Welcome to the North American Subaru Impreza Owners Club Wednesday August 20, 2014
Old 04-05-2010, 01:02 AM   #1
Chiketkd
Member#: 71634
In hibernation...
OMGHi2U GT4 Time Attack Challenge - Spring of 2010
It's the Spring and time to dust off our PS2's for another GT4 challenge. This challenge will be done solely on street tires and there will be five cars driven on five different tracks.
**This challenge will end on Friday, April 30th at 12:00 midnight EST.**
The ground rules are as follows:
-Two tires on the tarmac at all times. The curbs count as tarmac, as do cobblestones and concrete and pretty much anything that isn't grass, dirt or gravel. If you've got two tires on the dirt and two tires halfway on the dirt, your lap is no good. If you need any clarification at any point, just ask. Just want it to be fair and more importantly, the same for everyone.
-No contact with the walls/fences/barriers whatsoever unless a "mulligan" is specifically allowed. If you touch a wall, the lap is dirty and doesn't count.
-All laps will be done in Gran Turismo simulation mode, in the 5 cr. Practice session. **Save your ghost replay in case you ever need to defend your integrity.**
-Oil changes, wheel changes and car washes are always allowed
-NO NITROUS, EVER. Nuff said.
-ALL Driver Aids must be disabled. NONE are allowed on any car.
-Ballast changes are up to you.
-Post your times in this format: TIME/DRIVER/CAR
example: 1'20.456/Chiketkd/NSX
SCORING FORMAT:
Points will be awarded to the top 8 as follows:
1st - 10
2nd - 8
3rd - 6
4th - 5
5th - 4
6th - 3
7th - 2
8th - 1
Chiketkd is offline   Reply With Quote
Old 04-05-2010, 01:02 AM   #2
Chiketkd
Member#: 71634
In hibernation...
Modifications:
As this will be a street tire challenge, the mods will be limited. However, fear not, as the cars I've selected are some of the absolute best handling cars in the world! The ONLY allowable mods are as follows:
  • Semi-racing exhaust
  • Racing chip
  • Street Tires (S3)
  • Suspension (fully customizable)
As a reminder, no aero and turn off ALL driver aids (traction and stability control) for every car. We're going to drive these cars "au naturel"!!!
DRIVETRAIN LAYOUT: FF
CAR: Honda Integra Type R (DC2) '98/'99 (you will have to buy this car used)
TRACK: Deep Forest Raceway (Original Courses)
NOTES: Many have called this the best handling FF car of all time. Unfortunately it's only available as a used car in GT4. However, they do come up pretty regularly, so keep your eyes open for one!
1. 1'29.846/jl05sti
2. 1'31.450/Chiketkd
3. 1'33.920/import111
4. 1'34.470/SpeedTheory
5. 1'35.768/Xendrik
6. 1'36.801/ULL_WRX
7.
8.
9.
10.
DRIVETRAIN LAYOUT: FR
CAR: Mazda RX-8 Type S '03
TRACK: Seoul Central (City Courses)
NOTES: One car magazine declared the RX-8 the best handling car under 300K! Have fun revving this this svelte rotary to 9K rpms!
1. 1'03.692/jl05sti
2. 1'03.851/Chiketkd
3. 1'05.659/Robbie_B
4. 1'06.328/thewerxracing
5. 1'06.783/import111
6. 1'07.635/Xendrik
7.
8.
9.
10.
DRIVETRAIN LAYOUT: MR
CAR: Honda NSX Type R '02
TRACK: Tokyo Route 246 (City Courses)
NOTES: Easily one of the best handling MR cars ever made. The Type R version takes the "NSX" experience to an even higher level. Enjoy!
1. 1'47.088/jl05sti
2. 1'48.154/Chiketkd
3. 1'49.869/Robbie_B
4. 1'53.505/import111
5. 1'55.465/Xendrik
6.
7.
8.
9.
10.
DRIVETRAIN LAYOUT: AWD
CAR: Nissan Skyline GT-R V-Spec II Nur (R34) '02
TRACK: Mid-Field Raceway (Original Courses)
NOTES: Many have considered the Skyline GT-R's to be the best handling awd cars ever made. With 100% of power going to the rear wheels, unless a traction-loss occurs, it's not hard to see why. The V-Spec R34 models came with the latest ATTESA ET-S PRO awd system with an active LSD in the rear. Despite its weight, this car can turn!
1. 1'17.429/jl05sti
2. 1'18.145/Chiketkd
3. 1'22.341/import111
4.
5.
6.
7.
8.
9.
10.
DRIVETRAIN LAYOUT: EV (electric)
CAR: Nike One 2022
TRACK: Seattle Circuit
NOTES: With 250+ ft-lbs of torque available right off idle, this car is a beast! The only mod you'll be able to do to this car is tires (S3) as it has no exhaust, engine or suspension to modify.
1. 1'34.998/jl05sti
2. 1'35.862/Chiketkd
3. 1'38.417/Robbie_B
4. 1'40.936/import111
5.
6.
7.
8.
9.
10.
Old 04-05-2010, 01:03 AM   #3
Chiketkd
Member#: 71634
In hibernation...
FINAL RESULTS
1. jl05sti - 50 points
2. Chiketkd - 40 points
3. import11 - 26 points
4. Robbie_B - 18 points
5. Xendrik - 11 points
6. thewerxracing - 5 points
6. SpeedTheory - 5 points
8. ULL_WRX - 3 points
Congrats to jl05sti for the clean sweep!
