Old 05-11-2010, 10:19 AM   #1
Atomic Rooster
Member#: 204224
2010 STI
Obsidian Black Pearl
Default AutoX Tire Pressures for factory stock GR STI
What's optimal for a bone stock GR STI? 40/36 psi? 38/36 psi maybe?
I'll be learning the new car, and I'd rather not be changing a thing on the car while I adjust my driving.
Atomic Rooster is offline   Reply With Quote
Old 05-11-2010, 02:53 PM   #2
2superblus
Member#: 33526
2013 WRB W/Gold BRZ
08 STI WRB w/Gold, 02 WRX
40f/40r
I run 38f/42r
2superblus is offline   Reply With Quote
Old 05-11-2010, 03:02 PM   #3
Z06Fix
Member#: 246433
2010 Subaru STI SE
STU 21
I've been wondering the same thing. I know on the hoosiers alot of guys are running mid 30's in the front and high 40's in the rear.
Not sure about street tire pressures.
Z06Fix is offline   Reply With Quote
Old 05-11-2010, 03:39 PM   #4
09rexwagon
Member#: 216135
2011 Civic SI
STX #66, 06 S2000 STR 180
On the GR/GH/GE, the rear double a arm suspension keeps the camber very well and therefore the rear tends to grip quite well in compression (ie push). A way to combat that is keeping the rear higher than the front.
I tend to start with 40/48 cold...comes up to about 45/50 at temp but I"m on Kook RS2s which don't have particularly stiff sidewalls. Another GH in our club has Star Specs and he does about 38/42 if I'm not mistaken.
09rexwagon is offline   Reply With Quote
Old 05-11-2010, 04:00 PM   #5
Atomic Rooster
Member#: 204224
2010 STI
I'm really surprised by those high pressures in the rears. I'd expect that to result in the rear being abrupt to let go at the limit. Couldn't the same results be achieved by running a lower pressure, and thus getting a smoother limit?
Also, doesn't high pressure in the rear cause the outer shoulders to wear severely? Maybe I'm just used to different cars (FWD).
Bridgestone RE070 STi Tire pressures for AutoX (I searched) robmarch Motorsports 28 09-21-2006 05:13 PM
AutoX Tire Pressure for STi w/ stock tires Uber Wagon Motorsports 3 03-17-2004 03:29 PM
Autox tire pressure for Kumho supra 712 lowkey Motorsports 8 07-12-2003 01:01 AM
Kuhmos- tire pressure for WRX/stock size Tex-WReX2 Brakes, Steering & Suspension 3 01-09-2002 02:30 AM
what are good tire pressures for autox? iBlueVirus Brakes, Steering & Suspension 7 05-05-2001 07:34 AM
