Old 04-06-2010, 02:59 PM   #1
kharris4
Member#: 46018
2003 wrx
silver(mostly stock)
Default Why is mixing power steering fluid bad?
What results in mixing power steering fluid? I did a brief search, didn't come up with much. I'm wondering if steering vibrations could occur from this.
kharris4 is offline   Reply With Quote
Old 04-06-2010, 03:26 PM   #2
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
your car does NOT USE ANY power steering fluid in it anywhere
it DOES use Dextron ATF in the power steering system
that is a common problem....using the WRONG thing in it
Old 04-06-2010, 10:21 PM   #3
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
Well, mixing power steering fluid into the ATF which comes in the system will make for some pretty irregular steering response, since they are different viscosities and immiscible.
Power steering fluid will work if you flush a few bottles through the system, but there aren't any benefits and it doesn't last nearly as long.
sniper1rfa is offline   Reply With Quote
Old 04-07-2010, 07:08 AM   #4
kharris4
Member#: 46018
2003 wrx
I should have known this from the start.
Thanks guys.
Old 04-07-2010, 11:27 AM   #5
kpluiten
Member#: 120273
06 WRBWRXWGN
Now with 100% more Spec-C
I don't think it will work. Every Subaru car I've ever seen someone use it in for extended periods has resulted is a bad pump. Every one.
Old 04-07-2010, 11:29 AM   #6
kharris4
Member#: 46018
2003 wrx
I'm gonna flush it and put ATF back in.
Old 04-07-2010, 12:47 PM   #7
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
Could be wrong. AFAIK both are simply hydraulic oils - the ATF merely lasts a lot longer (it's much more highly developed). It's not helpful anyway, so the point is moot.
Old 04-07-2010, 03:21 PM   #8
Big-E
Member#: 123843
2016 STI LTD CWP
Let LED's light your way!
The correct fluid is Dexron III (A/K/A: Mercon/Dexron III).
Respectfully, there is no "T" in Dexron.
Do not use any other fluid in your power steering system.
Old 04-07-2010, 08:19 PM   #9
sLicK 2004
Member#: 206094
2004 WRX
Hybrid VF39 / JDM 6spd
I've seen people recommend M1 synthetic ATF? does that fall under Dexron III or?
sLicK 2004 is offline   Reply With Quote
Old 04-07-2010, 08:58 PM   #10
Web Foot STi
Member#: 39086
2004 STi
Yes. It just is better in sever applications. Just like any other synthetic. I've been running Mobile 1 for years now.
Edit: http://www.mobiloil.com/USA-English/...hetic_ATF.aspx
Web Foot STi is offline   Reply With Quote
Old 04-08-2010, 07:08 AM   #11
kharris4
Member#: 46018
2003 wrx
Do you guys think that mixing about 1 cup of PS fluid into the system could cause a short steering wheel vibration after hitting a bump while driving on the freeway?
Old 04-08-2010, 01:40 PM   #12
sniper1rfa
Member#: 141040
07 2.5i wagon
UGM
vibration? no. It will make the steering feel "lumpy" while turning.
Old 04-08-2010, 07:46 PM   #13
Steve Nastoff
Member#: 52052
03 Subaru WRX
Midnight Black Pearl
I don't even mix fluids in my beater.
I've had terrific results with Redline D4 ATF.
I also run a custom made cooler of my design that utilizes a 10 row Earl's radiator.
Steve Nastoff is offline   Reply With Quote
Old 12-20-2013, 02:56 PM   #14
hellriderkc
Member#: 373967
2006 Legacy
white
thank you all comments really helpful. dose any one know if mixing cause damage?
hellriderkc is offline   Reply With Quote
Old 12-20-2013, 07:49 PM   #15
Uncle Scotty
Member#: 16200
OK buy Nates beans
you didnt READ the thread
dont mix atf and ps fluid in the system.....no
Is my power steering pump bad? or is it something else? psychoskip Brakes, Steering & Suspension 11 01-25-2010 02:46 AM
Power steering fluid, manual tranny fluid, and rear diff fluid ex_boyometric Vancouver Impreza Club Forum -- VIC 17 03-09-2008 05:54 AM
So all my power steering fluid is on the ground... MUGWUMP Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 09-07-2004 11:48 AM
Who knows, why you CAN'T use power steering fluid? TaiChih Mid Atlantic Impreza Club -- MAIC 11 02-04-2003 01:36 PM
bad power steering fluid leak annointed Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 07-28-2002 11:09 PM