Old 04-05-2010, 10:24 AM   #4
Chiketkd
Member#: 71634
In hibernation...
The challenge is up!
Old 04-05-2010, 12:01 PM   #5
thewerxracing
Member#: 141498
That's it. Im in. Im sick of forgetting about these damn things.
However, where the hell do I get a Nike One?
thewerxracing is offline   Reply With Quote
Old 04-05-2010, 12:59 PM   #6
Chiketkd
Member#: 71634
In hibernation...
Glad you can join us. Each one of these cars is exciting to drive in GT4. Definitely a great challenge to start on with.
You win the Nike One after completing the International A license iirc...
Old 04-05-2010, 03:18 PM   #7
thewerxracing
Member#: 141498
Think I already got rid of it. Ill check tonight.
Old 04-05-2010, 06:10 PM   #8
thewerxracing
Member#: 141498
Well, let's get it started...
1'06.328/thewerxracing/RX8
Old 04-05-2010, 06:50 PM   #9
Chiketkd
Member#: 71634
In hibernation...
What I'll allow for the Nike One 2022, is as follows:
Switch to Arcade Mode and select Time Trial. Select the Seattle Circuit under "City Courses". Under the US flag, select Nike and then select the Nike One car. Change tire to Street: Super Soft. Once the track is loaded do not make any other changes to the car (can't change HP, weight, etc). You must run the standard car as is. You can still save your ghost in Time Trial mode and please do this.
P.S. Times are updated.
Old 04-05-2010, 09:29 PM   #10
Chiketkd
Member#: 71634
In hibernation...
FWIW, the '98 Type R also comes up in "Used Car Showroom II" and makes an identical amount of power after an oil change and all allowable mods are performed as the '99 (218hp). So I'll add that as an additional model year Type R that can be purchased used.
My first time: 1'31.450/Chiketkd/Hype R
Times are updated.
Old 04-06-2010, 05:08 PM   #11
thewerxracing
Member#: 141498
Finally figured out that the DC2 likes the softer side. So, expect a time tonight.
Old 04-07-2010, 01:22 AM   #12
import111
Member#: 24447
2010 Evo GSR
GG
1:43.231/import111/Nike One 2022
import111 is offline   Reply With Quote
Old 04-07-2010, 01:45 AM   #13
import111
Member#: 24447
2010 Evo GSR
GG
1:37.256/import111/99 Integra Type R
Old 04-07-2010, 08:55 AM   #14
Chiketkd
Member#: 71634
In hibernation...
The front end does (maybe a 7-7.5K front spring), but the back end needs to be stiff to aid rotation in corners.
Times are updated.
Old 04-07-2010, 04:28 PM   #15
thewerxracing
Member#: 141498
I need to find another second, Chiketkd. But I will.
Old 04-07-2010, 09:20 PM   #16
import111
Member#: 24447
2010 Evo GSR
GG
1:07.272/import111/03 RX-8 Type S
Old 04-07-2010, 09:48 PM   #17
Chiketkd
Member#: 71634
In hibernation...
Times are updated.
Old 04-07-2010, 09:48 PM   #18
PAImportTuner
Member#: 141669
A EJ205 with
E316G
Why not GT5P?
PAImportTuner is offline   Reply With Quote
Old 04-07-2010, 10:02 PM   #19
import111
Member#: 24447
2010 Evo GSR
GG
1:23.657/import111/Nissan Skyline GT-R V-Spec II Nur (R34) '02
Old 04-07-2010, 10:23 PM   #20
import111
Member#: 24447
2010 Evo GSR
GG
1:56.472/import111/Honda NSX Type R '02
Old 04-08-2010, 08:42 AM   #21
Chiketkd
Member#: 71634
In hibernation...
Originally Posted by PAImportTuner View Post
Why not GT5P?
Many people are holding out until the the full version of GT5 is released.
Times are updated.
Old 04-08-2010, 10:03 PM   #22
Chiketkd
Member#: 71634
In hibernation...
1'48.407/Chiketkd/NSX
Times are updated.
Old 04-09-2010, 12:34 AM   #23
Robbie_B
Member#: 137728
93 MR2T 87 924S
Teal and Black
1:38.417/Robbie_B/Nike One 2022
Robbie_B is offline   Reply With Quote
Old 04-09-2010, 09:09 AM   #24
Chiketkd
Member#: 71634
In hibernation...
Times are updated.
Old 04-10-2010, 12:27 AM   #25
Robbie_B
Member#: 137728
93 MR2T 87 924S
Teal and Black
1:05.659/Robbie_B/Mazda RX8 Type S
World Time Attack Challenge / Australian Superlap 2010 garageGT Motorsports 28 06-04-2010 03:55 PM
GT4 Time Attack Challenge - Grand Valley Speedway Chiketkd Motorsports 58 01-02-2010 10:11 PM
GT4 Time Attack Challenge - Fall of 2009 Chiketkd Motorsports 150 11-30-2009 09:00 PM
GT4 Time Attack Summer Challenge of '09 Chiketkd Motorsports 44 08-11-2009 09:38 PM
GT4 Time Attack Challenge - Nissan GT-R Concept ('01) Chiketkd Motorsports 42 06-22-2009 02:44 PM
