Old 04-04-2010, 10:38 PM   #1
erikm
Member#: 107019
Stg2 08 STi MBP
Franz Diebold tuned!
Default 08 STi DAM problems
08 STi running Cobb OTS Stage 1 93 v1.02
My DAM will start at 0.8 as it should after resetting the ECU, then it will go up to 1.0 for 50km or so.. and then it drops to 0.8 and then 0.7.
http://www.bravevisuals.com/logs/apr/datalog24.csv
http://www.bravevisuals.com/logs/apr/datalog25.csv
http://www.bravevisuals.com/logs/apr/datalog26.csv
As a side note I ran v1.04 for 3 days and my DAM went down to 0.4 so I immediately went back to 1.02.
erikm is offline   Reply With Quote
Old 04-09-2010, 11:48 AM   #2
whitey615
Member#: 207865
2016 Sti
Wrb
Are you concerned about your knock correction at all? And have you seen it go past -1.4
I consistantly see -1.4 when Im logging and as high as -2.8 but my DAM is always 1
This is on an 09 wrx
whitey615 is offline   Reply With Quote
Old 04-09-2010, 11:59 AM   #3
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
are you guys still on winter gas?
Old 04-09-2010, 12:24 PM   #4
whitey615
Member#: 207865
2016 Sti
Wrb
93+ octane
Old 04-09-2010, 12:51 PM   #5
jaxscuby
Sammo Hung
Member#: 10613
2002 USDM WRX
factory default is 0.5 and up to 1.0 for 32 bit ecus.
the knock correction is not the same as dynamic ignition multipiler (dam)
2.5 l are noisy compared to 2.0
Old 04-09-2010, 02:07 PM   #6
whitey615
Member#: 207865
2016 Sti
Wrb
I know it's not the same... So are you saying the knock is normal?
I saw in his logs that he had knock correction which is why I asked
Old 04-13-2010, 01:16 PM   #7
erikm
Member#: 107019
Stg2 08 STi MBP
Bump for some more logs:
Running stage 1 91 octane v1.04 with Sunoco Ultra 94 gas
http://www.bravevisuals.com/logs/apr12/
http://www.bravevisuals.com/logs/apr12b/
Please any suggestions are greatly appreciated.
Mellow exhaust for 08+ STi x86brandon Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 6 06-05-2010 09:48 AM
FS IL: ** SOLD ** 08+ STI Whiteline Camber Plates NIB JM530 Suspension/Brakes/Handling 11 06-04-2010 02:58 PM
08 Sti Gearbox Problem? xandi911 Transmission (AT/MT) & Driveline 9 03-04-2010 02:28 AM
08 sti HO2 problem Queerkiller Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 01-18-2009 10:09 AM
08 sti dccd problem yeahovah Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 3 05-21-2008 10:14 AM
