#1 |
Member#: 14578
Vehicle:2002 WRX Wagon PSM |
It recently got a little warmer here and when I turned on the AC I noticed it wasn't blowing cold at all. When I looked at the compressor, it wasn't spinning either so I put in a can of R134a. It was cold for about 10 minutes and it just got warm again. The compressor was still spinning but warm air just came out. I turned the car off and came back later on and turned the A/C back on and it was cold again for 5-10 minutes, sometimes warm air will just come out without any cold at all for any time. Is my compressor going bad?
#2 |
Member#: 216675
Vehicle:07 Impreza WRX UGM |
do you have it on recirculate? i know sometimes if you have it bring in fresh air it does not get as cold. also you might have a ac line leak somewhere, or just need to get the system drained and refilled.
#3 |
Member#: 14578
Thanks CS,
no one has another clue besides a flush? |
#4 |
Member#: 3782
South East
Vehicle:02 WRX WFC#040 Clean on 19's |
leaky seals.
#5 |
Member#: 17252
Vehicle:'06 WX8 59E |
A set of gauges is necessary to come up with a meaningful diagnosis.
For example, it would help to know how the readings change once it stops blowing cold. |
#6 |
Member#: 14578
I don't have any guages to plug in to see whats wrong. All that happens is that when the car is first turned on, it will be ice cold for 5 minutes. Then it would go warm totally.
#7 |
Member#: 40453
South East
If this is an intermittent problem it could be the expansion valve sticking. You should not keep attempting to run the ac until you get this sorted out cuz if that is the problem the pressure is going sky high in the system and it can ruin the compressor (I actually had the discharge hose explode before from this) You need a set of manifold gauges and you need to know how to read them to determine what the problem is. Dont keep dumping refrigerant in there assuming that you have a leak cuz if it has a full charge you are just gonna make matters worse. If it was low on refrigerant it would blow warm air all the time and if it was low enough the compressor wouldn't turn on at all. Do a search for expansion valve and read up on it.
#8 |
Member#: 157348
South East
Vehicle:high impact sexual violence |
call the amberlamps, sounds like you're leaking.
#9 | |
Member#: 14578
what's the amberlamps? Also, a little update... I noticed that everytime I turn off and turn the car back on, the AC would be ice cold again. 5-10 minutes later, it gets warm. Turn off the car, then back on and it's cold again. |
#10 |
Member#: 40453
South East
If it was low on refrigerant it would be warm all the time. It is not leaking.
#11 |
Member#: 14578
#12 |
Member#: 40453
South East
No. if the compressor is turning and it is intermittently blowing warm and cold air it is not electrical. If it was electrical the compressor would not turn on. A sticking expansion valve will cause the symptoms you are describing. Next time you turn it on, when it starts blowing warm air check and see if the compressor is turning. If the compressor is turning and it is blowing warm air, there is either a blockage (like a stuck expansion valve) or another thing I have seen is the radiator fans not turning on. I have seen a car build up really elevated high side pressure because the fans were not pulling any air through the condenser while the compressor was on. This is probably not your problem cuz the car would also be overheating if the fans were not on. There are a couple other possibilities such as the blend door being stuck but it would also blow hot air all the time
#13 | |
Member#: 14578
thanks again. |
#14 |
Member#: 40453
South East
I would be surprised if that is not your problem. It is easy enough to swap out. I have never seen them go that cheap. 48 bucks is a steal if it is the right one. Remember to get some new 0 rings. You will need two of them and they are two different sizes. you can get a pack of multiple sized o rings from autozone for about ten bucks. They will also loan a vacuum pump and manifold gauges to you so that you can vacuum it down and charge it back up.
#15 |
Member#: 14578
Yup, actually did a search on Autozone and Pepboys, they have it for even cheaper. Brand new expansion valves for $22
#16 |
Member#: 112359
BAIC
Vehicle:02 WRX VF39 - Sold |
Which expansion valve did you go with? Kragen or Autozone? I'm having the same problem as you and I think it's worth trying out. Let us know how it goes. Thanks
#17 |
Member#: 14578
update: ordered one from autozone, came out to be $30 with shipping. I'll be putting it in tomorrow or the day after depending on sunlight when i get home from work. It looks exactly like the pictures I've seen posted online.
#18 |
Member#: 40453
South East
Don't forget the o rings.
#19 |
Member#: 14578
Yeah, the one from autozone came with o rings so i didn't buy any. I got around to change it out today and noticed that the o rings that came with the valve were thinner than the ones on the car. I went around to a local auto store, autozone and strauss and couldn't find any o rings at all. So I inspected the ones that were on the car and cleaned it off. None of the o rings looked ripped so I threw it back on.
Haven't vaccumed the system and refilled it yet since it took me a while because it's in such an awkward position. I'll follow up tomorrow after I vaccume and refill. |
#20 |
Member#: 40453
South East
Barring any leaks, all should be well. If it won't hold a vacuum it is probably leaking by those o rings. If they looked like they were in good shape you might be ok with it.
#21 |
Member#: 14578
quick update. Had the A/C system vaccumed today and refilled it with 2.25 bottles of r134a. It looks like it did the trick, everything seems to be holding up good, might need another 1/2 can or so of refridgerant. Thanks Ricky.
#22 |
Member#: 40453
South East
That seems like a lot of refrigerant. I believe it is only supposed to take 16-19 ounces....maybe my memory is bad though.
#23 |
Member#: 40453
South East
yep. just went outside and checked. It only needs 16-19 ounces. Bout a can and a half. I guess you have 12 ounce cans. Too much of this stuff won't make it cool better. If you look right in front of the radiator closer to the drivers side there is a sticker that tells you how much r134 to fill it with.
#24 |
Member#: 14578
okay cool, when I asked the mechanic they told me about 3 cans... I'll go release some of it.
#25 |
Member#: 141781
Vehicle:2012 Dickstorm |
I have this same issue. How hard is the expansion valve to replace? Are there directions anywhere?
| Thread Tools | |
| Display Modes | |
| A/C Not Blowing Cold? | d0ugch0i | Car Care & Detailing | 8 | 04-15-2010 11:09 PM |
| AC not blowing cold air | b0red@werk | Service & Maintenance | 6 | 07-02-2009 05:23 PM |
| AC filled w/ freon...blows hot, refilled...blows cold What gives? | dingo dave | Service & Maintenance | 3 | 04-26-2009 08:06 PM |
| Why is my a/c not blowing ice cold ??? | boostedsti06 | Factory 2.5L Turbo Powertrain | 13 | 03-17-2008 05:39 PM |
| A/C hissing not blowing cold air | ryanpietro | Factory 2.5L Turbo Powertrain | 3 | 08-28-2006 02:33 PM |
