Old 04-07-2010, 10:52 PM   #1
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
Default What is the dumbest thing you ever did while working on your car?
I did search, but found no threads on "dumbest thing you've done while working on your car".
Let me start. Let's limit to 2.
1. Spending >2 hours trying to remove rear rotors with e-brake on.
2. Spending >5 hours trying to put back the strut without jacking up other corner.
Old 04-07-2010, 11:08 PM   #2
2:43AM
Member#: 190273
05 WRX evoIII-16G
I'll give it a shot...
1. Buying a crappy, leaky OEM uppipe and installing it. Finding the leak, bitching about it, redoing the entire install again because I thought it was bad gaskets. Bought new gaskets. Did the install again. Still leaked. The part was bad the entire time. Super-mega-fun leak somewhere under the heatshield. Many freezing cold days wasted in the garage. It was a learning experience. Lesson learned.
2. Flushing my cooling system. Necessary, but what a mess.
2:43AM is offline   Reply With Quote
Old 04-08-2010, 12:50 AM   #3
razrielle
Member#: 205698
1. Leaving tools under the hood (used to inventoried tool boxes, thought I had everything in mine, should have known better)
2. Not chocking the back wheels or using jackstands while changing brakes using a scissor jack (back before I knew better, in the 300 dollar car days)
razrielle is offline   Reply With Quote
Old 04-08-2010, 12:52 AM   #4
DCsubieSTI
Member#: 150875
2009 sti
1. changing the oil in my 1972 chevelle ss396 i went to take the ratchet set out the front seat and after i swung the big huge heavy door open to get the ratchet set out it swung closed just as fast and smacked the ratchet set out of my hand leaving a 2 inch gash in the paint on my quarter panel.
2. tightening the positive battery terminal on my 06 wrx i let go of the ratchet while it was still on the battery terminal it swung back down and landed in my AC line and made a huge arc flash good thing i had an insulated screw driver and i lifted it off the AC line.
DCsubieSTI is offline   Reply With Quote
Old 04-08-2010, 12:59 AM   #5
2:43AM
Member#: 190273
05 WRX evoIII-16G
Originally Posted by irshkid72 View Post
...good thing i had an insulated screw driver and i lifted it off the AC line.
You would have been fine. Maybe an oven mitt to remove the ratchet, but no risk of shock!
Old 04-08-2010, 01:08 AM   #6
DCsubieSTI
Member#: 150875
2009 sti
my hand would have been burnt dude. thats straight DC voltage the wrench was screamin hot. no risk of shock but burn yes
Old 04-08-2010, 01:18 AM   #7
pearljam11
Member#: 113335
13 WRB BRZ Limited
05 STi AgileTuned 320/352
I've done this but it was about a half hour.
I've left a wrench on my strut tower and then drove 200 miles before noticing
pearljam11 is offline   Reply With Quote
Old 04-08-2010, 01:22 AM   #8
PlasticFoamMan
Member#: 197764
2002 Nissan Frontier
buh bye WRX :(
Painting my lip before test fitting it
And today forgetting how close I was to the tree behind me (parked about an inch away from it... rolled right back into it while paying attention to something else..
PlasticFoamMan is offline   Reply With Quote
Old 04-08-2010, 01:22 AM   #9
snook07wrx
Member#: 214630
spending about 30 minutes trying to figure out why my hood won't shut all the way w/ the new top mount and splitter, getting quite pissed...
Then seeing a wrench sitting near the plastic radiator cover piece keeping it from locking shut...
snook07wrx is offline   Reply With Quote
Old 04-08-2010, 01:29 AM   #10
txl146
Member#: 32459
02 WRX VF34
Junior Tuned 301whp
This is probably the dumbest thing:
Was too lazy to drive the car in reverse to get car off the Rhino ramp, so I pushed the car off the ramp with driver side door open (thinking I can stop it myself). Ended up damaging the door when car rolled backward - luckily door got jammed on me + garage door and stopped the car ($1500 damage).
Old 04-08-2010, 01:33 AM   #11
razrielle
Member#: 205698
Oh I have another good one, sorry if Im going over my 2 limit
I bought a 91 Geo from this guy who had this great idea to make it into a "performance" car he basically gutted the interior, put a performance steering wheel, msd ignition, projector and angel eye lights on, and some other stuff I forget. He also had it sanded and primered, just never had the chance to paint it. So one night after work I got bored and decided to rattle can it black. Again being young and stupid I did it in my garage, after about 3 cans I finished, thinking it looked good and called it a night. The next morning I pulled out to let it air dry a bit more, I went back inside and discovered the magic of spray paint and aerosol, lucky me mom didnt get to mad over it and her boyfriends cavalier was a pos
Old 04-08-2010, 01:38 AM   #12
wopdeeze
Member#: 148597
00 GDA Jet Black
04 GGA PSM 10 SH5 XT
1. Instaled 4 pot calipers with bleed screw down and couldnt for the life of me figure out why i couldnt get all the air out.
2. re installed transmission got everything lined up after changing the clutch(4th time changing clutch on a subaru 10th time having the transmission or engine out completely) and started to tighten down the bell housing when i realized i forgot the clutch fork.
wopdeeze is offline   Reply With Quote
Old 04-08-2010, 01:45 AM   #13
zweetz32
Member#: 235285
forgetting to tighten one of the pieces holding down the camshaft. Turned on car, snapped one of the cams :-(
zweetz32 is offline   Reply With Quote
Old 04-08-2010, 01:49 AM   #14
subaru_steve
Member#: 219426
2004 Subaru WRX
WRB Stage II
I'll have a go.... Was outside washing my car and spraying down the engine bay, had placed a bag over the intake filter (K&N Ram intake) so as not to soak it. Little brother comes out to hear it start up....needless to say I shrink wrapped my filter.
