Old 04-07-2010, 09:59 AM   #1
superskaterxes
Member#: 197454
2006 mazdaspeed 6
black mica
Default Optimizing Launch Control using the AP
so i dont even have a subi but im here to get some info on what people have done to optimize the LC feature of the AP on their subaru. i currently have a mazdaspeed 6 with a 3076 and im having trouble building boost off the line using the AP.
-what RPM are people launching at who have bigger turbos?
-have u changed any of the VVT values or timing or anything to up the boost off the line?
-does the subi LC feature cut fuel or spark?
im just trying to figure out the best way to go about this and figured i could use some proven results from u guys. TIA
superskaterxes is offline   Reply With Quote
Old 04-07-2010, 03:55 PM   #2
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
fuel cut, ignition cut can be harmful to your car though it does shoot some pretty cool fireballs, and does a better job of getting the turbo spooled.
also RPM's vary alot based on flywheel, turbo, and engine sizing. Try out what you think should be right, and if it bogs or doesn't work quite right adjust it. I'm set at 5700 and it's great for me, but i'm running a 2.0 with a lightened fly, a bigger clutch, and a fairly small turbo.
ProdriveDreams is offline   Reply With Quote
Old 04-07-2010, 03:58 PM   #3
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
don't just dump the clutch though, you do still need to butter it a bit for best launching
Old 04-10-2010, 02:55 PM   #4
crystalgreysti
Member#: 233085
2007 sti
cgm
do any of you experience your 2nd gear dying or shutting down for a bit and then it just pulls hard? mines does its weird. anyone know what it can be? or cause it?....i have mine set at 4500 =) stock turbo launches pretty hard build boost just fine
crystalgreysti is offline   Reply With Quote
Old 04-10-2010, 03:45 PM   #5
wrxdrvr
Member#: 79222
'09 STi 297.5 WHP
Take your foot off the clutch a bit faster at the end so the switch isn't on, and the ECU still thinking the clutch is still pressed in...
wrxdrvr is offline   Reply With Quote
Old 04-16-2010, 03:08 PM   #6
RedRex26
Member#: 133418
2006 DOM3 XTR WRX TR
SRR 407whp 365wtq ppg'd
had the same problem. When you set the rpms for launch control it also sets the flat foot shifting to the same rpms. change the flat foot shifting rpms to your redline and it won't happen.
RedRex26 is offline   Reply With Quote
Old 04-19-2010, 03:03 AM   #7
crystalgreysti
Member#: 233085
2007 sti
cgm
^^^^did not know that. i thought you had to manually turn on the ffs through the ap?
Old 04-19-2010, 04:32 AM   #8
NSFW
Member#: 140444
05 Stage Free LGT
ATP 3076, 6MT, AVO FMIC
My LGT did this on the stock tune, no FFS, just shifting fast. Still does it on my own tune - it's a pre-existing condition that I have no idea how to fix via tuning. The only solution I've found is to shift slowly - then pulls hard as soon as the clutch engages. I'm sure FFS would just make the problem worse.
I suspect there are tables / features in the ECU that govern this behavior, they just haven't been documented yet, and made tunable.
Old 04-19-2010, 05:49 AM   #9
RedRex26
Member#: 133418
this is what i thought. but it happened to me at the track on multiple runs. I then checked the flat foot shifting and it was set at the exact same rpms that i set my launch control at and i never even touched the ffs. raised the ffs up past the redline and it never happened again. just solid 12s passes all night after that.
Old 04-19-2010, 11:29 PM   #10
crystalgreysti
Member#: 233085
2007 sti
cgm
ok gonna check that out today thanks
Can Cruise control co-exist with launch control with the 2002 wrx Hydra? jigga Other Engine Management 5 04-17-2007 08:16 PM
Can i use the AP if i get my ecutek flashed to stock?? SoSLOWSTi AccessPort 6 06-27-2006 07:36 PM
Anyone using the AP ProTuner... Pickles954 Engine Management & Tuning 6 01-12-2006 01:27 PM
Will UTEC launch control and the "switch" for... Richard Sierra Engine Management & Tuning 3 02-24-2004 12:30 PM
Anybody using the AP Racing 16" brake kit? BIGSKYWRX Brakes, Steering & Suspension 5 05-12-2003 09:59 AM
