Old 04-06-2010, 01:54 PM   #1
steveRS
Member#: 180430
2008 335i
Default ZZYZX Camber bolt
I have the zzyzx competition coilovers. Does anyone know the size of the camber bolts? I am pretty sure it is metric. Home depot or lowes do not have any metric bolts this big. Or does anyone know a good way to contact steve to find out? His website is down and he is a pretty hard person to get a hold of these days. If I can find out the size, I can order some online from McMaster Carr
Picture of said bolt:
Thanks
steveRS is offline   Reply With Quote
Old 04-06-2010, 01:56 PM   #2
subvinnie
Member#: 223886
go to ace or auto zone
subvinnie is offline   Reply With Quote
Old 04-06-2010, 02:02 PM   #3
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
That's just a bolt. Any grade 8 bolt that size will work.
Old 04-06-2010, 02:15 PM   #4
STi-MAN
Member#: 70252
05 STI
blue
^hahahha
STi-MAN is offline   Reply With Quote
Old 04-06-2010, 03:00 PM   #5
loworbitSI
Member#: 60981
05 996 GT3
You could use the lower factory 19mm bolt on OEM struts. The diameter of the bolt shaft is the same size on the ZZYZX as the factory, but the ZZs have 22mm ends. Nothing really different otherwise, maybe some difference in overall length, but a plasuible quick solution.
loworbitSI is offline   Reply With Quote
Old 04-06-2010, 03:24 PM   #6
steveRS
Member#: 180430
2008 335i
Found a quick temporary solution. The bolt is 14 mm. I found a 14 mm at a small local hardware store. However its grade is only 8.8 where as the the bolt from zzyzx is 10.9. Going to put on this bolt for now (the car won't see much driving if any at all) and then order a 10.9 grade 14 mm to replace the old one.
Thanks for the replies.
ZZYZX Camber bolt Size steveRS Brakes, Steering & Suspension 0 04-06-2010 01:56 PM
Tokico D-Specs + Camber bolts = less camber than stock struts without camber bolts?! formula91 Brakes, Steering & Suspension 10 09-07-2009 12:59 AM
rear camber bolts = front camber bolts? Penguinking Brakes, Steering & Suspension 1 07-12-2003 10:01 PM
why can you use camber PLATES in STX, but not camber BOLTS!? rex n effect Motorsports 2 05-12-2003 02:32 PM
Can only get 0.5 negative camber with camber bolts? Tronner Brakes, Steering & Suspension 1 08-23-2002 08:56 PM
