Welcome to the North American Subaru Impreza Owners Club Tuesday March 3, 2015
Old 06-04-2002, 12:19 AM   #1
cnstman
Member Sales Rating: (4)
Member#: 9548
2004 WRX STi
10.154 @139 @ 7,000'DA
Thumbs up Subaru short shifter
well i don't know how many people have had both the kart boy short shifter lever w/ bushings and the subaru short shifter, full linkage, but i have.
over time i did not like the notchy feel of the kartboy, so i took it out and sold it. i then purchased the entire subaru short shifter linkage and installed it.
the subaru in my opion is much smoother shifting. the throw is as short, if not shorter than the kartboy. i can personally shifter much much faster with the subaru short shifter due to the much smoother action.
my kartboy would bind up and cause me to mis 3rd gear if i was not paying close attention to the shift motion. with the subaru ss kit i can have a drink in my hand, and reach over and just push the shifter up from second, and it will fall into 3rd with no problems.
down shifting into 1st while moving is also much easier with the subaru ss.
i did keep the kartboy bushings, and i would recommend this to anyone getting the subaru ss. i had the opportunity to do a car to car comparision from a car with the subaru ss with the stock bushing to mine with the kartboy, and there is a difference. the kartboys do take all the sloppyness out of the action.
hope this helps.
in my opionion it is worth the extra money to get the subaru ss. i paid 189 from maxtro motors.
cnstman
cnstman is offline   Reply With Quote
Old 06-04-2002, 11:11 AM   #2
gtguy
Member#: 2184
2005 Legacy GT wagon
Platinum Silver Metallic
Well, that's what I've been saying for a while... Nice review, and it should help someone.
Kevin
gtguy is offline   Reply With Quote
Old 10-02-2002, 12:52 AM   #3
Groove1797
Member#: 25515
05 STI
I have the Subrau SS and was wondering what would the Kart's do, thanks for the answer!!
Groove1797 is offline   Reply With Quote
Old 10-04-2002, 01:49 AM   #4
BOP
Member#: 8681
Post
this is pointless
BOP is offline   Reply With Quote
Old 10-08-2002, 03:15 PM   #5
Siper2
Member Sales Rating: (33)
Member#: 1134
2007 BMW 328xi wagon
What differences are there between OEM and STi linkages?
I have a Karboy shifter & bushing combo (not currently installed, long story--no, I have no complaints about them ). I'm wondering if the Kartboy shifter installed in the STi linkage would be even better.
I think the "binding" up into 3rd happens with even the OEM shifter. That little problem ceased for me when I installed the Group N tranny mount.
gtguy,
What's your specific argument?
-Chris
Siper2 is offline   Reply With Quote
Old 10-08-2002, 04:17 PM   #6
cnstman
Member#: 9548
2004 WRX STi
Default my opinion, and my mechanics
siper2 if you read the following thread, my post, this is what my mechanic said is wrong with the shorter shifter levers, (kartboy, and all the others). this is not proven specifically, so take it for what it is worth. it made sence to me
http://forums.nasioc.com/forums/show...hreadid=206559
Old 10-08-2002, 05:58 PM   #7
Siper2
Member#: 1134
Well I read the whole thread, and you had a good point, but I think the mechanic was probably just generalizing. Most "short shifters" are POS offerings you find in the back of Super Street, with no good R&D behind them, no way to investigate nor prove quality, certainly no customer service.
Tom & Mark I'm sure did all the required research, and then some, before slapping something together. Not that I think that's your opinion. Just a point, is all.
As Peat Romano's pics show, the ball-to-sleeve distance is nearly identical from KB to STi shifter arms. I do find your argument about the gold linkage arms vs. OEM ones, and their slight difference, to be intriguing, though. However, if you're right about the angle thing, I say Kartboy shifters can't be to blame.
I say if your argument is right, then NOBODY should use ANY shifter where the "A-->B" length is different from OEM, if using an OEM linkage. The STi linkage appears to be better suited for both STi shifters AND KB shifters. Again, if your point has any merit.
I'd be interested in further opinions on this. I'll Email Peat, see if he'll pitch in.
-Chris
Old 10-08-2002, 06:56 PM   #8
Peaty
Techno Sapien
Member Sales Rating: (1)
Member#: 449
2010 Legacy 3.6R Lim
Azurite Blue Pearl
I know I've done this before but, I've played with both linkages and driven both. The linkage itself is the same stock VS STi. You put them side by side an there is no difference besides the colour and the end of the fork is a little longer to accomidate he bend in the STi shifter lever.
