Old 04-09-2010, 10:43 PM   #1
07jayspec
Member#: 155826
07 slow TR ugm
JAB
Default changing map issue
Well, first I was all stock then added Cobb ap v2 stage1 map..
Then added a spt intake and ebay tbe( catted dp ) and the first day I changed the map to stage2 93oct( This wasn't the reflash that's been changed, it was the temporary setting ) hopefully you guys know what I'm talking about.. But the reflash setting is still on stage1 93octane and everything was fine.
But to me it didn't seem like it was pulling as hard as when I had a invidia catless tbe( with NO tune), so I wanted to change my reflash to stage2.
So earlier today I decided to reflash it to stage2 but stupid me, I had my car running when I did this and it shut my car off and and cel came on and it wouldn't let me start my car for a good five mins and everytime I try it again it stays at initializing Ecu then fails..
But my car still starts but idk if its running the stage2 when i check the maps the top one says stage 2 but the reflash said stage1 and idk did I mess the ap up? Need help asap..
07jayspec is offline   Reply With Quote
Old 04-10-2010, 11:23 AM   #2
ProdriveDreams
Member#: 146819
'02 WRB VF-39'd WRX
W/06 STi Drivetrain swap
The AP is fine I'm sure. Keep in mind that the AP does not read anything fromt he ECU that tells it what maps are flashed. It just remember the last ones flashed. I would be more concerned about your ECU. Call cobb and see what they tell you to do.
ProdriveDreams is offline   Reply With Quote
New map issue....nOOb-ish problems westy2005 Open Source Reflashes 2 03-24-2009 09:07 AM
Oct/Map issue X-Factor AccessPort 3 07-17-2006 04:42 PM
AccessPort: Can you change maps with Someone elses AP? kellie00 Engine Management & Tuning 5 05-03-2005 12:03 AM
Unable to change Maps with AP Scoob_13 Engine Management & Tuning 8 01-24-2005 12:43 AM
Gotta Link that's "magically" changing MAP limit values? Look here. DanMan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 11 06-24-2002 05:48 PM
