Go Back   NASIOC > NASIOC Technical > NASIOC Project Cars
Old 04-07-2010, 06:12 PM   #1
hilary0110
Member#: 217964
1989 STS CRX Si
Calico
Default Oh hello STU
You can hear the sounds of my wallet screaming.
This car/build is sponsored by; MODERacing, KartBoy, and Exedy. Thanks!
So here's my build thread, no it won't be done fast, yes it will get done. Eventually.
As it sits, it had a Downpipe, intake, and bov. The bov will be changed back to stock and all current parts are subject to change.
Future Modifications:
Engine
-Intake w/ airbox
-Downpipe with High Flow Cat
-Cat-back exhaust
-Turbo Inlet
-ECU Reflash
Suspension
-Coilovers
-front and rear swaybars
-camber plates
-Alignment specs: -3 degrees front camber with 1/8” toe out, 0-1 degree rear camber, 0 toe
Interior
-4-point harness
-MODE Racing short throw shifter
-shifter bushings
Brakes
-stainless steel lines
-Upgraded pads
-ATE Super Blue Fluid
Wheels/Tires
-Rota 17x9
-10mm spacers
-ARP Wheel Studs
-245/40/R17 Bridgestone RE-11
hilary0110 is offline   Reply With Quote
Old 04-07-2010, 08:27 PM   #2
wrxtremeWGN
Member#: 12281
08 FSXT
Tiger's Blood
looking foward to seeing your progress, i need to start my own one of these... btw why do you want to use 10mm spacers?
wrxtremeWGN is offline   Reply With Quote
Old 04-07-2010, 08:42 PM   #3
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
01 Legacy 95 Impreza L
IBTL!
I always ran spacers in STX (15mm). Widen front track, promote oversteer. But hey I like oversteer. I assume similar reason or needed by offset?
G/L
mccanixx is offline   Reply With Quote
Old 04-07-2010, 09:49 PM   #4
Chiketkd
Member#: 71634
In hibernation...
Nice looking car Hilary. Best of luck with the STU build!
Chiketkd is offline   Reply With Quote
Old 04-07-2010, 10:36 PM   #5
hilary0110
Member#: 217964
1989 STS CRX Si
Calico
Originally Posted by mccanixx View Post
IBTL!
G/L
Over steer > Understeer. I have a hard time driving a car that pushes.. and these things have that tendency.
Old 04-08-2010, 12:40 AM   #6
Butt Dyno
Street's closed, pizza boy
Member#: 17301
is the "dark side"
06 Evo #7 STU, 03 IS300
IBTL!
G/L
Did you run front spacers only? Was that w/ 45mm offset RPF1s?
Soulive needs to sell me his 17x8 +35 Volks
Old 04-08-2010, 02:18 AM   #7
dodwrx
Member#: 130823
1997 Miata
Congrats! Looking forward to the build.
dodwrx is offline   Reply With Quote
Old 04-08-2010, 07:33 AM   #8
Storm
Member#: 5218
96L Most Over-
Developed Beater
Congrats freak!
I'm glad you got this....now I can bum a ride from YOU in Toledo!
Jay
Old 04-08-2010, 07:39 AM   #9
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
Yep, front only 15mm HR's, +45 Enkei's.
I'm sure those spacers may find their way to this car as I no longer use them.
Old 04-09-2010, 11:53 PM   #10
hilary0110
Member#: 217964
1989 STS CRX Si
Calico
Originally Posted by Storm View Post
Congrats freak!
Jay
We could probably work that out Jay if you want?
Mow your front lawn
Well Greg... If you're offering...
Old 04-10-2010, 12:38 PM   #11
Storm
Member#: 5218
96L Most Over-
Developed Beater
Mow your front lawn
So when you get a weird pic on your phone.....don't be surprised!
Good luck with the build, and keep track of what is working vs. throwing parts (money) at it.
Jay
Old 04-10-2010, 11:00 PM   #12
hilary0110
Member#: 217964
1989 STS CRX Si
Calico
I'm hoping Greg helps advise me in the right direction with parts...
Right Greg???
I'll be waiting for that picture Jay
Old 04-13-2010, 12:13 AM   #13
hilary0110
Member#: 217964
1989 STS CRX Si
Calico
Courtesy of KartBoy.
Endlinks front and rear, with spacers for whiteline swaybars, rear subframe bolts, shift knob, rear diff outrigger bushings, transmission corssmember bushings, and work gloves.
:biggrin:
(Can't use the subframe bolts unfortunately )
Old 04-13-2010, 06:53 AM   #14
Storm
Member#: 5218
96L Most Over-
Developed Beater
What are you gonna do with the work gloves?
Nice stuff!!!!
Jay
Old 04-13-2010, 09:34 AM   #15
piknockout
Member#: 192173
2006 STU prepped STi
Sponsored by Agile Auto
You haven't driven my car.
Car looks clean and seems like a good start with the parts! I was reading your post and thinking, "Does she know she can't use the bolts?" Then I read further.
If it helps I've got a lot of info in my build thread and should have even more in the next two weeks as I finish off the rest of the bushings and the intake/turbo inlet. Also talk to Colin, he was a huge help when I was setting up my car. From what I've gathered from my research here, some people like to go stiff springs/soft swaybars while others prefer to go softer springs/stiffer sway bars. I'm in the former camp. Currently running 600/500 springs and 24mm/22mm f/r sway bars and the car feels fantastic.
piknockout is offline   Reply With Quote
Old 04-13-2010, 01:38 PM   #16
Chiketkd
Member#: 71634
In hibernation...
