Welcome to the North American Subaru Impreza Owners Club Tuesday July 28, 2015
Old 04-07-2010, 12:11 PM   #1
06njsti
Member#: 150986
06 #001 LSB STi
Default 2.5L STi w/ GT30R and TMIC makes 414/421
Over the last year ive been building my STi for the ultimate street setup, and think ive came pretty damn close. I wanted a crazy powerband for the street with super low hp and tq. I also wanted to run a top mount to have very minimal lag, kind of look sleeper, and well just to be different. I know thats the only thing holding the car back but the power it put down is more then enough until I get a better idea of the cars limits. I want to give a huge thanks to Chris, Pete & everyone else at EFI that got my street monster up dialed in on the dyno and running like a champ. I also would like to thank Jodie @ Rallispec, my longblock came out great and couldnt be any happier. And also Rick, JJ and the guys down at IAG Performance for making the car handle like its on rails. And also the only shop that would put my car on some huge rubber, 275's!!! Theres also friends who helped me decide on parts for the car, and wrenched that deserve a thanks too. Chris wasnt expecting the car to put down this much on 93+Meth and I cant wait to see what she does on Q16 when the time comes.
I have already encountered a tuned c5 z06 vette owner who talked trash about my "riced out car with a body kit" at the race track last week. A quick 1/4 mile run shut his mouth right up.
So far ive ran 3 12.11's at the track trapping 117-118, with my best 60' being high 1.7's my first day with this car at the track. When I knew how to launch the car with the prior setup vf39 on 255's I was 60'ing 1.5's and 1.6's all day.So when i figure out how to really launch this car and get more trips down the drag strip i see mid 11's in the future. I also wanna shoot for 10's on Q16.
Car: 2006 Sti
Tuner: Chris @ EFI
Dyno Info: Mustang
Peak HP at RPM: 414whp @ 6500rpm
Peak Torque at RPM: 421ft lbs @ 4100rpm
Baseline hp/tq for a stock on same dyno: not sure
Target Boost: 23PSI
Target AFR: 11.7
Fuel: 93 octane pump + 50/50 water/meth mix
Engine/Power Modifications:
Rallispec Built Longblock
-Cosworth Pistons (99.75mm)
-Rallispec/Manley Rods
-Stock Crank
-Cosworth Bearings (Main & Rod)
-Cosworth 278/274 AVCS Cams
-Manley Springs, Valves & Retainers
-Grimmspeed Ported & Polsihed TGV Deletes
Gates Timing Belt
JDM Oil Pump (12mm)
Mishimoto Cooling Fans
Mishimoto Fan Shroud
Gimmik Motorsports Radiator
Aquamist HFS-6
JDM Spec C 12L Water Tank
P&L Motorsports Rotated 30R Kit
-Garret GT3076 Turbo
-.82 A/R
-3" Cold Air Intake
-44mm Tial Wastegate
GT Spec Equal Length Headers
P&L Race Catback Exhaust
Spearco Top Mount Intercooler
Perrin 100% Atmospheric BOV
Walbro 255 Fuel Pump
DW 850cc Injectors
APS Fuel Rails
Driveline Modifications:
ACT Extreme Pressure Plate & Street Disc
ACT Street Lite flywheel
Suspension Modifications:
Tien Flex Coilovers
Tien EDFC
Whiteline front sway bar (27 mm)
Whiteline rear sway bar (25 mm)
Katrboy Solid Endlinks (front & rear)
Whiteline Anti Lift Kit (race bushings)
Group N Engine Mounts
Group N Transmission Bushings
Group N Pitch Stop
GT Spec Fender Braces
Stoptech Slotted Rotors
Hawk HPS Pads
Goodrich Stainless Steel Brake Lines
Advan Rs's 17x9.5 +35
Nitto NT05's 275/40/17
06njsti is offline   Reply With Quote
Old 04-07-2010, 12:14 PM   #2
RealStreet
Member#: 205916
2003 Subaru WRX
in the 10's and the bends
Who rolled your fenders?
RealStreet is offline   Reply With Quote
Old 04-07-2010, 12:15 PM   #3
06njsti
Member#: 150986
06 #001 LSB STi
IAG Performance was the first to roll then, then when it went to the body shop they rolled them even more.
