Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Old 04-07-2010, 08:25 AM   #1
Charlie Tango
Member#: 230646
2007 Legacy spec.B
stg2, DGM
Default Hazy Carbon Fiber Hood??
I got a seibon carbon fiber hood a couple days ago. I washed it yesterday and it wass already hazy but it made it worse. Looks to be only on the surface. I've read diff forum post about waxing and clay bars not working to great. Anybody no anything about this??
Charlie Tango is offline   Reply With Quote
Old 04-07-2010, 10:16 AM   #2
CC4nj
Member#: 136945
2005 WRX/CRX/LGT
Obs. Black
Its been covered ALOT...
Its the resin thats hazing up on you. The mfg. uses a cheap clear/gel coat with little to no UV protection.
You can wax/glaze the hood and get it sorta better but its not a fix.
Best bet is it bring it to a bodyshop have them block it down and reclear it.
CC4nj is offline   Reply With Quote
Old 04-07-2010, 11:36 AM   #3
IIdiceII
Member#: 90438
it needs to be polished/buffed.
it will probably come back eventually but if you stay on it with repeat maintenance it should stay good for a long time.
IIdiceII is offline   Reply With Quote
Old 04-07-2010, 11:41 AM   #4
davidsti1
Member#: 210923
2001 RSTI Twinscroll
FullRace BW8374 ripper
paint it!!
davidsti1 is offline   Reply With Quote
Old 04-07-2010, 11:43 AM   #5
TAWRX
Member#: 199244
2008 WRX
World Rally Blue
take it to a shop and have a better clearcoat applied
TAWRX is offline   Reply With Quote
Old 04-07-2010, 02:34 PM   #6
Ryan314
Member#: 82989
Hybrid EJ257
Don't buy CF exterior parts again in the future.
Ryan314 is offline   Reply With Quote
Old 04-07-2010, 03:20 PM   #7
jz0r
Member#: 218240
07 WRX
satin white pearl
i know i wont.
my hood and trunk looked really bad after cleaning them a few days ago, but i just waxed them good and it looks better. but at the same time i found so many little cracks where moisture is starting to seep in and bubble up
jz0r is online now   Reply With Quote
Old 04-07-2010, 03:24 PM   #8
dangerousatom
Member#: 70710
2002 04STi Swaped RS
w/PPGS & 02 Wagon w/PPGs
Heh dont listen to that, but be sure yo are ready to get then cleared for lots of $$$ My brand new Seibon hood was 4 clear coats with a wet sand in between cost more than the hood itself.
dangerousatom is offline   Reply With Quote
Old 04-07-2010, 04:57 PM   #9
Charlie Tango
Member#: 230646
2007 Legacy spec.B
stg2, DGM
Ok cool. Im new to posting stuff so its cool to see everybodys opinion to my own problems!! haha But ima wax/clay bar real good and have a clear or two put on! I thinks thats the best thing to do! CF exterior is AWESOME Ryan341! lol
Old 04-07-2010, 05:57 PM   #10
IIdiceII
Member#: 90438
waxing it and claying wont do a god damn thing.
you need to literally remove the bad "layer" of clear/gel coat on top thats now all hazy. you need to compound/polish/buff (whatever the hell you wanna call it) it.
waxing will just put a layer of stuff on top of the bad clear and claying will take the stuff thats stuck to the bad clear off.
youre still gonna have a bad layer of clear on the hood.
Old 04-07-2010, 08:25 PM   #11
Charlie Tango
Member#: 230646
2007 Legacy spec.B
stg2, DGM
So prob just take it to my body work guy and ask him about clearing it?? It souldn't be much.
Old 04-07-2010, 08:29 PM   #12
IIdiceII
Member#: 90438
that would the best solution but I would at least try to machine polish it first. it will be much cheaper and if you keep up on maintenance, should last a long time.
Old 04-08-2010, 12:08 AM   #13
dangerousatom
Member#: 70710
Check that bro it will be a few hundred bucks and i dont mean under $300 unless your good friends and he's hooking you up. Its like a 10+ hour job over a week of sanding and clearing and drying/curing
Carbon Fiber new or old ( old is far worse ) sucks up clear like a sponge and gives you thousands of pin holes and fish eyes. So it has to be wet sanded and shot again and again and again till the weave is sealed. Then finally it will get a smooth unblemished finish.