Old 04-13-2010, 02:47 PM   #17
mccanixx
Member#: 60566
2005 XT 5sp, 02 WRX
Jay
Originally Posted by Chiketkd View Post
Hey now! Be nice.
Clearly, give me the gloves!
kidding Hil actually outworks most dudes
Old 04-13-2010, 07:36 PM   #18
Butt Dyno
Member#: 17301
is the "dark side"
Or Vell's. That thing was very RWD'y. You couldn't get on the power too early or it would start stepping out.
Old 04-13-2010, 11:14 PM   #19
hilary0110
Member#: 217964
1989 STS CRX Si
Calico
Hey now! Be nice.
Don't be jealous of my skillllzzzzzzzz
Seriously though. I have a lot of work to do before the 25th.
Old 04-14-2010, 07:01 AM   #20
Storm
Member#: 5218
96L Most Over-
Developed Beater
You and me both...... Finished up the gearbox last night though.
Jay
Old 04-16-2010, 11:20 AM   #21
hilary0110
Member#: 217964
1989 STS CRX Si
Calico
These should be at my house when I get home on the 23rd
Kartboy
-Kartboy Spacers for use with Front Endlinks and Whiteline Bar – KB-017-WhitelineSpacers
-Kartboy Rear Subframe Bolts – KB-0XY
-Kartboy Knuckle Ball Shift Knob 6-speed - KB-015-6-Speed(White)
-Kartboy Rear Diff Outrigger Bushings (HARD BLACK) - KB-018-HARD
-Kartboy STi Front & Rear Endlinks (2004-2007) - KB-017-STI-Combo
-Kartboy Transmission Cross Member Bushings - KB-025
MODE Racing
-04+ STi Double Adjustable Short Shifter – MODE0014
-Super Pro Subaru WRX STi Front Control Arm Rear Offset Bushing – SPP-SPF1388AK
-Super Pro Subaru WRX STi Steering Rack Bushings – SPP-SPF1972K
-Stoptech Subaru STI Front Stainless Steel Brake Lines 04-07 – STP-950.47004
-Stoptech Subaru STI Rear Stainless Steel Brake Lines 04-07 – STP-950.47504
-Turn In Concepts Subaru WRX/STi Race Rear Diff Mount Bushings – TIC-RDMB-RACE
-Turn In Concepts Subaru STi Shift Linkage Bushing – TIC-SLB-0405-STI
-Kartboy Subaru STi Shifting Bushings 6-speed – KAR-KB-003-STI
-Kartboy Subaru Rear Shifter Bushing – KAR-KB-003-REAR
-Whiteline Subaru STI Adjustable Rear Swaybar 24mm – WHI-BSR37XZ
-Whiteline Subaru STI Adjustable Front Swaybar 24mm – WHI-BSF36XZ
-ARP Wheel Studs (10 studs)
-Muteki Open Ended Lugnuts
-STi Group-N Engine Mounts – D1010FE1
-STi Group-N Pitch Stop – D1040FE000
-STi Group-N Transmission Mount 6-speed – D1010FE000
Old 04-17-2010, 12:38 AM   #22
SubieEngineer
Member#: 208152
2007 STI LTD #576
UGM, FOR SALE!!!
^ Good luck with the install! Good to see another STU build. I'm shooting for STU legality at the year's end.
SubieEngineer is offline   Reply With Quote
Old 04-21-2010, 02:18 AM   #23
hilary0110
Member#: 217964
1989 STS CRX Si
Calico
Okay, I ran the car on Sunday in Cincy region.
The car was what I expected. It pushed a lot and as soon as I got my head out of my ass and didn't drive it like Greg's car it was a lot better out there. Tom was just shy of FTD in the car so that was pretty impressive, he got 6th in pax. The boy can drive. It gave me a lot of confidence in the car this season. I'm really looking forward to it.
Unfortunately when I drove up to tech the car this is what I found.
Got some stop leak in it and it was fine for the rest of the event. All 12 runs.
Got back to Toledo today and found this.
As I expected it needed a new radiator. Luckily Jacob had one laying around for me. I also found the AC tensioner pulley was completely ****ed too so Tony luckily had one of those laying around.
Had to pull the grill to replace the Radiator (just made things easier) While it was off I replaced the front emblem.
Radiator was out and back in pretty smoothly
I also replaced the Forge blow off valve with the stock blow off valve.
The Forge Blow off valve will be for sale for anyone interested.
Old 04-21-2010, 02:26 AM   #24
SubieEngineer
Member#: 208152
2007 STI LTD #576
UGM, FOR SALE!!!
Great that you got to run, sucks that the radiator took a dump on itself.
Old 04-21-2010, 02:57 AM   #25
hilary0110
Member#: 217964
1989 STS CRX Si
Calico
Yeah, I'm glad it survived the drive to Cincy (not sure when it exactly broke) The drive to the event, 12 runs, drive back to Athens, then the drive to Toledo, without over heating.
Oh you sad, sad little country Whitford Off-Topic 15 06-04-2010 02:29 PM
Hello to the Sedona Red "Time Attk" on hwy 76 near Wadsworth, OH gpatmac Mid West Subaru Owners Club Forum -- MWSOC 0 07-02-2008 01:48 PM
Oh hello Blossom Paraskass Off-Topic 45 06-27-2008 01:20 PM
Oh hello Punky Matt A Off-Topic 20 06-27-2008 11:54 AM
hello from Columbus, OH zosima Mid West Subaru Owners Club Forum -- MWSOC 51 10-22-2002 05:09 PM
