Old 04-07-2010, 08:13 PM   #1
Cobb Tuning
Member#: 4803
Default AccessPORT Firmware Update for 2.0-liter Subaru AP-SUB-001
COBB Tuning has just released a major firmware update for All AccessPORTs part number AP-SUB-001 for 2002-2003 and 2004-2005 WRXs. This update repairs two minor bugs with the AccessPORT; adds new functions and streamlines menu screens. This update includes all v2 and v2b units with both AccessPORT versions now on the same firmware version: 1.6.0.0-12994, all "BETA" versions have been consolidated into this update.
This release fixes two bugs that were unique to the AP-SUB-001 AccessPORTs. Slowdown associated with extensive use has been eliminated, also, ECU identification errors have been resolved.
Additional Features have been added to the AccessPORT v2 to bring it up to date with the v2b with the addition of the Absolute Pressure, Barometric Pressue and Fuel economy data monitors. The "about" screen on both v2 and v2b has been simplified for easier interpretation and support and the "Change Map" feature has been updated for both units to give an explanation for any gray-out "locked-out" maps.
This update is available immediately through AccessPORT Updater and requires no other updates to maps or tuning software be performed. Further information can be found on our Firmware Information Page.
Old 04-08-2010, 06:42 PM   #2
cueball89
Member#: 90513
2003 wrx wagon
black
So I updated my acecess port and now it no longer connects to the computer. The updater or the map manager. Im trying to put a new map on my car but cant. It worked 3 days ago with the old firmware.
cueball89 is offline   Reply With Quote
Old 04-08-2010, 07:01 PM   #3
cueball89
Member#: 90513
2003 wrx wagon
black
It connects on my other laptop. Strange.
Off topic question:
Why cant I have 2 race tuner programs on 1 laptop? 2 cars 2 access ports and I happen to have 2 laptops. Rather inconvenient.
EDIT:
More problems. Got the map on the access port went to flash the car and is said it cannot connect to the ecu. It reset the ecu fine but keeps saying the green test code connectors aren't connected which they are.
Connected white 4 pin connector.
Connected green test connectors.
The screen then told me to cycle the key.
Then cycle the key again.
Then its not connected, retry.
It has never told me to cycle the key twice...
Old 04-09-2010, 11:50 PM   #4
Shopow
Member#: 184496
2003 Impreza WRX
FINALLY Thanks COBB!
Shopow is offline   Reply With Quote
Old 04-10-2010, 12:48 PM   #5
Shopow
Member#: 184496
2003 Impreza WRX
Tried it today works flawless! Thanks COBB !
Old 04-10-2010, 09:59 PM   #6
cueball89
Member#: 90513
2003 wrx wagon
black
I guess I'll try it again tomorrow.
Old 04-11-2010, 10:20 AM   #7
jonej20
Member#: 198816
2004 wrx
psm
just download it today work every time and also does lunch control works in my04 wrx need help to set lunch control thanks.
jonej20 is offline   Reply With Quote
Old 04-11-2010, 11:40 AM   #8
rexworx
Member#: 103232
05GD 04XT11WRX2.5XTR
PPG,4.44,LSD,E85,6spdx2
+1 on launch control?
rexworx is offline   Reply With Quote
Old 04-11-2010, 01:24 PM   #9
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
no 16 bit ECU's have launch control from cobb. If none of the maps on their webbsite for your car say LC next to the name, doesn't work.
Pretty sure 04 wrx's are 16 bit, if that's the case you will have to do the tinywrx patch through the opensource community to get launch control.
How to add LC to non LC enabled cobb maps
ProdriveDreams is offline   Reply With Quote
Old 04-11-2010, 01:33 PM   #10
rexworx
Member#: 103232
I thought cobb was going to release it very soon. Then they came out with this new update so I thought it may. Another reason is if you select "adjust maps" you can select idle rpm, retard timing, and now LC rpm. Now I set the LC to 3200 rpm, presses ok and it did a lil loading thing to the ecu. I then press the clutch in and floor it but it just wants to rev.
How does it work for the 32bit ecu's? do you have to hit the cruise or defog button, or just push the clutch in a floor it?
Old 04-11-2010, 01:59 PM   #11
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
my understanding of the 32 bit LC is that it uses the clutch switch (which 16 bit's do not have wired to the ECU) to trigger a lower redline when the clutch is not fully engaged.
I don't know anything about defog button pushing.
Old 04-11-2010, 06:49 PM   #12
TurboWRex05
Member#: 216164
2005 Impreza WRX
CGM
^ funny... on my 05 WRX there is a clutch switch that sits in front oof the clutch pedal. When pressed in, the switch it released, when depressed, the switch is engaged. If you look under your dash, there should be 2 types of switches. One is connected to nothing and looks like a button with a spring, the other above it is a switch attached to a box that has wires coming out the back side. If clutch switch is the case, then my 05 has it.
TurboWRex05 is offline   Reply With Quote
Old 04-12-2010, 01:36 AM   #13
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
all manual subarus have a clutch switch so you can't start the car without the clutch disengaged, but ONLY 32-bit and CAN-BUS subarus have this switch connected to the ECU
Old 04-12-2010, 02:43 PM   #14
freetors
Member#: 195982
white
so did we get LC yet?
freetors is offline   Reply With Quote
Old 04-13-2010, 12:03 AM   #15
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
don't you think they would have announced that in some rather large bold type??
Old 04-13-2010, 04:29 PM   #16
rexworx
Member#: 103232
^^^^Thats what I thought!
Old 05-21-2010, 05:52 PM   #17
Cobb Tuning
Member#: 4803
If you are having an issue with your AccessPORT after performing this update, please send an email with the following information to [email protected]
Please include the following information:
- When the update was performed
- What part number
- How your AP is used
- What occurred between update and failure
The log file from AccessPORT Updater has part number and version info for the AccessPORT Firmware and Updater.
Travis
COBB Tuning
QTP downpipe for 2.0 liter WRX in western Indiana (Terre Haute) Fourdoor Engine/Power/Exhaust 9 02-23-2012 03:46 PM
Best 400awhp Turbo for 2.0 liter wrx wishiwuzfast77 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 05-17-2009 10:52 PM
FS: Cobb Accessport V.2 WRX 02-05 AP-SUB-001 explosivexover Engine/Power/Exhaust 2 02-27-2009 02:26 PM
FS: Cobb Accessport V.2 WRX 02-05 AP-SUB-001 explosivexover MAIC Private Classifieds 0 02-27-2009 11:12 AM
Cobb Accessport Version 2 for 2.0 liter WRX Scooby do Engine/Power/Exhaust 0 03-09-2007 01:02 PM