The bushing in the STi and OEM are very close in stiffness. I say it's virtually the same others would argue that it's somewhat stiffer. The first STi one I came across was new and felt stiffer than the old OEM one I took out. I've had a few out now and compared and I think depending on age and batch to batch varience for all intents and purposes they are the same. The KB bushings on the other hand are very stiff almost solid.
As far as the shift lever itself, the KB and STi have pretty much the same throw. The A - B distance shown is what reduces the throw really. How high the knob sits changes the arc of the throw and will contribute too but not nearly as much. The KB sits lower so in the end will have a shorter throw than the STi but I don't think it will be noticable. Because it's shorter it will require more effort than the STi (distance from the fulcrum) but after a bit you don't notice.
These pics are of the second gen KB but the distances are the same:
I think it comes down to personel preference, driving style and possibly tolerance in tranny manufacture. Some people are having problems right off the bat with their tranny others have had no problems. I'm still amazed that I hear that the WRX suffers from the clutch chatter when cold too. My 99 has done this from day one, you think they would have fixed it by now.
All three shifters are good OEM, Stock and STi.
Peaty is offline   Reply With Quote
Old 10-13-2002, 09:57 PM   #9
BboyAspenWhite
Member#: 17712
2002 wrx
white
Default my take...
i bought the car with the sti ss linkage already installed so i cannot compare it to a stock one while driving. but at a dealership i did sit in a car without the factory ss equipped and tried to feel if the throws were "longer" or felt any different than my shifter and could not notice a difference between that car and mine (however, i just sat in the car and messed with the shifter so it wasn't moving). i think the factory ss felt pretty good, but thought the lever felt too flimsy and shifting into 2nd under hard excelaration always took a tab bit longer than getting into other gears. i just recently installed the kb ss lever + shifter bushing and YES i did feel a difference in the shortness of the throws. i and a friend who helped me do the install made sure to sit there feeling and messing with the shifter so that we would be able to notice the difference when the kb was installed. we both agreed that the throws were a lot shorter and shifting felt "crisper" and more precise. also, under harder exceleration, i've been able to get into 2nd faster/easier and i've been having less instances of trouble getting into reverse. i HONESTLY feel and believe that i'm able to shift faster since i noticed that when i first took the car out right after the install, my gas and clutch work were a little out of sync since i'm so accustomed to the time it takes for me to shift with my former setup. that might not be sustantial evidence but it's a thought. anyways, sorry for the length but i hope this was/will be useful for anyone who wants shorter/notchier, more "mechanical feeling" shifting. kb products are top-notch. peace.
hong
BboyAspenWhite is offline   Reply With Quote
Old 10-19-2002, 09:27 PM   #10
Corn-Picker
Member Sales Rating: (3)
Member#: 8679
2010 The most hated
vehicle on the internets
I have the STi shifter with the Kartboy bushings also. The STi shifter definitely made a difference, the Kartboy bushings definitely made a difference (I installed them at different times). Considering how often you shift your car, I think it's a worthwhile investment
I also have a Momo air-leather shift knob, I give it high marks as well. It fits the hand much better and is not annoying to use like the stock shift knob is, the Momo feels more like a part of your hand even though it's just a leather/aluminum sphere.
What else makes a huge difference in shift feel is Redline 75W90ns. I was skeptical that a simple differential fluid change could make any difference but it made a huge difference. The shifter feels the same on startup in winter as it does when warmed up during the summer, the Redline fluid is that consistent.
Corn-Picker is offline   Reply With Quote
Old 10-20-2002, 12:19 AM   #11
Peaty
Techno Sapien
Member#: 449
Azurite Blue Pearl
I put the 70w90ns in my car and I got a grind when shifting from 4 - 5 unless I shifted very slow or double clutched. It could be because my car had 40K on it when I did the change. I switched to the Redline Shockproof and it went away and shifts very nicely.
Old 10-20-2002, 02:20 AM   #12
Corn-Picker
Member#: 8679
2010 The most hated
Maybe this is what I have too I know I bought what redline recommends for the WRX, I thought that was 75w90ns but I could be wrong...
Old 10-22-2002, 06:12 PM   #13
BOP
Member#: 8681
Post
this is pointless
Old 11-03-2002, 02:27 AM   #14
dj_noose
Member#: 17302
2002 Impreza WRX
you know... the blue one
I like the sti short through shifter, works for me
dj_noose is offline   Reply With Quote
Subaru Short Shifter by Vivid Racing Vchecchia Car Part Reviews 6 03-09-2002 02:47 AM
Subaru short shifter noise gsxr750 Normally Aspirated Powertrain 8 04-11-2001 07:24 AM
subaru short shifter (factory) shukes24 Normally Aspirated Powertrain 4 12-18-2000 10:03 AM
Subaru Short-Shifter? SkToBe General Forum Archive 24 09-15-2000 01:31 AM
