Old 04-05-2010, 04:36 PM   #1
tubmyster
Member#: 59868
Default Replace 03 WRX Turbo with 04 Forester Turbo?
The turbo in my 03 wrx needs to be replaced now. I just noticed that I'm not getting any more boost, so it's just sitting in my garage until it gets fixed. I am trying to find a used one in my area, but the only luck is a turbo off of a 2004 Forester. My questions is will it be a direct replacement? I have done some searching and found people who put the wrx turbo on the forester with no problems, but nothing about a forester turbo on a wrx.
tubmyster is offline   Reply With Quote
Old 04-05-2010, 06:39 PM   #2
GrimmSpeed
Member#: 136396
2015 WRX, 2012 WRX,
2013 BRZ, 2006 STI
Hey,
As long as the turbo is a td04 it will work just fine! You could also check out the for sale section on here, they're available all the time!
Mike
GrimmSpeed is offline   Reply With Quote
Old 04-05-2010, 11:45 PM   #3
02Wagon11
Member#: 233456
02 Wrx Wagon
i have a td04 for sale now with 55k on it, no problems
02Wagon11 is offline   Reply With Quote
Old 04-06-2010, 07:54 AM   #4
Spenk
Member#: 7164
2000 Miata LS
Evo Orange Mica (1/644)
Originally Posted by GrimmSpeed View Post
Hey,
Mike
Correct. BTDT.
Just make sure you swap the WG actuator from your old turbo onto the FXT turbo. They work at different spring pressures.
Spenk is offline   Reply With Quote
Old 04-06-2010, 11:22 PM   #5
tubmyster
Member#: 59868
is the WG actuator fairly easy to swap out? i need my car fixed asap so would rather pick up the forester turbo locally than wait for a turbo to be shipped to me
Old 04-07-2010, 12:23 AM   #6
Haelan
Member#: 151045
2013 Subaru STI
CBP
It's two bolts and a c-clip. It only takes a few minutes to swap them.
Also, swap the restrictor pill. It's in one of the boost hoses attached to the turbo.
Haelan is offline   Reply With Quote
Old 04-10-2010, 01:35 AM   #7
tubmyster
Member#: 59868
just finished swapping my turbo today! first time i've ever done something like this and i'm glad everything worked out fine. it's a little bit slower right now, when i switched the WG actuators i unknowingly loosened the actuator arm, so i will turn that in a little bit tomorrow
SOLD (ME)- 02/03 WRX UTEC with map switch dlewis Engine/Power/Exhaust 8 05-25-2010 01:24 PM
SOLD ME: 02/03 WRX UTEC with map switch dlewis NESIC Private Classifieds 6 05-25-2010 01:24 PM
replacing blown 03 wrx motor with 04 motor pillarguy17 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 6 01-26-2006 12:38 AM
replacing blown 03 wrx motor with 04 motor (plug and play?) pillarguy17 Subaru Conversions 2 01-16-2006 12:58 AM
04 Forester Turbo w WRX suspension? Italiano Brakes, Steering & Suspension 2 07-12-2003 12:25 PM
