Welcome to the North American Subaru Impreza Owners Club Sunday February 14, 2016
Old 06-03-2002, 07:47 PM   #1
More Power
Member#: 5767
Default Flat 6 Swap and Turbo
Has anyone swapped the new flat six from the Outback into a 2.5 RS? If you could turbocharge it you could get some major power. You could even go N/A with high compression pistons and make good power. Anyone have info on this engine?
More Power is offline   Reply With Quote
Old 06-03-2002, 09:22 PM   #2
Really_Soaked
Member#: 4992
2000 Impreza 2.5 RS
Blue Ridge Pearl
Sigh.
Why bother? The money involved in transplanting such an engine into an RS would be better spent on an EJ25-T. The EJ25 is ighter, probably stronger, has better weight distribution and is already in the car.
If you were going to go to that extent, just throw it in the trunk of a Legacy GT and have a rear-engine'd AWD H6. That, or buy a porsche.
-sw
Really_Soaked is offline   Reply With Quote
Old 06-03-2002, 09:43 PM   #3
N/A
Member#: 133
TBA TBA
TBA
I thought the H6 and the EJ25 were actually really close to each other in size and weight?
N/A is offline   Reply With Quote
Old 06-03-2002, 10:58 PM   #4
yebokmj
Member#: 2213
1995 Impreza w/EJ255
Brilliant Red
Default Size and weight
This has been discussed. The weight though marginal at 100lbs when put at the front would be quite bad. Also there was a questoin about it fitting under the hood interms of height. Also it was said you should go with the SVX engine for it's larger displacement. Not only that but the fact that there is no aftermarket for the engine will also make things more difficult. Do a search for more info.
Joshua
yebokmj is offline   Reply With Quote
Old 06-04-2002, 06:00 AM   #5
ac_gohan
Member#: 1903
2000 2.5 RS-T coupe
T3/04 Link'd 2 10 PSI
I heard that the exhaust runners on the H6 were not designed that well either. Thats for NA i wonder how it would be when it comes to a forced induction application. But hey never know till you try, personally i think that would be badass. Twin turbo that **** supra killa
ac_gohan is offline   Reply With Quote
Old 06-04-2002, 08:58 AM   #6
Z1 Performance
Member#: 9327
The newer flat 6 is actually a loaded POS...IF you must do it (and I am not sure why you wold bother), the older H-6 from the SVX is a MUCH better option
adam
Z-1
Z1 Performance is offline   Reply With Quote
Old 06-04-2002, 09:16 AM   #7
Marquis
Member#: 64
1999 Impreza 2.5RS
Rally Blue Pearl
No offense, but why do you say that? I don't mean to imply the new H6 is great, but I don't understand why it's so bad. Also, the H6 in the SVX is gigantic. It's sized like an EJ20 with two extra cylinders on the front (both in weight and dimensions), which it basically is. The new H6 is significantly smaller, only about an inch longer than an EJ25. Still heavier, of course, but less so than the SVX's H6.
I still wouldn't recommend either option unless you're really in the mood for headaches and want something pretty unique. A turbo EJ25 (especially a nicely built one) can make plenty of horsepower for any of us mortals.
Marquis is offline   Reply With Quote
Old 06-04-2002, 10:01 AM   #8
rhdude
Member#: 6637
2009 Acura MDX Sport
I know of a guy here in the mid-A who once had a XT, he swapped in a SVX motor, and made it twin turbo, paralel turbo's I believe.... then, his ex-wife totaled the car He has always told me, "if someone tells you it cannot be done, do it just to prove them wrong if nothing else, and if they ask why you want to do something, ask them, why not do it???
I had raised the topic of a ej30TT powered RS a while back.... search for threads, there are PLENTY of them....
In the future I want to build a ej25TT, with paralel turbo's, dual throttle bodies.... not like FAT's kit...
rhdude is offline   Reply With Quote
Old 06-04-2002, 10:18 AM   #9
More Power
Member#: 5767
Thanks for the info guys. I will do a search. I kind of figured it would be pointless, but thought I would see if anyone has done it.
Old 06-04-2002, 11:41 AM   #10
XT6Wagon
Member#: 524
04 STi
RHdude, the current 6cyl motor is the EZ30, and shares nothing with the EJ. The SVX motor is based off of the early EJ series.
XT6Wagon is offline   Reply With Quote
Old 06-04-2002, 03:35 PM   #11
RageHardIntoTheBendies
Member#: 1532
1999 RS, Silverthorn
www.zucru.com
FAT has done a twin turbo SVX powerd Impreza.
RageHardIntoTheBendies is offline   Reply With Quote
turbo swap and turbo inlet juanmedina Newbies & FAQs 3 10-15-2007 02:53 PM
Great deal on 02' wrx with 41k and built flat 6 EJXXX SWIC Private Classifieds 16 10-10-2007 07:01 PM
2.5 motor swap and turbos WjRgX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 03-02-2005 02:37 PM
Subaru Flat-6 Turbo Diesel Available in 3 Years? Jon [in CT] News & Rumors 22 11-05-2004 10:49 PM
doing the 6 speed swap and have a question about DCCD fc735 Transmission (AT/MT) & Driveline 0 01-25-2004 10:33 PM
