Old 04-08-2010, 01:35 PM   #1
STi-MAN
Member#: 70252
05 STI
blue
Default next size up from m12 x 1.25?
so made the noob mistake of stripping the chassis hole for a m12 x 1.25 bolt.. i think a local shop is just gonna see if they can fix it.. but wondering if they retap.. what would be the next size up in bolt.
this is for a harness to chassis bolt.
thanks in adv.
STi-MAN is offline   Reply With Quote
Old 04-08-2010, 02:09 PM   #2
boost junkie
Top Scoob 009
Member#: 68273
2012 WRX
GD Race Car in progress
Harness as in a safety belt? No way I'd trust tapping to a larger size for that application. I'd either cut off the nut behind the panel and weld in a new one, or at least drill out and helicoil the existing one.
boost junkie is offline   Reply With Quote
Old 04-08-2010, 02:11 PM   #3
subielife
Member#: 181524
1316 BRZ & Tacoma
Blue/Gray
M14 X 2.00
subielife is offline   Reply With Quote
Old 04-08-2010, 02:11 PM   #4
STi-MAN
Member#: 70252
05 STI
blue
yeah thats the bolt.. i was looking into the helicoil.. i think i didnt strip all the threads so they're going to try and fix it.. if not i'll helicoil it for the added safety..
thanks for the input.
Old 04-08-2010, 02:55 PM   #5
fliz
Member#: 30342
1/2".
fliz is offline   Reply With Quote
Old 04-08-2010, 04:53 PM   #6
Turn in Concepts
Member#: 93646
Many Track Records
Let us help you go fast!
Drill out and bolt and nut with backing plate if you can get to the backside
Turn in Concepts is online now   Reply With Quote
Old 04-08-2010, 05:12 PM   #7
STi-MAN
Member#: 70252
05 STI
blue
^ im not sure if i can get to the back side.. its the right under the pillar stock seat belt mounting point.. i'll see what i can do.. im actually not even sure if its a m12 x 1.25 any more..
Old 04-09-2010, 07:21 AM   #8
Storm
Member#: 5218
96L Most Over-
Developed Beater
If I'm not mistaken, the seat belt bolts are not M12x1.25 anyway. They are M11x1.25 (see also, special). Take a lug nut and try to thread it onto a known good seat belt anchor bolt, my guess is it'll slide right over it.
If this is the case, drill and tap it for an M12x1.25 bolt. If this doesn't work, you might as well go to 1/2" because M14 will not fit through most belt anchor plates. Another alternative is a helicoil kit for the size bolt you're using. I just did a tranny crossmember bolt hole on my Forester last weekend. Not fun, but relieving to get it done.
Good luck,
Jay
Old 04-09-2010, 01:40 PM   #9
STi-MAN
Member#: 70252
05 STI
blue
^ sadly i think your right i took off a lug nut and it threads but wiggles like its a size too big.
I called schroth since the bolt in kit they sell has the same size and thread pitch of the oem and they say they supply a 7/16 size bolt.. but im not sure thats what i have.
Old 04-09-2010, 04:47 PM   #10
Storm
Member#: 5218
96L Most Over-
Developed Beater
It very well could be a 7/16" size. I've heard that almost all mfgrs. use the same fastener size for seat belts across the board. A standard for the usage? Guess you'll have to go to a hardware store and size up the fastener first and foremost. Once you know what size you're working with, you can either try to clean the threads up with the same size tap, helicoil it back to the same size, or go to something bigger.
Good luck no matter what you do.
Jay
Old 04-09-2010, 05:38 PM   #11
STi-MAN
Member#: 70252
05 STI
blue
^ you hit it on the mark.
its a 7/16 fine thread for anyone else that has this same thing happen to them..
Old 04-09-2010, 06:00 PM   #12
Wintershredder
Member#: 160089
2008 M5/330xi/328xi
Black/Black/White
Helicoil at the least. Its your life after all.
Wintershredder is offline   Reply With Quote
Old 04-09-2010, 06:06 PM   #13
IAG Performance
Member#: 158123
It's funny but Subaru chose to use Standard on one of the rear seat bolts and Metric on the other. Very strange actually. You are correct though that it is 7/16 fine thread. As far as re-threading the hole....I would not use a heli-coil! You should use something better quality like a Time-sert. It is actually a steel insert rather than a wire like a heli-coil.
http://www.timesert.com/
IAG Performance is offline   Reply With Quote
Old 04-09-2010, 06:17 PM   #14
A5un
Member#: 174095
2011 EVO X MR
Good luck,
Jay
I did the same cross-member hole too on my WRX, it was pain in the ass since I was not setup equipment wise for drilling anything, let alone tapping metals.
I would recommend some sort of thread insert kit, Helicoil or Timesert or some generic crap you can get from McMaster Carr. They all work just about the same. Being able to use the same OEM bolt makes things easier sometimes, though it may be more work up front trying to chase down your desired thread insert.
A5un is offline   Reply With Quote
Old 04-09-2010, 08:58 PM   #15
STi-MAN
Member#: 70252
05 STI
blue
I was able to retap the threads (i didnt strip the threads THAT bad).. every shop thought it was weird that it was a 7/16's thanks IAG for confirming that.. down the road i might do the timesert you were talking about.
Old 04-10-2010, 12:44 PM   #16
Storm
Member#: 5218
96L Most Over-
Developed Beater
Awesome to hear. Others will hopefully be able to reference this thread for the times when this happens.
I'm not a big fan of the way Subaru made any of the chassis mounting points.
Jay
Old 04-10-2010, 02:19 PM   #17
Scooby South
Subtly Outspoken
Member#: 238
99 Ver6 Recreation
JDM Speedwagon 3 LSDs..:)
Exactly what IAG reccomended...
FS: Chrome Spline drive Tuner lug nuts M12 X 1.25 TK421 SCIC Private Classifieds 3 09-07-2007 03:56 PM
FS: Chrome Spline drive Tuner lug nuts M12 X 1.25 TK421 Wheels/Tires 4 09-05-2007 04:43 PM
NEW- Racing lug nuts m12-1.25 19mm hex 60 taper open ended konigjim Tri-State Area Private Classifieds 0 03-27-2007 10:00 PM
Best next size up turbo? Hit Man X Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 10 04-12-2003 11:28 AM
When do we move from a Newbie to the next step up? BSmotorsportsRX Off-Topic 26 09-17-2002 11:13 AM