Old 04-07-2010, 12:15 PM   #4
2wickedWRX
Member#: 151211
2007 RWD STI
WR blue
what body kit is that
2wickedWRX is offline   Reply With Quote
Old 04-07-2010, 12:27 PM   #5
chrisc75
Member#: 183729
07 sti
swp ///95 m3/ 94 supra tt
wait gary u have equals?
chrisc75 is offline   Reply With Quote
Old 04-07-2010, 12:29 PM   #6
WREX88
Member#: 166373
2002 WRX (VF-39)
BMW 330XI
i think your "riced out car with a bodykit" is pretty hot. and 414hp/421tq is pretty dope on EFI's dyno for a 3076. what did you run in the 1/4?
EFI to IAG...westminster, md up to bethel, ct. both great shops...i split my time between ct and dc.
WREX88 is offline   Reply With Quote
Old 04-07-2010, 12:30 PM   #7
mongoosaroo
Member#: 115056
2002 psm now w/ 2.5
jesus tuned my hot rod
nice build!! nothing like shutting up vette owners.
mongoosaroo is offline   Reply With Quote
Old 04-07-2010, 12:36 PM   #8
06njsti
Member#: 150986
06 #001 LSB STi
Yea you didnt know that? EL was the last headers i wanted (I wanted that rumble and not to sound like an evo haha) but they make more power low end, and thats kinda what I wanted for this car.
1/4 mile times are updated in the original post, ive only had the car out 1 day and 7 passes too.
IAG is an AWESOME shop! Its well worth the 2 1/2 hour drive from philly and so is EFI, and im lucky enough to have rallispec 15 mins away.
Old 04-07-2010, 12:39 PM   #9
shadowmd
Member#: 193222
05 Wrx 1.5xtr 6spd
2.5 hybrid 367whp/363wtq
verrry nice!! car looks good. really like the way the wheels fit.
shadowmd is offline   Reply With Quote
Old 04-07-2010, 12:39 PM   #10
DC5edSTI
Member#: 131261
2007 SWP STi 2.5xtr
2003 Corvette ZO6 400whp
Nice, numbers and the car looks good... I'm not a fan of the front fenders, but otherwise it's good looking...
However you say you ran in to a ZO5, you mean ZO6 i imagine.... and how you shut him up with your 1/4 time, but don't mention what you ran or post a slip.... sup wit dat?
DC5edSTI is offline   Reply With Quote
Old 04-07-2010, 12:40 PM   #11
karlknaupp
Member#: 60871
2004 WRB WRX
This car is slow... Until I get a ride in it. Lol.
karlknaupp is offline   Reply With Quote
Old 04-07-2010, 12:50 PM   #12
trex616
Member#: 132365
'02 WRX
EPL B5 S4 & B6 USP
He has equals. Its the cams son!
I believe its INGS+1 front bumper and sides. Seibon hood, Chargespeed +20 fenders, APR splitter, and a Mature rear diffuser. Gary you might as well throw up the full mod list (if it fits).
Having spent some time in this car, it is an amazing street setup. So much area under the HP curve.
And I believe he his still working on getting a proper slip. Im sure he will post one when he gets a time he his happy with.
trex616 is offline   Reply With Quote
Old 04-07-2010, 01:07 PM   #13
DC5edSTI
Member#: 131261
2007 SWP STi 2.5xtr
hmmmmmmm..... that's kinda what I thought.... the time was good enough to shut up some random loser that probably couldn't drive at all.... but would be considered weak for his setup.
well hopefully you get that time your looking for.... again nice car and setup.
Old 04-07-2010, 01:13 PM   #14
DevilsOwn
Member#: 134176
That is one beautiful suby. Nice setup.
DevilsOwn is offline   Reply With Quote
Old 04-07-2010, 01:15 PM   #15
06njsti
Member#: 150986
06 #001 LSB STi
Yea my bad lol, it was a C5 Z06 and if your doubting my 12.1 Ill gladly get a time slip up, but to tell you the truth im embarressed of what I ran. It should be alot faster, it is what it is though and was my first day at the track with that setup and prior to that 1st run I had NO idea where the sweet spot was launching this bad boy with 275's.
