drivin my 03 wrx today just cruising not driving hard or anything. i went to shift from 2 to 3 and it didnt go into to gear right away. i pulled over and did a quick check and everything looked and felt ok. as i kept driving it became harder to go into any gear. even when parked and just trying to go thru the gears every gear is difficult to get into gear. about a year ago i had the tranny worked on and had some broken syncros replaced. i really dont want to go thru that expensive process again. any ideas or advice would help. possibly syncros? forks? gears? im planning on changing the gear oil when i get time this week. my gear oil only has maybe 2000 miles on it. i used redline 75w90ns. any help would be appreciated.
huey1133 is offline   Reply With Quote
Old 04-04-2010, 07:14 PM   #2
flstffxe
Member#: 155358
2008 Forester
Steel Silver
Clutch not fully disengaging?
How does it shift with the engine not running?
flstffxe is offline   Reply With Quote
Old 04-04-2010, 10:54 PM   #3
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
shaft nut backed out, mebbe
Old 04-05-2010, 12:22 AM   #4
iht
Member#: 196742
2000 Impreza 2.5rs
tried double clutching?
iht is offline   Reply With Quote
Old 04-05-2010, 12:35 AM   #5
Uncle Scotty
Member#: 16200
OK buy Nates beans
yew didnt READ the OP.....didya
Old 04-05-2010, 05:23 PM   #6
scoobdude
Member#: 50699
2004 WRX
Platinum Silver
loose shifter linkage?
scoobdude is offline   Reply With Quote
Old 07-28-2013, 02:15 PM   #7
shaneSC
Member#: 243074
2003 WRX
Sorry to bring this thread back, but I'm having a similar problem. 03 WRX 53k miles stock 5MT, engaging all gears is hard and not smooth, but no grinding. I've tried with the car off and clutch engaged, and some gears, ie. 3-4, are completely blocked out.
This issue wasn't present for a few months after I bought the car, and shifting felt perfect. Then suddenly one day after a long cruise in the highway, I pulled over and shifting felt much harder to engage. Still drivable, but not nearly the same feel. I don't abuse the transmission, and have switched to Extra-S hoping to cure it, but it hasn't helped.
I was thinking clutch engagement wasn't releasing, but the issue shouldn't persist with the at off, right? My next thought is linkage, but what is it that could be off? Worn bushings or an actual adjustable mechanism?
Any help is appreciated.
*EDIT* One other note, sometimes when I'm at a light, I engage the clutch and try to shift to 1st, I get blocked out and have to reclutch one or twice before it will engage.
shaneSC is offline   Reply With Quote
Old 07-28-2013, 04:04 PM   #8
scoobdude
Member#: 50699
2004 WRX
Platinum Silver
check your fluid level for the clutch?
Old 07-28-2013, 06:17 PM   #9
Uncle Scotty
Member#: 16200
OK buy Nates beans
and is the linkage and linkage bushings ok??
Old 07-28-2013, 10:24 PM   #10
shaneSC
Member#: 243074
2003 WRX
Clutch fluid is OK. Is there a way to adjust the linkage? I'm considering getting new bushings, but I wanted to see if there's anything to check on before ordering. Are there any clear signs of the bushings being bad? Seems strange that it so suddenly started, if its simply worn bushings...
I have the FSM's, but don't recall seeing anything in there about adjusting the shifter linkage. Maybe I just missed it?
Thanks in advance.
Old 07-28-2013, 10:39 PM   #11
Uncle Scotty
Member#: 16200
OK buy Nates beans
there is no adjustment but the pivot studs can break and teh bushings can get squished out of shape and the stock ones are garbage anyway
Old 07-29-2013, 12:21 AM   #12
shaneSC
Member#: 243074
2003 WRX
OK, good to know. I'm gonna go ahead and order some new bushings and hope that it makes things smooth again. Thanks for the help!
help 1st gear sticking/hard to engage as well Rod702 Transmission (AT/MT) & Driveline 26 01-10-2010 02:35 PM
Reverse gear hard to engage. C-grunt South West Impreza Club Forum -- SWIC 21 10-05-2007 10:42 AM
06 STi 1st and 2nd gears are hard to shift when cold? 06slvrsti Transmission (AT/MT) & Driveline 6 02-22-2007 01:13 AM
Hard to Engage 1st and Reverse rich728 Transmission (AT/MT) & Driveline 11 04-01-2006 11:16 AM
Reserve is hard to engage 3 out of 5 times... Is this normal? MrP0nch0 Technical Forum Archive 23 08-29-2000 05:28 PM