Side Note: Called K&N and told them exactly what I did, they sent me a free replacement, props to K&N for that!
subaru_steve is offline   Reply With Quote
Old 04-08-2010, 04:05 AM   #15
T WRX rawr
Member#: 215168
2006 WRX stage 2 OS
I started reading this and thought you were my brother. He did the exact same thing. haha
T WRX rawr is offline   Reply With Quote
Old 04-08-2010, 04:26 AM   #16
DriftIt
Member#: 137388
'05 WRX
Back when I was in high school I knew just enough about cars to get me into trouble. At the time I had an '84 Z28 that had been pretty much set up for the track by the guy I bought it from. It had switches for the fuel pump, electric fan, water pump... anyhow, at some point I had turned the fuel pump on and tried to start the car inside my grandpa's shop(barn) but it flooded and wouldn't start and I didn't have time to mess with it because I had to go somewhere so I shut everything down and left in my pickup. Next day I came back out and managed to get it started, however, the oil drain plug had a slight leak so there was about a 6" wide oil puddle under the car that also had some fuel in it from flooding the car bad the day before. At the time I had no exhaust system (only headers) and upon startup, saw flames shoot up from underneath the car. I freaked, threw the sliding shop door open and backed the car out but in my frenzy didn't manage to pull the door closed enough while practically launching the car out of the shop in reverse and ended up messing the front of the door and the front fender up a little but DID make it out in time to put out the fire with a garden hose and not cause any damage otherwise.
Lesson learned, haha...
DriftIt is offline   Reply With Quote
Old 04-08-2010, 05:45 AM   #17
Wannascooby
Member#: 112992
2006 WRX TR
Crystal Gray
Cut bumper for FMIC over 20times because I wanted it to be a perfect fit, but ended up with a crappy cut anyway...Next time measure 19 times and cut once
Wannascooby is offline   Reply With Quote
Old 04-08-2010, 06:00 AM   #18
jamal
Member#: 71875
98 Legacy GT
my wheels fit
-cross threaded a control arm mounting bolt. had to track down an $80 helicoil kit and then buy a new drill just to use it.
-tonight I had my transmission out of the car because I didn't seal the pcv cover on the back of the block well enough and it was leaking a pretty significant amount of oil.
jamal is offline   Reply With Quote
Old 04-08-2010, 07:49 AM   #19
2:43AM
Member#: 190273
05 WRX evoIII-16G
Yes, hence my comment of "oven mitt." Luckily it just superheated your steel wrench and not melt the A/C line which is mostly aluminum throughout the engine bay!
Old 04-08-2010, 08:50 AM   #20
rkramer
Member#: 118209
2015 WRX Limitec
or exploded the battery... that would have REALLY ruined his day
Old 04-08-2010, 08:58 AM   #21
Punk In Drublic
Member#: 232673
2015 wrx limited
dgm
Changing the oil in my girlfriend's old Ford Escape, I forgot to put the oil drain plug back in before I refilled it with oil haha... Yeah.
Punk In Drublic is offline   Reply With Quote
Old 04-08-2010, 09:15 AM   #22
alexjander
Member#: 176630
2002 WRX Wagon
1. Reconnecting lines in the wrong order and pressurizing my coolant system with fuel... (this was on a Jetta Turbo).
2. Using too large a torque wrench on an intake manifold and cracking all the ears... (I forget what kind of car this was on, for a friend)
alexjander is offline   Reply With Quote
Old 04-08-2010, 09:24 AM   #23
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
1. I did that too but only about 20 minutes.
2. Forced a spark plug into the head, crossthreading it and ensuring it would never come out. Luckily the car still ran OK and was old enough that it never needed new plugs again.
3. Just remembered the worst one: worked under my car alone while it was only supported by a crappy cinder block or something. The support failed and the car almost crushed my chest; luckily there was enough clearance for me to wiggle out.
Mike Wevrick is offline   Reply With Quote
Old 04-08-2010, 09:29 AM   #24
wrb-bugeye
Member#: 233624
2002 2004 outback
92 Lifted Toyota Pos
While unbolting stuck exhaust bolts on my truck the wrench broke free and i managed to punch myself in the face. And the latest scare was while replacing my clutch line and not thinking ahead to disconnect the battery, ended up arching my wrench on the starter and almost frying it.
wrb-bugeye is offline   Reply With Quote
Old 04-08-2010, 09:31 AM   #25
timskyline86
Member#: 211913
:P (□)
(ಠ_ಠ)
In my saturn, changed spark plugs and did some other things. Didn't reconnect the wires fully(didnt push them in all the way onto the spark plug). Spent 15min and killed the battery trying to start it. Kept checking everything until i went to change the plugs again and realised what happened.
Another retarded one, changing the break pads spent 30min with a breaker bar trying to get the bolt off until my grandpa walks out and tells me I think its tight enough already...I was turning it the wrong way.
timskyline86 is offline   Reply With Quote
what is the dumbest thing you have seen at a TSA checkpoint? wawawrx Off-Topic 84 03-05-2010 02:55 PM
Dumbest thing you ever did. StopSweatinMe Off-Topic 10 11-20-2005 10:55 PM
What is the 1st thing you ever got pulled over for, once you got your WRX/STI ? 99ways2die Off-Topic 69 11-04-2005 12:30 PM
what is the sexiest thing you ever done for another person slippers2kwifey Off-Topic 52 04-20-2004 04:31 PM
What is the dumbest question you have gotten bout your car bruno General Forum Archive 109 03-27-2001 12:20 AM