Old 04-08-2010, 02:28 PM   #14
Charlie Tango
Member#: 230646
2007 Legacy spec.B
stg2, DGM
Dangg!! What too do what to do!
Old 04-08-2010, 02:43 PM   #15
IIdiceII
Member#: 90438
BUFF IT!
go to a local detailing shop. odds are they will do it for less than 50 bucks. go on a rainy day too. they'll be itching for business!
Old 04-08-2010, 03:38 PM   #16
dangerousatom
Member#: 70710
Clear It or never let it sit in the sun for more than a few seconds.
Old 04-08-2010, 04:01 PM   #17
deadmeat47
Member#: 243169
2002 Outback Sport
Red
Default fog
is it a fog or is it just sitting on the top? if it is sitting on the top then it isnt too big of a problem
deadmeat47 is offline   Reply With Quote
Old 04-09-2010, 03:45 AM   #18
racersky
Member#: 77817
I had the same problem on my free Seibon Hood I picked up recently. I'll just copy and paste it in here.....
recently received a free carbon fiber hood that was in bad shape on purpose. The previous owner did not take much care of the hood and the car was always parked under direct sunlight. So on to some pictures so you can have a visual of what it looks like.
Here was the condition of the hood when I first received it:
As you can see the milky areas of the hood is oxidation...man was this hood f'ed up. I kind of had second thoughts of it when I brought it home. So out came with the test spot and 50/50 shots.....
One pass of buffing Menzerna 203 but then if didn't come out all the way so upped it to Menzerna Power Gloss
Stage 2 of buffing Power Gloss then 203
50/50 shot to show you the difference with only using 203 so you can see why I decided to upped to Power Gloss
Here's more before and after....
Wetsanded the corner with 2000
For wax I used Natty Red Paste.....Hope this helps you with your oxidation problems
racersky is offline   Reply With Quote
Old 04-09-2010, 03:53 AM   #19
twentyclowns
Member#: 173176
2008 WRX sedan
Black OBP
you bought it used or new?\
this question is for the op....
twentyclowns is offline   Reply With Quote
Old 04-09-2010, 12:18 PM   #20
dangerousatom
Member#: 70710
I so cant stand lazy people who cant read posts.......it says rite in his post weather its new or used.....and only an idiot would even think it was new
Old 04-09-2010, 12:57 PM   #21
Blinden
Member#: 122993
Ex's WRX
02, 04 Sti, 12 Hatch
/Raises hand
I must be an idiot, because I can't tell WEATHER it's used or new and was wondering the same thing...
Blinden is offline   Reply With Quote
Old 04-09-2010, 01:23 PM   #22
dangerousatom
Member#: 70710
^ I seriously hope that is sarcasm
Old 04-09-2010, 01:25 PM   #23
twentyclowns
Member#: 173176
2008 WRX sedan
Black OBP
weird....doesnt say a damn thing about it being used or new, you ****ing idiot!!
why dont you chillax and quit being a ****ing dick, *******
dangerfag is a prick
Old 04-09-2010, 01:36 PM   #24
twentyclowns
Member#: 173176
2008 WRX sedan
Black OBP
what i cant stand are idiots that complain that people cant read when infact they are the ones that cant read, and i hate when they are complete aholes about it
go play in traffic buddy
Old 04-09-2010, 02:15 PM   #25
Blinden
Member#: 122993
Ex's WRX
Nope, it's not, so, can you show me where it says WEATHER or not it's used please?
wtb: carbon fiber trunk, carbon fiber hood, or aw rs hood and trunk today!! spyda23 Tri-State Area Private Classifieds 1 07-02-2009 07:02 PM
OEM Carbon Fiber hood 02-03 w/ NRG carbon fiber hood struts evoklr101 Exterior/Styling 9 06-05-2008 02:15 AM
Is there a way to correct hazy carbon fiber? rites Interior & Exterior Modification 3 02-02-2006 09:08 AM
carbon fiber hood, forge bov, carbon fiber front strakes, and more anthonyrb98 Private 'For Sale' Classifieds 70 10-11-2005 10:06 PM
GA: Kaminari full carbon fiber hood & S202 carbon fiber replica spoiler Si2WRX Private 'For Sale' Classifieds 5 10-27-2004 05:50 PM
