Old 04-04-2010, 06:39 PM   #1
neo277
Member#: 131432
2004 WRX on Ignite E
Gtx3076 - 07 6mt
Default 07 sti 6 speed leaking gear oil from bell housing
Hey Everyone.
I have an 04 wrx with an 07 sti 6 speed and as i got home the other day i noticed i was leaking some redline smurfblood from my tranny. I checked the axle seals and the rear part of the trans where the DS slides in and those seals were good.
Then i noticed it leaking from the front bottom section of the bellhousing, right at the front section on the bottom where you can look through and see the cluch cover. Also i took the rubber cover off the top of the clutch fork and noticed some gear oil on the clutch fork.
Anyone ever run into this issue. I believe its the input shaft bearing/seal.
Anyone ever have this problem and how much would it cost to replace?
thanks everyone
neo277 is offline   Reply With Quote
Old 04-04-2010, 07:10 PM   #2
DZnutz
Member#: 91837
i believe that the transmission must be disassembled in order to replace that seal... GL
DZnutz is offline   Reply With Quote
Old 04-04-2010, 07:20 PM   #3
neo277
Member#: 131432
Gtx3076 - 07 6mt
Default trans
Just my luck.
Old 04-05-2010, 12:08 AM   #4
mick_the_ginge
Citizen Mick
Member#: 27646
2003 Sleeved 2.5
Oil Dry Sump Goodness
How does your pilot bearing look? Input shaft leaks like this are usually due to a failed pilot bearing.
mick_the_ginge is offline   Reply With Quote
Old 04-05-2010, 07:27 AM   #5
neo277
Member#: 131432
Gtx3076 - 07 6mt
Default trans leak
Hey
Not sure because i haven't pulled the trans yet. I replaced the pilot bearing with a new one when i put my new ACT clutch in about 1500 miles ago, so it should be in good shape but who knows until i actually pull the trans and see.
Do you know how much something like this would cost to repair?
Old 04-05-2010, 09:22 AM   #6
AndrewtechAutomotive
Member#: 99694
2002 dogbox,'11 wrx
You need to fix it straight away. If the pilot bearing is not present or isn't keeping the input shaft stable, the front seal will leak.....but other really bad things could happen if you don't take care of that situation asap. Just play it safe and don't wait to fix it. I would think front seal job would run around $800??
Andrew
AndrewtechAutomotive is online now   Reply With Quote
Old 04-05-2010, 10:47 AM   #7
neo277
Member#: 131432
Gtx3076 - 07 6mt
thanks everyone. getting it worked on asap.
Old 04-06-2010, 04:23 PM   #8
neo277
Member#: 131432
Gtx3076 - 07 6mt
Default trans
Andrew
Hey Andrew
Does the 07 sti 6 speed need to be split open to repair the i/s seal/bearing?
Thanks
Ziad
Old 04-11-2010, 02:25 PM   #9
04stigeorge
Member#: 177402
05 STI and 08WRx
blue and white
Default front seal
If you r in a pinch, I've replaced the front seal with some self tapping screws a chissel and a slide hamer with only removing the 4 10mm bolts that hold the guide. We did one in a winter rally..no time to do a teardown.
04stigeorge is offline   Reply With Quote
Old 04-12-2010, 07:57 PM   #10
neo277
Member#: 131432
Gtx3076 - 07 6mt
So got the problem fixed. Turned out be the pilot bearing failed. thanks for all the help guys
Ziad
Master swap list for 04-07 Sti 6 speed into WRX crashtke Transmission (AT/MT) & Driveline 808 08-12-2015 09:01 AM
06/07 STi 6 Speed Cost From Dealer suby25 Transmission (AT/MT) & Driveline 9 08-28-2009 04:12 AM
WTB: 06/07 STi 6 Speed Tranny knakai1 Private 'Wanted' Classifieds 3 08-21-2008 02:05 AM
testing waters..... 07 STI 6 speed tranny with only 1,000 Miles!!! WRXINTX Drivetrain 14 03-08-2008 12:13 AM
My Car's Been Blessed With 07 STI 6-Speed Goodness! ScoobyNubieToo! Tri-State Area Forum 18 03-21-2007 06:39 AM
