Old 04-06-2010, 11:53 PM   #1
pismobeachrider25
Member#: 216673
2003 WRX
Default 05 STI swap into 04 WRX Wagon. HELP!
Just looking at some options on different builds but this seems the most apealing to me. What components would I need to do a full 05 STI awap into an 04 WRX Wagon. aside for a list of parts necessary, a list or possible problems i may run into with the swap would be much appreciated. Thanks NASIOC!!
I was not sure where to post this so if it is in the wrong section, mods please move it to the correct area, sorry.
pismobeachrider25 is offline   Reply With Quote
Old 04-07-2010, 12:21 AM   #2
Texy32
Member#: 124252
0506 STI/Tribeca
OBP/SGM
do you want to swap the motor or the motor and 6spd tranny.
For the motor this is required.
http://elementtuning.com/techdocs/ej...llation-guide/
hope this helps.
Texy32 is offline   Reply With Quote
Old 04-07-2010, 08:57 AM   #3
pismobeachrider25
Member#: 216673
2003 WRX
looking to swap the full motor and 6spd tranny.
Old 04-08-2010, 03:56 AM   #4
808subaru
Member#: 62234
Chapter/Region: HIIC
09 fozzy
If you are picking up the entire 05STI donor car, I'd also swap the hub over to the better stronger bolt pattern.
808subaru is offline   Reply With Quote
Old 04-08-2010, 11:37 AM   #5
bhhamblin
n00b Moderator
Member#: 99397
15 WRX, 83 DR30,
93 R32 GTS-T, 93 R32 GTR
hope this helps.
What about the AVCS sensors?
bhhamblin is offline   Reply With Quote
Old 04-08-2010, 12:14 PM   #6
Evil Imports
Member#: 14732
+ 13 B8
i would swap the full harness and just use EVERYTHING from the sti, that is what was done with my wagon/sti swap, we used EVERY piece from the doner car
Evil Imports is offline   Reply With Quote
Old 04-12-2010, 09:58 AM   #7
pismobeachrider25
Member#: 216673
2003 WRX
werd, would i have to use the brembo's, sti axles, and sti hubs also or will the 04 wrx ones compensate?
Full V7 STi drivetrain into 04 WRX wagon! big_adventure Subaru Conversions 113 12-08-2012 03:53 AM
2007 STi swapped into 04 WRX, poss boost leak? Samurai_jim Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 03-10-2009 09:01 AM
05 sti swap into 03 wrx RexRexRex Subaru Conversions 0 02-07-2008 08:32 PM
what to do with DBW with 05 sti swap into 02 wrx? bustaman Subaru Conversions 7 11-16-2005 02:11 AM
sti tranny into 04 wrx wagon? sakebomb Subaru Conversions 1 07-08-2004 02:34 PM
