Old 06-04-2002, 12:18 AM   #1
KillerTHC
Member#: 4942
01 SRP 2.5 RS-T
Ludespeed Stage 3 Link'd
Default broken speedo after turbo install
we installed a stage 3 Ludespeed kit with a Link Plus ECU in my MY01 RS and now the speedometer does not work at all (this is one of many problems but we think we know how to solve the others). The speedo always stays at 0 MPH and the odometer/tripometer never get miles added to it. this may sound cool to some, but it's really annoying. i was wondering if anyone has had a similar problem or could tell me where the speedo is wired into and where the sensor is because i think someone disconnected it when they were installing my A-pillar gauges.
also, i have been blowing the fuse that controls the fuel pump but i don't think these problems are related. TIA.
KillerTHC is offline   Reply With Quote
Old 06-04-2002, 02:52 AM   #2
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
umm if you unplugged the main harnesses from the stock ecu that's why you Speedo no longer works.
jeremy
Old 06-04-2002, 03:04 AM   #3
KillerTHC
Member#: 4942
01 SRP 2.5 RS-T
we put the stocker back in and nothing changed.
Old 06-04-2002, 10:52 AM   #4
Jewbaru
Member#: 1994
2013 Impreza WRX
make sure you didn't cut the signal wires going to the ECU, and going to the speedo when you installed the Link.
Jewbaru is offline   Reply With Quote
Old 06-04-2002, 12:25 PM   #5
Impreza Rider
Member#: 756
2003 Legacy L wagon
2009 Kawasaki C14
Which wiring diagram did you use to install the Link?
Impreza Rider is offline   Reply With Quote
Old 06-04-2002, 01:34 PM   #6
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
my next suggestion
Old 06-04-2002, 02:37 PM   #7
Delicious Tuning
Member#: 1990
The Link has should have nothing to do with the Speedo not working, that I know of, unless there is a short circuit somewhere. I have put in three Links so far and two fo the three speedo's work fine.
Besides we do not cut the wiring harness at all, there is a harness that was made to connect between the stock harness and the Link.
Only thing I can think of is under the car, the connection to the tranny got unconnected.
Delicious Tuning is offline   Reply With Quote
Old 06-04-2002, 03:46 PM   #8
Graham
Member#: 11931
2001 2.5 RS Turbo
257/FMIC/T3-T04S
So there's no soldering that has to be done for the Link to be installed? Does it come with a harness?
Graham
Graham is offline   Reply With Quote
Old 06-04-2002, 04:14 PM   #9
KillerTHC
Member#: 4942
01 SRP 2.5 RS-T
Graham
no soldering at all. just connect the harness to the link and the stock plugs to the harness and your in business. the harness is a custom unit though made by Andrew at AMR (i think) and it costs like 100 bucks.
Old 06-04-2002, 05:05 PM   #10
Delicious Tuning
Member#: 1990
Cool
100 to make, maybe more because they are a pain to make. You also have to supply an old stock ECU that fits your RS harness so he can use the connector in to make the harness adaptor. Or just buy them form Gerry.
Help!! Car Overheating after turbo install! bcristea Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 06-07-2004 01:04 PM
Blue smoke after turbo install 99SubRs Normally Aspirated with bolt-on Forced Induction Powertrain 7 09-20-2002 10:44 PM
2.5rs Stalling after turbo install DragII Normally Aspirated with bolt-on Forced Induction Powertrain 28 05-02-2002 11:12 PM
loud ticking noise after turbo installed? RS2000 Normally Aspirated with bolt-on Forced Induction Powertrain 10 04-09-2002 08:51 PM
Tranny temp light after turbo install?? aussiebrydon Normally Aspirated with bolt-on Forced Induction Powertrain 7 10-13-2001 01:24 PM
