#1 |
Member#: 17300
NWIC
Vehicle:'93 Impreza L Wagon JDM Ver8 STi swap |
Event: Dyno Pull
Location: English Racing, Vancouver WA Ambient Temp: 60F Elevation: 171 FT Weather: Overcast Track and Conditions: N/A Tires: 255/45-17 Champiros Car: 1993, Impreza L Tuner: Dyno Info: Dynojet Transmission: 2005 USDM STi 6spd Gear: 3rd Peak HP at RPM: 398 Uncorrected Peak Torque at RPM: 330 Uncorrected Baseline hp/tq for a stock on same dyno: 240-250whp STi Target Boost: 25psi Target AFR: 11:1 ish Fuel: 92 Engine/Power Modifications: 2003 JDM STi Ver8 Engine swap, Stock twinscroll headers/uppipe, Custom VF to T3 twinscroll adapter/twin Tial 38 MV-S/downpipe/intake fabbed by Garage 808, Holset HX35W, ID1000 injectors, Dual in tank Walbros, 3" Titanium catback, Opensource My logger was freaking out when I was at the dyno so didn't really get to tune it, so forgive the AFR wave Something I borked in the wiring I think. Also no E85 fun ![]() I figured I'd still post up what it made since I've been working on this setup for awhile. ![]() Most recent picture of engine bay that I have, since then cleaned up more and new cold air intake now: ![]() I need to weight it again but it was around ~2,500lbs (without driver) last time I checked. All my non-Subaru friends want me to put an intake manifold that actually has a plenum, probably something custom, we'll see if that happens before I go back Car went 12.2 @ 116 with a 2.0 60' on 18psi on the stock VF37 Car doesn't feel nearly as laggy as it looks on the dyno, might try a 4th gear pull next time. Hopefully get E85 tune, and get some drag results soon. -Tim
#2 |
Member#: 149114
very nice, i like the engine bay.
jealous of the 8k redline too |
#3 |
Member#: 153880
RMIC
Vehicle:03 Evo VIII 2011 STI |
Very nice. Aaron over at English racing is a very good tuner.
That power looks like fun. |
#4 |
Member#: 188598
Vehicle:2002 Built v7 ej207 Holset power ;) |
glad to see another holset subie
now tune it with e85 and turn the boost up to 30 ![]() |
#5 |
Member#: 133146
Vehicle:07 FPgreen 7.37@95 WRX VF39+E85 12.0, 121mph |
do you have more pics? the front looks
#6 |
Member#: 173241
TXIC
Vehicle:2002 s256 twinscroll now with one more gear |
looks sick, have any pictures of the adapter you used to go from the twinscroll to t3?
#7 |
Member#: 17300
NWIC
I will post more pictures of car/adapter when I'm back at a real computer.
On a side note redoing the intercooler piping with reverse manifold cut like 8 ft of piping verses the conventional setup I had before - the throttle/boost response is a lot better than mt old setup with the VF37/fmic/stock rotation manifold. -Tim |
#8 |
Member#: 33782
Vehicle:96 bastard child search FIRST, then PM!!! |
sweet!! I wanna see more pics of the car
#9 |
Member#: 97436
South East
Vehicle:05 WRX/ver8 207/ 4.44fd/rotated3076/FJblue |
Thats awesome man makes me think a bit more about bumping from 23 to 25psi on 93...hows the timing mid and top end?
Trey |
#10 |
Member#: 184505
E. Canada
Vehicle:2003 WRX Sonic yellow |
Great post!!!
#11 |
Member#: 244580
Vehicle:1997 Saab 900 Holset HX35 |
Hi, came across your thread on Google. Just wondering which version of the HX35 are you using, is it a 12cm^2 version straight off of a Ram or did you pick yours up elsewhere? When are you actually seeing full boost on the road?
#12 |
Member#: 167244
TXIC
Vehicle:2k3 WRX MBP black & gold is pimpin' |
thaat's siiick!
i wana ej207! ![]() |
#13 |
Member#: 82745
SCIC
Vehicle:2005 Subaru STI 2003 WRX Wagon |
Stock (no aftermarket pistons, rods, crank, and so on) block EJ207 v8?
