Welcome to the North American Subaru Impreza Owners Club Friday December 2, 2016
Old 04-09-2010, 06:10 AM   #1
FourOnTheFloor65
Member#: 106225
02 WRX STied PSM
03 L, 05 GT Legacy Wagons
Default How to keep a welding table from rusting?
I picked up a nice heavy steel table a few months ago, that I have modified into a nice welding table. It has been in my garage where it has surface rusted a bit. I was wondering if there is anything that I could put on it to prevent or at least postpone the rusting? I would think that putting oil on it would cause problems with the electrical conductivity from what I'm welding to the table.
Is there something that is commonly used for this that doesn't cause conductivity problems, or should I just keep sanding it once a month or so?
Thanks,
Ryan
FourOnTheFloor65 is offline   Reply With Quote
Old 04-09-2010, 12:25 PM   #2
MSI
Member#: 95419
Use it regularly ..... control the humidity in your garage.
We have never treated any of our tables, and they have been setup for 5 years now in the new shop area with no signs of any rust ...
-mark
MSI is offline   Reply With Quote
Old 04-09-2010, 01:06 PM   #3
FourOnTheFloor65
Member#: 106225
02 WRX STied PSM
Well the garage isn't temperature controlled. I heat it when I am working on something and it is cold outside. I open the doors when it's hot. It is insulated but it still gets humid from time to time. Maybe some kind of plastic cover will help.
Old 04-09-2010, 01:14 PM   #4
kharris4
Member#: 46018
2003 wrx
silver(mostly stock)
Just try to keep it clean. If it's rusted once, then it'll rust again even if you think you got it off.
One measure that you may consider is cleaning it up real nice, then welding a thin gage sheet of metal over top of it. Then you have a nice new table to work on.
Whenever we weld SS we use an SS table, CS we use a CS table. Maybe you could incorperate that into your renovation.
kharris4 is offline   Reply With Quote
Old 04-09-2010, 01:21 PM   #5
Member#: 67
1999 Outlasting
the competition.
what ive always used was to put a bunch of WD40 on the table and work it in with a red scotchbrite pad. let it soak in for a bit then wipe clean. you might need to do it ever few months depending on the weather there.
T
Old 04-09-2010, 01:40 PM   #6
Dodik
Member#: 122609
2002 Outback H6 BE
82 GS750E
some sort of zinc coating? never tried it but theoretically may work
Dodik is offline   Reply With Quote
Old 04-09-2010, 01:41 PM   #7
cowboy_Rob
Member#: 194062
2003 Impreza WRX
yea just sand the hell out of it then rub in wd40. it wont affect the conductivity but dont use too much because it can burn if you have puddles of it on there.
cowboy_Rob is offline   Reply With Quote
Old 04-09-2010, 07:53 PM   #8
syndromeofthedown
Member#: 190627
DO NOT zinc coat your table. Not even remotely a good idea. I second, rather third the WD40 notion. It will not affect anything provided you wipe the excess off.
syndromeofthedown is offline   Reply With Quote
Old 04-09-2010, 08:12 PM   #9
kcpaz
Member#: 194611
1998 Legacy GT
Mexico Blue (not red)
you can treat the surface with Jasco, of any other phospheric acid based rust prep. You can buy them at most hardware stores like ACE, and True Value. It will actually help prevent future rust without leaving a greasy film like WD40.
kcpaz is offline   Reply With Quote
Old 04-09-2010, 09:02 PM   #10
Ron89
Member#: 161671
2005 STi VF39
304/320 mustang dyno
I got a free sample of a product from Blue Works (associated with WD40). They sent me a little catalog that had this stuff in it. Looks like it might be what you are looking for?
http://www.blueworksbrand.com/produc...ose-lubricant/
There's even a little side by side comparison.
On top of it all you can order a free sample of this stuff to see if you like it. I chose the PTFE Lube so I can't say if it works well or not...but hey its free.
http://www.blueworksbrand.com/sample
The only thing that kinda sucked is it took a couple weeks to get it but I'm not really surprised.
Ron89 is offline   Reply With Quote
Old 05-22-2010, 12:37 AM   #11
feint05
Member#: 152984
2004 jewbaru
jewbuilt, polish tuned
cold galvanizing compound?
feint05 is offline   Reply With Quote
Old 05-22-2010, 02:57 PM   #12
fan boy
Member#: 241243
T
worked at a machine shop, and that's how they cleaned/maintained all the bench tops.
fan boy is offline   Reply With Quote
Old 05-23-2010, 08:36 PM   #13
Mr. Wagon
Member#: 244383
About a year ago I got a new Acorn platen at work. It came in with a nice shade of red rust from sitting outdoors. I orbital sanded it and then hit it with a nice coat of paste wax. This is in a shop with no climate control and no rust has returned.