Old 04-07-2010, 01:16 PM   #16
Scooby921
Merci Buckets
Member#: 88606
2016 Focus RS
2017 Lincoln Continental
OP please update your 1st post to the required format found here. And if you can, shoot me a new title for the thread that makes it a little more useful for those searching and browsing the PPB forum. Thanks.
http://forums.nasioc.com/forums/show....php?t=1858764
Scooby921 is offline   Reply With Quote
Old 04-07-2010, 01:30 PM   #17
trex616
Member#: 132365
'02 WRX
EPL B5 S4 & B6 USP
Too bad Atco had that event last week. We could've gone and gotten some nice numbers with Price, Sam, John and Jake. Oh well, this summer will be ridiculous. Last one to 10's owes everyone else a tank of race gas?
Old 04-07-2010, 02:24 PM   #18
foolio
Member#: 9351
2006 trailblazer SS
black
I guess you'll be paying for everyones gas then....
foolio is offline   Reply With Quote
Old 04-07-2010, 02:37 PM   #19
D Money
Member#: 109948
. Most famous car
on Nasioc ever. :/
^hahaha you're wild Jodie.
Gary is a dirtball! We were out last night in his car and did a few pulls on 38 and they pulled cepa over instead! hahaha We bailed into some neighborhood and cepa got tickets and the cop said he clocked him at 101mph, but funny thing is he was on break in and couldn't have. Gary is also bangin cepas girlfriend.
D Money is offline   Reply With Quote
Old 04-07-2010, 02:37 PM   #20
vik_wrx
Member#: 194804
2004 VF43 WRX - sold
Amazing build , can we see more pictures of the car?
vik_wrx is offline   Reply With Quote
Old 04-07-2010, 02:44 PM   #21
godforbid67
Member#: 137168
06 Built SGM WRX
35r, PPG, 280's, PSS9.
Very sick. Is that wrb or a different blue?
godforbid67 is offline   Reply With Quote
Old 04-07-2010, 02:47 PM   #22
OppositeLock
Member#: 54060
Now: v8 207/v6 5mt
Then: JRTune fastest td04
Nice setup! It went 12.1, but what did it trap?
OppositeLock is offline   Reply With Quote
Old 04-07-2010, 02:49 PM   #23
06njsti
Member#: 150986
06 #001 LSB STi
Hey hey hey, im not bangin' her yet! and its his ex, if i get the opportunity im gonna tap it and run haha.
There will be a post in MCG in the next few weeks
Its Laguna Seca Blue
Trapping 117-118, the car has ALOT more in it at the track, its just a matter of me getting used to it.
Old 04-07-2010, 02:52 PM   #24
AlxSti
Member#: 94615
|'06 STi 341/356|
www.AffinitiBrokerage.com
Nice work man! She makes great power and those are nice trap times. I'm not a huge fan of the body kit, but I'll give you credit for having it done hella clean. Engine bay pix?
AlxSti is offline   Reply With Quote
Old 04-07-2010, 03:02 PM   #25
Fail Wagon
Member#: 133584
far from sleeper with a hood like that but nice numbers and times. looks good
Fail Wagon is offline   Reply With Quote
Swapage 2.0L to a 2.5L Sti and drivetrain 02Subiwrx-mac Newbies & FAQs 45 01-27-2010 11:57 PM
2.5L VF39 E85 CAMs and Ported heads VS 2.5L VF39 E85 juanmedina Proven Power Bragging 156 09-05-2009 04:27 AM
need a base for 2.5L block/2.0L heads w/VF30 and TMIC db_amn UTEC 9 08-11-2009 05:18 AM
02 WRX, 2.5L STI/wrx heads, GT30R, 93 oct-344whp/329wtq, c16-433whp/398wtq Astacun1 Proven Power Bragging 31 12-29-2005 11:16 AM
FS MD: 2.5L STi Shortblock, 2.5L Gasket Kit, STi Pinks (565CC) bryan carbon Private 'For Sale' Classifieds 3 01-27-2004 10:37 PM