#14 |
Member#: 115104
Vehicle:2003 WRX Sedona Red Pearl |
Damn that is a nice looking car. Glad to see the results with a stock 207.
#15 |
Member#: 127247
Vehicle:04 Impreza JBP |
cant wait to get one of these motors in my car! nice results
#16 |
Member#: 56203
Vehicle:00 RSTI Coupe |
#17 | |||
Member#: 17300
NWIC
![]() I was going to try to go out and get some better shots, but have been busy/lazy so here's some from in front of my house... ![]() ![]() ![]() ![]() And my awesome stripped interior: ![]() -Tim |
#18 |
Member#: 6675
NWIC
Vehicle:98 SF5 some mods 01 allroad |
Hahahah Tim that is Awesome! Quite a different car than you drove away!
Josh |
#19 | |
Member#: 244580
Your car looks great by the way, I know for sure that thing freakin' flies. It weighs 500lbs less than mine, and mine gets going pretty good ![]() |
#20 | |
Member#: 82745
SCIC
How's the compression on all four cylinders? |
#21 | |
Member#: 17300
NWIC
Definitely would like to see a comparison, is your setup twinscroll? I'm sure I can get mine spooling faster with more tuning and of course having AVCS working. Regardless, even with how the car was when it was dyno'd even my skeptic friends didn't think it was really laggy on the street.
-Tim Quote:
#22 |
Member#: 244580
![]() Didn't do a very good job of it, but I think its enough that you can see how our torque curves compare. |
#23 | |
Member#: 244580
I don't think these turbos are laggy at all, they're huge! Considering you've got til 8k+ to play with, you've got plenty of powerband, too, unlike me. |
#24 | |
Member#: 17300
NWIC
Got any pictures of your setup? Always curious to see what other people are doing - there's about a dozen Hondas around here with Holsets, my friend had a HX35 on his RB20DET swapped 240sx and I think my other friend is going about to put one on his built motor Evo. The custom setups people do with Holsets always interest me.
Are you running a full 4" intake since yours is speed density? Sort of curious how much power I'm throwing away tapering my intake to ~3" MAF. -Tim Quote:
#25 | |
Member#: 244580
![]() ![]() ![]() And here's the rest of the setup if it helps. Stock internals, top and bottom. Thus the low rev limit. Holset HX35 56mm turbocharger Reindeer Performance Custom made twin scroll manifold TiAL V44 External wastegate, .9bar spring Siemens deka 845cc injectors By me 3" downpipe v-band flanged, welded by Liquid & Powdercoat Finishes By me 2.5" delivery pipe JT 3" catback exhaust, catless CXracing 22"x8"x3.5" front mount intercooler Custom Stage 'Drew' tune Bullet 14" universal slim fan Russell -4AN oil lines Walbro 255hp 341 fuel pump Spec Stage 3 Clutch w/ Viggen Pressure Plate Forge FMDV004 atmospheric dump valve K&N cone filter, homemade 4" intake plumbing AEM Wideband A/F ratio Gauge AutoMeter Pyrometer AutoMeter Sport Comp Boost Gauge Equus Oil Pressure Gauge |
| Thread Tools | |
| Display Modes | |
| Dyno Tune: EJ207 w/ stock VF30 | subydude | Proven Power Bragging | 27 | 05-14-2010 12:25 PM |
| Dyno Tune: 2.0L + VF43 makes 285 whp | dsolis | Proven Power Bragging | 54 | 04-05-2010 06:34 AM |
| Dyno Tune: 2.0L + TD04 makes 242whp 263WTQ (Epic Motorsports) | fl4tsc | Proven Power Bragging | 17 | 02-05-2010 03:31 AM |
| Dyno Tune: TD04 at P&L makes 320whtq with new TMIC | sszyma | Proven Power Bragging | 28 | 11-09-2009 04:04 PM |
| Dyno Tune: 2.5L + ATP35 makes 360whp | 2gnt2wrx | Proven Power Bragging | 12 | 10-31-2009 08:32 AM |