Mr. Wagon is offline   Reply With Quote
Old 05-24-2010, 12:34 PM   #14
Viperguy324
Member#: 121108
2006 06 Spec C
very bad for welding...
Even worse...
Viperguy324 is offline   Reply With Quote
Old 05-25-2010, 05:07 PM   #15
madmax718
Member#: 172501
Its not that zinc is bad for welding, the fumes are quite toxic.
If you dont use your bench/table often, try to keep a good polish on it- the smoother the table, the less problems. Also, as recommended wd40 (but it dries quickly). I prefer CLP, rem oil, or even just regular motor oil. Just spray a little break clean on a cloth and wipe down before using. You had best make sure its clean if you do aluminum.
madmax718 is offline   Reply With Quote
Old 05-25-2010, 10:28 PM   #16
GrundleJuice
Member#: 165749
corrosionX spray on, wipe down so its wet but not puddled. repeat every cpl times you use the table, assuming its used infrequently. Wont hurt conductivity, even when electrical joints are saturated. I constantly fight steel and aluminum corrosion and this is the best thing for it, period.
P.S. 16 Oz is enough to treat an avg size welding tabel (4'x4' -ish) dozens of times.
GrundleJuice is online now   Reply With Quote
Old 07-10-2010, 03:52 PM   #17
charliew
Member#: 125304
I have a metal work bench that got scratched up so I took all the paint off the top work area and just wipe it down with eastwoods metal ready maybe twice a year. If it does get a spot on it I just use some emery cloth on it and add the metal ready. Also you could probably get a piece of cardboard and spray some oil on it lightly and put it on the table when you or not using it with the oily side down. Just a idea. I usually have to clean a bench off to have a place to work in my shop.
charliew is offline   Reply With Quote
Old 07-11-2010, 02:02 AM   #18
jakedademon
Member#: 157764
2002 '02 SZ55 hyb
2002 v9 EJ207 VF22 wagon
Sprinkle some crack on it.
jakedademon is offline   Reply With Quote
Old 07-12-2010, 01:39 PM   #19
PERRIN_Jarid
Member#: 214449
-mark
Same here. Even in Oregon as long as you use the table regularly and I wipe it down with a WD40 coated rag once in a while we have had zero problems
PERRIN_Jarid is offline   Reply With Quote
Old 07-12-2010, 07:17 PM   #20
Silver_AWD
Member#: 224375
02 WRX Wagon
^ Same here and I live in Chicago. The temp goes from 100*+ to -14*, how/humid/dry/wet etc. I weld at least once a week on the table, hasn't had one piece of rust on it since I made it. (about 3 1/2 years)
Silver_AWD is offline   Reply With Quote
Old 07-14-2010, 09:55 PM   #21
JCByrd24
Member#: 250098
You can wax your table with butchers wax or even car wax. Wears of after a while but does work, I have the same problem in my garage.
JCByrd24 is offline   Reply With Quote
Old 07-15-2010, 02:13 AM   #22
Kfly04
Member#: 252005
2004 STI
Java Black
Try peeing on it urine has acid in it might help..
Kfly04 is offline   Reply With Quote
Old 07-15-2010, 10:01 AM   #23
Hondaslayer
Interpretively Paraphrasing
Member#: 4562
1995 Legacy LSi
2005 Chrysler Town & ****
Bad idea / good idea.
Cover will help, however plastic does not breathe and will cause moisture to build underneath it. What you want is a cover that breathes and will wick moisture away.
When I am finished I clean my table and dry it thoroughly and just cover it with a light cloth (remnant from an old car cover actually) just to keep other dust / paint etc off it.
Old 07-15-2010, 12:37 PM   #24
wisconsinsubaru
Member#: 232342
lightly hit it with a flap wheel, spray on WD-40 and wipe off. it will leave a nice coating on it.
wisconsinsubaru is offline   Reply With Quote
Old 07-26-2010, 06:38 AM   #25
stiguy86
Member#: 230632
2006 Forester XT
the flap wheel, or wire wheel will work good, i use WD on my benches, but welding nossle anti spatter spray works really good. (i used "eagle" i think), then all those little balls of weld spatter wont stick to it either.. you should be able to pick some up at your local welding supply shop for around 4 bucks a can--
stiguy86 is offline   Reply With Quote
Switching from Cingular to Verizon... How to keep my number? brucelee Off-Topic 16 04-19-2007 12:33 AM
New kitten - how to keep the current cat from killing her? Hazdaz Off-Topic 44 05-17-2006 10:02 PM
How to keep exhaust/turbo bolts from rusting. Scott4DMny Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-09-2005 10:19 PM
How to keep a neon light from flashing? Machine Age Victim Off-Topic 13 09-20-2005 01:27 PM
New ides on how to keep the MAS from blowing tell me what u think Xscreamer General Forum Archive 2 09-28-2000 09:05 AM
